I have pro com gas logs cant get pilot light to stay on and heater to com on
  • 700 Answers
Not sure if this poarticular unit has it but try to clean the thermocouple off with either a wire brush or emery cloth. then attempt the re-lighting of the pilot.
Posted on Jan 11, 2009
  • Todd Born
    Todd Born Jan 11, 2009
    be sure to hold it in for 30 seconds afer you re-light the pilot.
Pilot light wont light
Rita, Check the attached links,instruction and guides to trouble shoot pilot light, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Gas Heater Pilot Light Troubleshooting
What to Do if Gas Furnace Pilot Light Won Stay Lit DoItYourself com
Furnace Won Ignite Why and What to Do
Aug 03, 2016 | Heating & Cooling
Heater serial # 3687823 was working fine then just stopped. cant get it to light now
if the pilot lights when held but wont stay lit, the thermocouple is shot, local hardware stores sell universal thermocouples. self explanatory to replace. if even when pressing the button the pilot doesn't light there is a blockage in the gas line or control valve. that needs a pro to fix.
Mar 16, 2014 | Procom Heating & Cooling
Once I get the pilot light lit , hold for 30 seconds, and the let the knob out to turn to low or high, the pilot light won't stay lit.
From what you're describing, either the Thermocouple needs cleaning or it needs replacing, However, these are not easy units to work on for a Do it your-selfer. so I would recommend taking it in to a pro who can get the part if necessary and replace it if necessary. Most independent hearth stores that sell and service gas logs and gas fireplaces can help you.
Jan 24, 2011 | Endless Summer 233000 Open Flame Patio...
My propane fireplace pilot light wont stay lighted help
Most gas valves have a flame sensor, which is a metal bulb at the end of a wire. The pilot light heats this bulb, and the valve stays open because there's a flame. If the flame has been out, you'll need to hold down the pilot light button for as much as two minutes after lighting the flame to allow the flame to heat the flame sensor up enough to keep supplying gas when you release the button.
Mar 17, 2010 | Desa International CCL3018N 18KBTU VNTFRE...
Pilot light won't light on ventless fireplace
Ventless Gas logs, Vanguard, VS30PR. Propane gas
Pilot light stays lit various times, sometimes for several days then other times for a few minutes. Lights best when temp outside is below freezing. Pilot flame appears to receive too much air. How do you adjust the pilot flame? Is this done using two screws marked A & E? Do you have suggestions?
Thanks,
Ed
Jan 07, 2010 | Desa International Unvented Gas Space...
My pilot light kept going out. I cleaned it
You may have to get a new thermocouple.
This is a small copper tube that goes from the pilot light area to tha gas valve.
It feels the heat from the pilot and keeps the gas valve open for gas to flow to the pilot or to the logs when in the lit position.
Without the gas valve will stay closed.
Jan 06, 2010 | Vanguard International Blue Flame - Medium...
I have a Martin ventless gas log fireplace. I
Sometimes when you turn a gas heater off for some time, if the source tank has been turned off, the line will bleed the propane and the line will contain mostly air. This is especially true if the supply line is long. In order to light the pilot, you will have to hold the pilot lighting button down for a while (a full minute or longer, depending on the size and length of the supply line) before pure propane arrives at the pilot light jet. You should keep a lighted lighter at the jet so that when the gas arrives, the lighter will light it. After the pilot lights, you will have to keep the button pressed long enough for the thermocouple to get hot enough to set the pilot to stay on. When it is hot enough, you should be able to release the pressed lighting button and the pilot should stay on. If it does, you should be able to light the heater. If the pilot jet never lights, gas is not getting to the regulator. If the pilot will not stay lit after a period of time waiting for it to heat the thermocouple, the thermocouple or the regulator may be bad and need replacement. :-)
Jan 03, 2010 | Desa International Unvented Gas Space...
I have a set of propane gas logs. The pilot light
Check the connection of the thermocouple or replace it if connections are tight.Pilot safety valve may be badreplace gas control valve.
Oct 24, 2009 | Desa International CCL3924PTA 24" LP Gas...
Heating & Cooling Logo
57 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
