Noisy fan (2yrs old) seems to be causing slow cpu operation and apparently implicated in hdd failure.
Part no 1323-006H0A2-AOB-106Q-0FZ
fire sine
  • 382 Answers
SOURCE: CPU fan failure
The bearings in the fan or internal mechanism may have burned out. If the fan does not generate a cool enough environment, you run the risk of frying the processor and other motherboard components that are temperture sensitive.
Replace, don't attempt to repair.
Keep me posted.
Posted on Oct 28, 2007
win_john_don
SOURCE: extremely noisy fan!
First turn off your pc, pull out the main cooling fan and clean with with an oil or a wd-40.
Posted on Jan 15, 2009
  • 12 Answers
SOURCE: CPU fan issues
The fan may not stay on all the time - its a feature of laptops to help save power. The fan is also variable speed. As the CPU gets hotter, the fan speeds up. When the CPU isn't being used as much and is cooler, the fan slows or even stops. It turns on to full speed when you first turn the laptop on as part of the BIOS system check.
The noise is another issue. You could have a broken "fin" or fan blade. The bearing could be going out. Something may have simply "crawled" inside the fan's output vent. In any case it may be worth your time to have a professional open up the laptop and look at the fan. I have heard a LOT of noisy laptop fans in my day, and believe me it's not the worst thing to put up with.
Posted on Mar 19, 2009
SOURCE: Fan Speed Too Slow
You need to pull the fan chain until it is set to the fast setting, then you use the remote to set the fan at the speed you desire.
Posted on May 28, 2009
SOURCE: motherboard won't boot up cpu fan comes on hdd
check PCI card any connected , check the ram and processor installed properly if removed.
after this there is problem try to change the ram to other ram slot and ram which is working. or check your system ram in other system. if it does not work let me know.
Posted on May 07, 2010
Overheating
You will probably need to replace the CPU fan down the road and remove the old thermal grease between the heatsink and the processor ic for new compound, will make all the difference.
Sep 24, 2012 | Toshiba Refurbished SATELLITE CEL600 64M...
Dell Inspiron 1012. On power on I get 7 long beeps recuring about every ten seconds or so,the screen remains black and no hdd activity I have checked the hdd and all ok,memory seems ok beeps still sound...
The beeps during startup depend on the BIOS. Here are some possible causes of the seven slow beeps on different bios:
AMI (American Megatrends') = virtual mode exception error.AST Research = Processor register read/write verify test failed. Compaq = AGP video.Mylex = DMA page registrater error.
there are others which i didn't include....
Jul 27, 2011 | Computers & Internet
It was just this morning when I tried to turn my pc on.. unfortunately it did not. ! when i press the power button on cpu it turns on for a few second like one or two but immediately after it drops the...
Try replacing the power supply - I had a similar problem that was fixed that way. If that doesn't work, it's probably the motherboard itself. The CPU is also possible - have you overclocked it or otherwise cooked it? Is the CPU cooler/fan blocked with fluff, or has the fan been slow (or stopped) - noisy fan is a sign of bearing stiffness/partial seizure which slows the fan and lets the CPU get too hot. If the CPU is fried, you get the symptoms you describe (MB won't start the PS)
Dec 23, 2010 | ASUS M2N-MX Motherboard
The heater operation is very noisy compared to new. Perhaps it's the fan? The heater is six years old and I'm concerned that it may cause a fire.
Its most likely the bearings in the fan motor failing causing vibration. One simple way would be too check and make sure all nuts and screws and bolts are tight around th e fan. If so is the fan blade dirty it doesnt take much dirt on a fan blade to get it out of balance and cause bearing failure.
Dec 13, 2010 | Dayton (3UG73) Electric Utility Heater
Why does my fan seem to be cycling at all times which is slowing down the computer big time
your fan has nothing to do with your computer slowing down.
your fan goes on when a threshold is reach in the cpu temperature or another component's temperature being cooled. the question is what's is causing your cpu or your chipset to work harder than usual causing your system to seem to be sluggish??
the simple answer is malware and need for a clean up and tune up
I suggest you do the following:
1. get an air can, open the case and without touching anything and watching for ESD, dust off your system free.
2. close the case and turn your computer on
3. update your antivirus and run deep scans
4. get all critical updates for your system from windows update
5. download, spybot search and destroy, malwarebytes, superantispyware, and a square free edition, update them and run deep scans.
6. defrag your hard drive
7. to improve perforamance make sure you update or upgrade memory
good luck!
Apr 23, 2010 | Gateway 831GM PC Desktop
Have gateway pc with vista. For no apparent
Possible problems:
CPU over heats / causes shut down.
Virus / Malware.
Defective heat sink/fan
defective CPU.
Improperly seated CPU.
Nov 24, 2009 | Microsoft Windows Vista Home Premium with...
Rolling reboot problem, computer reboots for know apparent reason.systemax venture p4
Probably getting too hot or HDD problem.
If too hot you may take of the case and blow out the system with an air compressor (just take it outside away from clean things). Also while it is apart clear away any lint debis from the CPU fan & heatsink area. Leave the case off and hookup your system again. This will do two things, 1.) give you better airflow to test the heat theory and 2.) give you a chance to peek at the CPU fan to see if it is moving well. Depending on your motherboard you may have a sensor monitor in the bios which will allow you to check the tempature of the CPU as well as the fan speed.
If it is a Hard Drive problem listen for a noisy drive arm (clicking sound). Lastly if it's a memory problem you can tell by swaping out the chips. But i would lay odds that it's a heat issue. Hope this helps, Best Regards, -md
Nov 10, 2009 | Systemax Venture PC Desktop
My sony vaio VGN-CS11S is soo noisy
The fan's bearings are probably going bad, or there may be some object that was sucked in to cause the noise.
Sep 28, 2009 | Sony CPU FAN CPU Fan
My Compaq NC6400 is very slow and doesnt charge the battery
i had the same prob and changed the ac and its bac to its old self
Jul 11, 2009 | Computers & Internet
Hi I have a HP Pavillon a708 and the fan is almost constantly on. It's really noisy and seems to slow the PC down, is there anything I can do??
First, open up the case and gently vacuum all the dust, especially around the 2 fans.
If still noisy and the problem is the cooling fan (3-5 inches across), buy a replacement fan of the appropriate size at a PC store for $30 - $40. It takes 5-10 minutes to unscrew the old fan and install the new one, and just use the same electric wire from the old fan for the new fan.
If it's the CPU fan, you'll need to have your PC serviced.
Hope this helps.
Jul 09, 2009 | HP Pavilion a705w PC Desktop
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
