Question about KitchenAid KSM150PS Artisan Series Stand Mixer
Stand mixer leaking oil
When I move the mixer after use, there is a puddle of oil on the counter
  • KitchenAid Master
  • 1,314 Answers
Your gearbox grease is breaking down, time to repack it with some new stuff.
Posted on Dec 01, 2013
SOURCE: how do I add oil to my kitchenaid stand mixer?
if the oil is black or dark green this is the transmission grease. There is plenty in the case don't worry. You may have a cracked transmission case or a bad gassket. I think the most likely thing is a loose screw or two. Take the trim band off, 1 screw. Then take the 4 screws that hold the cover on. You can now lift the top and take a look for the sourse of the leak
Posted on Jan 08, 2008
SOURCE: oil leak from Kitchenaid ultra power mixer
Ah, I found the solution.
http://www.fixya.com/support/t125253-mixer_leaking_oil
Posted on Nov 02, 2008
donmeanie
SOURCE: K45SS leaks lubricant
From what I see, the "O" ring on the vertical center shaft that could be the problem and/or the transmission case gasket. I will let you know what i find when I venture into my mixer. Also, if you decide to try and repair your mixer, plan on replacing the nylon worm gear while you have it apart. Aparently they are known to strip or break. The cost should be minumal for all parts depending on your model, worm gear is between $14.00 to $25.00, the "O" ring maybe $1.00 at your local hardware store and the transmission gasket should be about $5.00. Mixer grease is $17.00 but I think I can find a sutible substitute locally. Check out http://www.goodmans.net/get_list_10.htm for more information and parts.
-DM
SOURCE: kitchenAid stand mixer is leaking alot of oil
ok, there are 4 skrews holding the body together on its white underside( or what ever color you have.) after you get those there are like 9 or 10 little skrews under a shiny rig that goes around the shaft that does all the work in the bowl. pull the ring off and take out those skrews. after that... well i have to find out for myself how to fix the oil leak! good luck and if you find out let me know! BTW here is a link to the service manual.
http://store.mendingshed.com/k45map.html
Posted on Dec 29, 2008
ricardok45
  • 135 Answers
SOURCE: Kitchenaid stand mixer oil leak
Hi. The grease that your mixers are lubricated with has reached a stage where the oil is leaching away from the grease. All your machines need this grease changed. Shell Darina EP-2 or Chevron FM ALC EP-2. These machines need to be internally cleaned and re-greased. It's important to remove the oil from any place that it drips. The planetary gear must be removed, cleaned and re-greased also. It's a messy job, but you can do it yourself if you're familiar enough with machinery. If not, then a suitable service outlet can easily do it.
If you choose to do it, go to the Kitchenaid website and locate the parts files for your particular model, these drawings will assist greatly with the project. If you can, take digital photos at every step of dis-assembly as a reference for re-assembly. If this solution assists you, please rate it. Good luck! ricardok45
Posted on Mar 06, 2009
Mixer leaking oil is it possible some got into my cookie batter
It's pretty impossible to say for sure without having been there to witness it, but it seems possible that it happened. Some mechanical oils and greases are all-natural and wouldn't harm you if you ate a little of them, but that's not something that KitchenAid would ever tell you. As frustrating as it is, I for one would probably choose the safe route and make a new batch.
Dec 22, 2013 | KitchenAid KSM150PS Artisan Series Stand...
Leaking oil
Leaking of oil in a stand mixer is not necessarily indicative of a large problem.
Kitchenaid stand mixers are overpacked with oil to last the lifetime of the motor. If the motor sits idle for some time (is not used), the oil may begin to drip from the gears and settle. Oil leakage may primarily be seen from around the beater shaft or planetary action.
A stand mixer can lose up to a 1/4 cup of oil before it needs to be serviced.
It is recommended to run the mixer on speed 10 for 2 minutes in order to redistribute oil back into the motor. In order to prevent future occurences, this is recommended to be done every 3 weeks if mixer is not being used.
Jun 27, 2009 | KitchenAid Classic Stand Mixer
Oil leaking from shaft after wew moved it
Oil seal around the shaft probably dried up. Before replacing, try penetrating oil at seal, wait a day; if no better, replace seal.
Jun 25, 2009 | Hobart H600 Stand Mixer
My mixer is leaking oil. last time we made bread dough in it it sounded kind of rough. we figured wiyh the heavy load maybe that was the rteason for the noise. when we moved the mixer to clean it, there...
May 13, 2009 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid 250 Watts; Classic: Leaking Oil
Found this,may be helpful.
Why do I see oil leaking from the beater shaft of my stand mixer?
Some KitchenAid® stand mixers that are not used very often or have been tipped may experience slight oil leakage from the shaft or hub attachment. To avoid the oil leakage, KitchenAid suggests that you run the mixer weekly for short periods of time. Generally, the mixer may lose approximately X cup of oil before repair is necessary. The oil used is FDA approved and is not harmful to consume, should any get into the food that you are preparing.
Dec 15, 2008 | KitchenAid K45SS Classic Stand Mixer
Oil leaked from housing
my ultra power ksm90gr 300 watt mixer leaked oil when in the upright position overnight. whats that all about?
Nov 10, 2008 | KitchenAid K5SS Heavy Duty Commercial...
Exploded parts views for all mixers are available at www.kithchenaid.com. Click "Customer Care" in the upper right hand corner of the main page, and then select "Locate Manuals and Guides." You will need to enter the unit's model number exactly as it appears on the bottom of the mixer. It will be listed on a white sticker.
Nov 03, 2008 | Food Mixers
Leaking oil at the base
A TV show "How it is made" was in the Kitchen Aid factory and they used a thick grease and no oil in the mixer. Does your unit get hot? Maybe its melting the grease (dark brown)..
Oct 25, 2008 | KitchenAid KP2671 Professional 6 Series...
How do I add oil to my kitchenaid stand mixer?
Nov 21, 2007 | KitchenAid K45SS Classic Stand Mixer
KitchenAid KSM150PS Artisan Series Stand Mixer Logo
90 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
