Toshiba e233 photocopier does not coincide with the top margin of the original copy
Wider top margin comes out with the copied document compared to the original document
    New Friend:
  • 16 Answers
Top margin??? SEF or LEF
1. If it is the lead edge registration, go to 05 mode and adjust the values of the following...
440 > start > adjust value (for upper drawer margin)
441 > start > adjust value (for lower drawer margin)
442 > start > adjust value (for bypass drawer margin)
443 > start > adjust value (for LCF)
2. If it is the side registration, adjust it from the drawers.
Posted on Nov 30, 2012
Testimonial: "thanks so much! it did works. hoping for your help again when I will encounter another problem"
  • 12 Answers
SOURCE: xerox workcenter XD120f
The small scanner glass (not the full size glass) has some dirt on it. Use a lint-free cloth (not paper) with alcohol or Windex and clean the glass. This should help.
Posted on Jan 27, 2007
Inky
  • 691 Answers
SOURCE: My margin gets cut off on one side whenever I make copies
Are you copying onto the same size of paper or onto another size like A4? If changing size you will have to tell the machine what sizes are in use.
If you are using similar sizes, try setting off a stack and as the machine feeds a sheet in, turn off the power. Lift the lid and see iff the page is running in the correct position and not off to one side. If the page is off to one side, you need to check that you have the paper guide (where fitted) pushed up to the correct position etc.
Let me know if this helps any.
Posted on Oct 11, 2007
007tech
  • 95 Answers
SOURCE: Toshiba 2060 Photocopier prints copies that are a bit too dark.
restart the copier while holding down the "0" and "5" keys. you will now be in service mode. enter "5" and press "start" key a number should show up in the display. this is the exposure value - how dark or light the copies will be. 5 is the automatic exposure setting. around 128 is the normal value. the larger this value the lighter the copies are - the smaller the value the darker the copies.
Enter a new number (exposure value) and press the "interupt" key to save the value. Restart the copier and check what the copies look like. Keep adjusting until it looks good/better.
Posted on Mar 27, 2009
SOURCE: TOSHIBA ESTUDIO 3511 COLOR PHOTOCOPIER
ce 40
Posted on May 10, 2009
  • 153 Answers
SOURCE: Error E000024-0001 on Canon iR 2870 Photocopier
the developing assembly connector has fallen off or the sensor needs replacing
Posted on Jun 04, 2009
What would be causing our Toshiba e-studio 350 copy machine to mis-align margins when printing a document?
This involves 2 different sizes coming from 2 different cassette. 11x17 tray needs adjustment .
Sep 11, 2014 | Toshiba e-Studio 350 Copier
How can I change the format in a Yahoo email?
No. If you want to send an exact copy, attach it instead.
Sep 01, 2014 | Yahoo Computers & Internet
When I am photocopying and scanning documents I am noticing vertical lines on the print in the middle of the page which is ruining the copy, any ideas? Alos message intermittently coming up waste toner...
Most probably you are using the automating document feeder for the photocopy or scanning. If you can lift up the document feeder , there should be the mirror where you can put the original document for manual photocopy or scan. Clean the edges of the mirror with a printer cleaning liquid. There may be some foreign particle stuck there or it is just dirty from long use. Hope this helps.
Sep 02, 2011 | Office Equipment & Supplies
I bought a second hand toshiba 5540 from a supplier here in the philippines. the problem is that the copies produced is not clear.for example, when photocopying a passbook, there is no clear copy that is...
does it copy properly when using standard paper as the medium to copy from
the reason is that many passbooks have a surface that reflects the copy light to prevent those books from being copied
May 26, 2017 | Toshiba 6560 Copier
Double sided printing with Toshiba Studio 3510c series
In the middle of the main screen (in copy mode) there is a big button called "simplex 1 to 1" or it may say "duplex". on the next screen you'll see different ways to do duplex copies. if you have a double sided original then select 2 to 2 / if you have 2 single side originals then select 1 to 2. Place originals in the document feeder and press start
Apr 07, 2009 | Toshiba Office Equipment & Supplies
Photocopies with black lines from top to bottom.
Try check your paper, see whether loaded properly or not.
If yes, probably u need to adjusting your casette
Feb 17, 2009 | Toshiba 1360 Black and White Copier
MFC-9440 CN--Lines in my auto feed scanned/faxed copies
clean the thin strip of glass located under the document feeder with something non abrasive
Feb 06, 2009 | Brother MFC-9440CN Laser Printer
Problem with toshiba BD6560
replace the developer and use ur enlargement feature
Jan 10, 2009 | Toshiba 6560 Copier
Copying problem kyocera mita 3530
You did not specify how much of it it is NOT copying or left off.
Depends on how close to the end it is copying.
Try this make a copy of the ceiling ( open top with no documents and copy) it will give you a black sheet of paper, compare it to your copy, there is a margin of white around the black area this is because :
1- makes sure the toner is falling on the sheet
2- leaves enough room to clear out of the fuser.
Is your print falling in the white area? if so it can be adjusted but there has to be a margin of white around the paper. or it will cause jamming.
Good luck
Nov 15, 2007 | Office Equipment & Supplies
167 people viewed this question
k24674
jasbo
jasbo
