Question about Samsung SlimFit TX-S2783 TV
Just wanted to know if my TV is HD or not. How can I tell. Model no. is TX-S2789 Samsung Dolby Digital
  • Anonymous Feb 22, 2009
    it blocks some of my channel what do i do?
Http://www.hdtv-source.com/reviews/B000F2R5I8_1.html if your tv is similar to this model then yes I assume it is HD.
Posted on Jan 11, 2009
  • moonjokes Jan 11, 2009
    I mean I assume its not my apology
Do you have to have an optical cord from receiver to tv..koss model ks3102..if not i have rca cords were do cords go.
HD broadcasts by TV stations are often broadcast in Dolby Digital. If your TV can output Dolby Digital or HD then you will need to have the TV connected to the receiver via either the optical in, or the coaxial in. If the receiver can get the Dolby signals via the Coaxial and the TV can send them via a Coaxial socket it should work. Don't forget to set your HD set to output Dolby signals. If the TV or Receiver can only send Dolby via the optical you will have to use that. Optical cables can be picked up cheap these days. I have seen them in pound shops!
Sep 09, 2015 | Audio Players & Recorders
How should I connect my denon avr 1906 to my 32" ES6300 Series 6 SMART 3D Full HD LED TV Model numberUE32ES6300U in order to get dolby digital from the tv's tuner please?
Use an optical cable.
Be aware though. Your TV has a DVB-T tuner. It picks up the Freeview standard definition (SD) channels, but not the Freeview HD ones. Dolby Digital sound only comes from the Freeview HD channels.
Your TV will pass Dolby Digital from any source connected to a HDMI port to the Optical Out. It will also pass DTS. But the internal Freeview DVB-T tuner doesn't generate Dolby Digital, just stereo and stereo with Dolby Surround encoding where you use ProLogic II for decoding.
Sep 08, 2014 | Denon AVR-1906 Receiver
Dolby output is Pro Logic II, even though source is Dolby Digital
I know nothing about tivo but dvd player might need to be on bitstream to pick it up.I have to change mine when listening to music. hope this might help.
Mar 26, 2009 | Onkyo TX-SR304 Receiver
Unsure of audio setting using Onkyo TX-SR606 connected to PS3
The PS3 should default to the DOLBY DIGITAL sound output so your ONKYO should be setup to the Digital input, TV logic is a matrix similated multi-channel and I doubt if any PS software is in the DTS audio format, look at your game software disc`s and they will inform you of the audio capabilities.
Feb 20, 2009 | Onkyo TX-SR606 Receiver
Can someone tell me what the audio setting on the Onkyo TX-SR606 should be when the PS3 passes the signal as full multi-channel. My receiver always seems to say something different i.e. Dolby Digital or TV...
If you're running an optical cable from the PS3 to the receiver, best quality would be through the Dolby Digital, because that broadcasts in 7.1 HD Audio Format. There should be a way to get a default setting when the optical input is detected in your receiver.
What Blu Ray to buy for ONKYO TX-NR801 for Dolby TrueHD, etc???
Hi, as the Onkyo receiver you have does not have HDMI switching, the only thing it will do for you with a Blu-Ray player is process the audio signals.  The video from the BR player will have to go directly to an HDMI input of your hi def TV.  In this case, either Sony or Panasonic BR player will be equal.  Assuming you keep the Onkyo unit you have, you would want to use the optical digital output from the BR player as the audio source into one of the optical, digital audio inputs on the Onkyo.  In an ideal world, your receiver would some that does do HDMI switching.  This way, all the audio and video signals from any audio or video source would be automatically switched and channeled through 1 simple HDMI cable into your hi def TV.  This will make you life simpler as ther would be no need to select an appropriate input on the TV, as well as one on the receiver.  That said, buying a new receiver in addition to a BR player is more costly.  Good luck.  Let us know how it goes.
Jan 02, 2009 | Onkyo TX-NR801 Receiver
Not showing DTS MASTEr OR DG True HD
In the menu is an option for switching master and true hd on. Standard its of and played als normal dts/dolby.
also: check the input (blu ray?): maybe it is set to only output no high def signals, so the amlifier doest recieve hd sound..
Igor
Dec 14, 2008 | Audio Players & Recorders
PCM vs Dolby Digital
OK, I just figured this out. Go to the audio options in your DVD player and switch from pcm to bitstream. Now my movies sound right again.
Nov 16, 2008 | Onkyo TX-DS575 Receiver
Onkyo TX-SR605 7.1 Channels... Problem
firmware up date go to onkyo homepage
Apr 01, 2008 | Onkyo TX-SR605 Receiver
Samsung SlimFit TX-S2783 TV Logo
Jerry Greenberg
Jerry Greenberg
