Question about Gateway Computers & Internet
MA2 CMOS battery replacement
Machine has been wonky on start. wanted to try cmos battery first, but can't find it!
  • Gateway Master
  • 7,627 Answers
Posted on Nov 30, 2012
SOURCE: Gateway 450rog cmos battery
The CMOS battery is located on the motherboard, just under the bottom left side of the keyboard, by the letter 'V". It looks like a clock battery, marked 3V (volts). The battery comes out of its "cage/connector" by gently lifting it with a small flat screwdriver. Replacement CMOS batteries are inexpensive and readily available at any computer shop. Hope that helps
Posted on May 27, 2008
  • 10 Answers
SOURCE: want to replace cmos battery in Toshiba Satellite A10
On Toshiba laptops you hit the ESC key as soon as you turn it on & then you
are given the option to hit the F1 key to enter bios.
As to the cmos battery, they couldn't have hidden it better if it was the Queen's diamond!
It is near the bottom of the laptop on the right side, almost directly beneath the pause/break key.
Problem is, you have to disassemble the entire laptop to get at it!
Disassembly instructions for the Satellite A10 are here
http://www.irisvista.com/tech/laptops/ToshibaA15/SatelliteA15_laptop_disassembly_1.htm
Best of luck
Barb
Posted on Mar 03, 2009
  • 38 Answers
SOURCE: HP PAVILION ZV6000 LAPTOP CMOS BATTERY LOCATION
You have to take the keyboard off. Gently pry the plastic strip that is between the top of the keyboard and hinges. Unscrew the (2 to 4) screws holding the keyboard down. Slide the keyboard up and out. You should see the battery with 2 wires going to the motherboard. Pull the battery connector off the board, take out the battery and wait for about 30 seconds. Replacing it is easy once you have it open.
Posted on Mar 24, 2009
longgee
  • 322 Answers
SOURCE: BIOS CMOS battery dead
You just have to go to the nearest computer store and purchase the battery you needed.
Posted on May 01, 2009
  • 338 Answers
SOURCE: I can't find the cmos battery in my Acer TravelMate 512DX
you have got an older model, try this:
follow the instructions:
you will need:
a slim x-screw-driver
a sharp knife with a slim blade and
a cup or else for the screws, don't loose them!
a new c-mos bios battery model: CR-1220 (exchange it while your in there!)
you find c-mos battery and hdd under the keyboard!
- turn off the power, remove accu and charger cable, for static electricity is friendly fire
to your laptop now !
- open your screen to max. fold (angle of 180 degrees)
- look for removable plastic part near to left holder of screen
- carefully remove it
- also remove plastic panel right to it in the section between display holders
metal should be visible now
- carefully! remove keyboard, starting at the left side, continuing topside
as you won't be able to fully remove it, simply turn it over
- unscrew any screws holding the metal plate, remove it
- now you see: left the CPU plus cooler, top right middle the hdd still in an adapter attached
to the mainboard, at it's lower right the C-MOS battery (g
- turn loos these screws
- carefully remove the frame/adaptor holding the hdd
- unscrew again the adaptor
- seperate hd fram adaptor
... and gotcha!
be careful to get a proper notebook hd (samsung or such)
exchange CMOS-battery by chance
reattach new hd to frame, again carefully!
to reassamble: rewind the procedures
put everything back in place
replug, pray and turn on the lappie.
wish you luck.....
Posted on Jun 13, 2009
Testimonial: "Thanks for all of the information. The keyboard was destroyd during the removal process so we bought a new one instead."
P4P800 - VM BIOS Version 1012 to Upgrade 1018 Now CMOS can't save Date & Time
I'm sorry to have to say this but your CMOS battery connection is bad. There is basically nothing you can do other than replace the whole motherboard if it is too much of a problem.
One of my many computers is like this as well. I'm lucky in that as long as I leave that computer plugged in (it doesn't need to be turned on just plugged in), the CMOS won't reset its self. If you aren't that lucky then I would seek out a replacement motherboard.
Jun 18, 2012 | ASUS P4P800-VM Motherboard
Tip
How to verify that the CMOS battery needs to replace
<p>The CMOS battery is named after the Complementary Metal Oxide Semiconductor power. The CMOS has the current date and time functions for desktop and laptop computers. It allows the computer to automatically adjust the time, even on computers that are disconnected for long time. When a computer no longer has the date and time and forget it on every boot, the CMOS battery probably needs replacing. Some computers have messages when the battery is weak, while others just lose the current date and time after each shutdown.<br /> <p>Time & Date Errors<span> </span><br /> <p><span> </span><br /> <p>1. Turn on the computer. Look in the task bar at the bottom right. Make sure the date and time is set correctly. Double-click the time and click the up or down arrow to switch to the correct time. Click on the arrow next to month to change the month. Click "OK" when finished.<br /> <p><br /> <p>2. Turn off the computer. Wait 3 to 5 minutes and start the machine.<br /> <p><br /> <p>3. Look on the taskbar to see if time was lost and said a strange date January 1, 2000. Replace the CMOS battery, if this is the case.<br /> <p><br /> <p>CMOS Error Message<br /> <p>1. Look for error messages like "CMOS checksum error", "CMOS Read Error" or "CMOS battery failure" when you start your computer. These errors are caused in the machines shut down for several months or when the CMOS must be replaced.<br /> <p><br /> <p>2. Let the computer on for 24 hours. Restart the computer and find the error.<br /> <p><br /> <p>3. Change the CMOS as the return error.<br />
on Jun 21, 2011 | Computers & Internet
P4P800-VM BIOS was Upgrade but BIOS Date & Time can't save from BIOS
If your cmos battery is new and the date and time not change. Try the following.
1. Clean the cmos battery terminals.
2. Check your mother board if there is bulges capacitor.
3. Check the memory you have using if in the same voltage requirements.
Hope this will help to you.
Jun 15, 2012 | ASUS P4P800-VM Motherboard
How to reset forgotten bios password on a dell precision 220
If you know the current password just boot the machine and look for what key to press to get into the Bios or Setup. There you can change it if you know the current password.
If you don't know the password, then you will need to remove the CMOS battery from the motherboard and let it sit for a couple of hours. This will cause the computer to clear memory of everything. Then replace the CMOS battery and start the machine. Unfortunately you might have to disassemble the laptop to get to the CMOS battery.
Mar 15, 2012 | Computers & Internet
Cmos battery error failure
The CMOS (BIOS) battery keeps the computer'a comfiguration and the Date & Time settings in the CMOS (BIOS) chip in its memory. When the CMOS (BIOS) battery is flat these configuration information is lost.
Replace the CMOS battery with a new one, in most cases this battery is a lithium 3 volt battery type CR2032 and it is coin size battery 18mm in dia.(check it to make sure the type of battery is installed on your motherboard).
When you replace this battery then go into the BIOS and set the Date & Time etc.
Jan 26, 2012 | Intel DG31PR Motherboard
I have a HP C6100 All in One error Oxc18a0206 ink failure
Remove all supplies, switch off the machine remove power & usb cable wait couple of minutes.. Power on the machine install the supplies as per appears on screen, check for the error.. For tech guys:
Remove CMOS battery from the formatter, wait for 15 mts, with out battery check for the error. Once error disappears, add CMOS battery...
Jan 04, 2012 | HP PhotoSmart Office Equipment & Supplies
HI, I have a IBM Thinkpad R50e and i had a CMOS battery failure. After replace the battery it has now started to ask me to check the date and time and when i press enter it is asking for a BIOS...
Dear john, replacing CMOS Battery usually RESET password ( plug out your laptop battery,then plug out the CMOS battery. keep it out for 5 minutes.)
After 5 minutes by, put back on the CMOS battery. put it back all together. laptop battery the last one.
On the first boot you need to set the time and date. or by pass it by pressing ESC. >> If your Operating System goes >>> right click on clock task bar >>Adjust Date/Time >> set as you wish >> apply >> ok >>>RESTART your unit.
akee_akee@live.com
Aug 16, 2011 | IBM ThinkPad R50e Notebook
Bio password
Here is a complete guide to disassembly of the VGN-SZ laptop.
http://home.comcast.net/~nw_systems/vgnSZ.pdf
The trick here is to get to the CMOS/BIOS (referred in the manual as the 'reserve') battery. Remove this battery and leave the unit with no battery, A/C power or CMOS battery for an hour or so. Then replace the CMOS battery and reassemble. Power it up. Its going to 'yell' a lot since the BIOS was flushed and all information will have to be put back in. However after you do this, you should be all set.
Hope this helps!
Jun 21, 2011 | Sony VAIO VGN-SZ440 Notebook
Good Morning Sir... My Mother Board Is DG41 WV In This System Problm Is Cheq CMOS Problem... So Iam Change The CMOS Battery... Again Smae Problem Phase... & CLR Cmos Jumper Changed Again Same...
If you've replaced the CMOS battery, set the date and time as well.
If the CMOS setting default to the very first date (1st January 20??), it'll automatically report the "Check CMOS" error.
Let us know if this works,
-BuzzPuppy
May 01, 2011 | Computers & Internet
Where is the location of the Cmos battery for my
You really need a service manual to try & locate the CMOS battery. With laptops the CMOS battery can be different on each model. These are often located on the motherboard below the keyboard, but a service manual should help you.
Nov 01, 2009 | Acer TravelMate 240 Notebook
Computers & Internet Logo
90 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
