Tedelex tv model ec29E09 VOLtage to lopt 12v
Replaced 2sk 2996 and tda44608p40 checked 160v 100uf caps
Slinteriors
  • 8617 Answers
SOURCE: Replacement of LOPT on an LG TV
You will have to cut solder /splice the 3 wires Be sure to dress the splices after soldering with electrical tape. That's the only way if the CRT socket is sealed. Just don't mix up your wires, They should be color coded. Let me know if you need any additional help.
Posted on Jan 31, 2008
crazy larry
  • 6 Answers
SOURCE: Bush TV Dead MODEL: 5693D
switch mode power supply? it has a in or primary side and out the secondary side of a switch mode transformer.
check the driver IC that runs Q102 it makes a oscillation that Q102 amplifies. now the secondary if has a short will blow the Q102 look for shorted rectifiers in the secondary and fuse resistors that are open, even go far downstream and check the HOT for short.
Posted on Feb 23, 2008
SOURCE: tv does not power up
I have seen the schematic, d982 is a 13v 1/2w zener
-GR
Posted on Jun 03, 2010
gopakumarg43
  • 75178 Answers
SOURCE: I want a LOPT (Line
Hello
The service person who told you so is correct. EF series LOTs are of old National Kit, and is not available now. If you have a chance to get it from somewhere, it will cost more that RS 800/= ie about $18, and with that money you can purchase a new kit for your TV, provided your TVs picture tube is good. Just do as you like in this case. Todays TV kits are assemled and aligned, comes with more than 250 channels and includes all accecories, like remote handet, fitting material and so on. OK.
Posted on Dec 10, 2010
eagle338
  • 4889 Answers
SOURCE: set wont start up green
Please tell me whats the make and model of the tv. The orange light flashing is usually a self-diagnostic code and I can tell you what that code means. Also count the number of blinks in between each pause and let me know
Posted on Feb 12, 2011
I have tedelex EC2159 remote codes it should be 3 digits not 4
Pilot remote control codes for TEDELEX:
30 results. Displaying page 1 of 1
NR Brand Model Type Pilot Supertel* Easytel Unitel 1 TEDELEX 1452 R/C P1679Y 2 TEDELEX 1452 TV P1679Y 3 TEDELEX 1455 TV P1655Y 4 TEDELEX 1458 TV P1655Y 5 TEDELEX 1459 TV P1655Y 6 TEDELEX 2052 TV P1679Y 7 TEDELEX 2056 TV P1690N 8 TEDELEX 2092 TV P1679Y 9 TEDELEX 2096 TV P1690N 10 TEDELEX 2098 TV P1655Y 11 TEDELEX 2099 TV P1655Y 12 TEDELEX 2122 TV P1545Y 13 TEDELEX 9227 TV P1690N 14 TEDELEX 9422 TV P1655Y 15 TEDELEX 9427 TV P1655Y 16 TEDELEX 9628 TV P4263 17 TEDELEX EC 2528 TV P4190N 18 TEDELEX EC 2909 TV P4264 19 TEDELEX G 148 TV P4263 20 TEDELEX G 149 TV P4263 21 TEDELEX G 202 TV P4263 22 TEDELEX G 209 TV P4263 23 TEDELEX N 9034 SA VCR P1814 24 TEDELEX RC 94 R/C P1655Y 25 TEDELEX RC 97-PI TV P4263 26 TEDELEX RC 98A R/C P4190N 27 TEDELEX RC 98D TV P4264 28 TEDELEX SOME MODELS VCR 29 TEDELEX SOME MODELS VCR P4205N 30 TEDELEX STUDIO 3000 G TV P1690N
* Note: Supertel, Minitel and PRO-TEL universal remote controls will share the same code.
Feb 26, 2017 | Televison & Video
My tedelex tv model EC29E09 seems like it's turning on as it shows the on light when you press the on button but nothing happen thereafter
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Feb 09, 2016 | Televison & Video
Sony TV model # KV-J29 MF8 , sound ok in 1 min and led stdy.and no picture
check for bad voltage regulator ic. Check for 160v across your main cap and power supply. Use floating ground, to see if power supply is working. If you have 160v, check for 130v b+ to see if your horizontal circuit is working.
Nov 27, 2011 | Mitsubishi CS-40503 TV
RED LED FLASHING WANT STOP/TV WANT COME ON
Check power supply to see if its working, check across main cap, Do not use chassis ground for 160v. If good, check for 130v on the collector of the horizontal output transistor, if missing voltage, check for either an open low value resistor in the power supply or an open pekoe fuse or a bad voltage reg ic.
Oct 31, 2011 | Toshiba 32A43 32" TV
Power on for a few seconds then turn off
Tv is going into x-ray protection mode. Check power supply voltage, make sure it's not too high. 160v dc across main cap, do not use chassis ground, use cap ground. If too high, something is open. If too low, something is shorted in power supply. Check voltage regulator ic.
Oct 05, 2011 | JVC AV-32D305 32" TV
W/supply voltage fuse is ok w/output voltage no supply voltage on fly back
Very likely the flyback is bad. Most CRT sets have an SCR clamping circuit that "crowbars" or shunts power if the voltages on the flyback outputs are not within spec.
Jan 30, 2011 | Televison & Video
Television works fine all of a sudden it turns off if i unplug for a while and then turn it on it works again,and then it happens again aprilladybug1926@q.com
Send it to repair.
Your unit need to check the leaky electrolytic capacitor,regulator.
Leaky capacitor (most especially the 160v/100uf) will shuts down the unit because it will not give sufficient voltage. I've encountered also on Sony TV that the faulty voltage regulator will do the same thing as what happen to your unit so it is better to look for a qualified technician/service center to isolate the faulty parts.
Thanks for using fixya....
Jan 04, 2011 | Televison & Video
Tv d'nt work and det power
Just check the B+ of your Tv use a voltmeter and measure the voltage. find the capacitor 160V that is the B+ filter cap.the reading must be around 115vdc.
If no voltage but fuse ok, check the 400v cap. the voltage should be around 380vdc.
Jun 02, 2009 | Televison & Video
Philips 20ps47s301 turns on then starts clicking and turns off
IT SOUNDS LIKE YOU HAVE A POWER SUPPLY PROBLEM OR RELAY PROBLEM. BEING A 20 INCH SET IT IS NOT WORTH REPIRING. PARTS AND LABOR WILL BE OVER $100.
Jan 16, 2009 | Philips 20PS40S 20" TV
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
