Question about Kenmore Side by Side Refrigerator
Location of freezer thermistor in a Kenmore side by side refrigerator
Kenmore model #106.53659300
  • Steve Zissman Dec 02, 2012
    I have solved my problem - The thermistor on the freezer side enters the freezer cabinet at the top right, through the damper cutout. You will have to remove the air diffuser from the top of the cabinet to see anything. It is then threaded down into the right side shelf bracket holder, just pull the black wire out of the bracket holder and you'll see it. In order to replace the thermistor, you must remove the damper from the refrigerator side. There is NO documentation on this in the Kenmore parts diagrams, I took everything apart to find it.
VANMAN69
  • 23 Answers
SOURCE: freezer works ok.refrigerator temp varies from 39 deg.to 60 deg.
check to see if there is frost in the back of the freezer if so you have a defrost prob..
Posted on Jun 29, 2007
  • 1122 Answers
SOURCE: Refrigerator freezes up
PLEASE DISREGUARD GUEST FIXYA SOLUTION,FREEZER PROBLEM PROCEDURE IF NOT DEGITAL,FIRST CHECK IF ICE ON BACK FREEZER WALL. STEPS-FIND DEFROST TIMER,BOTTOM FRONT ,BOTTOM BACK, INSIDE FRIG.ON CONSOLE,LISTEN TO SEE IF FAN IS RUNNING IF SO TURN THE DEFROST TIMER CLOCKWISE TILL YOU HEAR A CLICK SEE IF FAN TURNED OFF IF SO YOUR FREEZER IS IN DEFROST,FREEZER WILL COME OUT OF DEFROST IN 20-30 MINUTES IF IT DOES AND THE FAN COMES ON YOU HAVE ELIMINATED DEFROST TIMER&FAN,NEXT REMOVE BACK PANEL TO FREEZER IF THERE IS ICE FORMING REMOVE BOTH LEADS TO HEAT AND CHECK WITH VOLT METER ON OMES,IF YOU GET ANY READING THE HEATER IS GOOD,IF NO READING REPLACE HEATER AND CLIPON TEMINATOR,IF HEATER IS GOOD DEFROST COILS WITH HAIR DRYER TOP TO BOTTOM AND THIS WILL ALSO CLEAR THE DRAIN,IF EVERYTHING CHECK OUT GOOD DEFROST TIMER ,FAN ,HEATER, DRAIN, YOU NEED ONLY TO REPLACE THE LITTLE ROUND CLIP ON TERMANATOR,LET ME KNOW-MIKE
Posted on Jun 17, 2008
  • 1462 Answers
SOURCE: side by side kenmore refrigerator
defrost system not working. take back plate off freezer. checkdefrost heater and any stats mounted on the pipework
Posted on Sep 10, 2008
  • 117 Answers
SOURCE: I have a Kenmore coldspot side by side- not cooling properly
Setting it to 5 is what the manufacturer recommends. If you set it to 1 and the frig is still not cold, then you probably have a faulty cold control (thermostat)
http://tclaundryrepair.com/home
Posted on Feb 19, 2009
VOTIT
  • 2071 Answers
SOURCE: Kenmore side by side is not getting cold or freezing
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
Is the refrigerator completely dead?
If so, see “It's stopped completely.”
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
The compressor
The Thermostat
The overload, relay, or capacitor
The defrost timer
The condenser fan motor
The freezer and the fridge are cooled by the same system, air is moved to the fridge by a fan from the freezer, either the circulation fan is defective or the fridge thermostat is defective.
Regards:
VOTIT
Don't forget to rate;
Posted on Jul 05, 2009
Freezer side working frige side not
Check ur cold control thermostat, ur thermistors in both fridge and freezer ( they should be checked for both ohms and for amount of current being put out as per ur model ), ur air flow vent from freezer to fridge.( to make sure it opens and closes without any restrictions) On thermistors check for A close circuit and amount of ohms not just an Ohm reading. As per ur model. Most should atleast show 1200 ohms. Also Check door seals for leakage. check ur fan and air flow damper vent too
Jul 28, 2014 | Kenmore Refrigerators
Defrost timer
The defrost timer is part of the electronic control baord located on the back of the refrigerator. If the freezer is not defrosting check the thermistor on the evaporator(freezer) coils. It can cause the control board to thing it doesn'y need defrosting. a common problem
Mar 22, 2014 | Kenmore Side by Side Refrigerator
I'm trying to find out how much the thermistor costs to replace on the EB9SHKXVQ03
Use google to find a place that supplies whirlpool spares, tell them the model of the freezer and which thermistor you want, then ask them how much for a thermistor.
Dec 21, 2013 | Whirlpool EB9SHKXVQ Top Freezer Side by...
Thermostat location ed2fhgx
Your model does not have the old style thermostat. It uses a=> 12002355 Thermistor
and located inside the control panel and freezer compartment. The thermistors connect to the control board. Here is a parts list and the list shows the thermistors=> MFI2568AES.pdf I am here should you have questions, Sea Breeze
Nov 27, 2013 | Maytag MFI2568AES Stainless Steel Bottom...
Well it looks like THIS. and it mounts on the evaporation coils inside the ice box behind the service panel How to check:
Nov 30, 2012 | Kenmore Dryers
Side by side refrigerator not cooling
call an ref and aircon technician to fix it, maybe it needs some frion
Jun 29, 2012 | Kenmore 64722 Top Freezer Refrigerator
How do I replace freezer thermistor
I have a Galaxy refrigerator model # 106.55122700 refgigerator side do not cool anymore
Apr 14, 2009 | Kenmore Refrigerators
Kenmore fridge
i would suggest if you can take a look at the damper control at the refrigerator side. it is located at the middle. it regulates the air coming from the freezer section and dependent on the signal coming from the thermistor... so that is the next thing to check. if the thermistor in the refrigerator side is working fine.
i hope i was able to help...
May 20, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Side by Side Refrigerator Logo
183 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
