Remington PTAC Heater/Cooler
I have a Remington PTAC Heater/Cooler and it never seems to blow warmer air. When I have the temperature gauge set at 70 degrees, it blows the same temperature as when I have it set at 85 degrees, and the air is rather cool. Is there a way to calibrate the temperature of the heat blowing out? Since the air is cool, the unit keeps running and never heats the room.
Thanks!
  • jameswbacher Jan 11, 2009
    Thanks for the response. Interestingly, these are all brand new units, but the same problems. I am wondering if there is an initial setup that needs to be done to calibrate the heat sequencer. Any suggestions?
    Problem Solver:
  • 20 Answers
You may have a bad heat sequencer
Posted on Jan 11, 2009
My Amana PTAC set to 90* blows cold air then warm then back to cold. The temperature outside is just a few degrees
sounds like the auxillary heat strips are coming on and off....what kind of time does it cycle on and off?
Feb 16, 2015 | Amana Heating & Cooling
2005 Buick rendezvous heater blowing cold and temperature gauge not working properly?
Faulty coolant temperature sensor and a faulty heater control valve.
Jan 14, 2012 | 2005 Buick Rendezvous
Heater
there may be an air lock in the system, Have you toped up the anti freeze lately?
Jan 31, 2010 | 2001 Ford Explorer
Heater blows cold air. also, the temperature gage
A thermostat stuck in the open position can cause both of these problems
Nov 12, 2009 | 2002 Chevrolet S-10
Back air blows cold air, the front blows warmer air
I recenly had the same problem on my 1999 suburban, even after I replaced the whole ac system.
The heater valve, which is under the air filter area was not closing, causing heat to be blowing over the evaporator core. I used a zip tie to keep it in the closed position, and ac went from 70 degrees to 40. I think the vacuum switch is bad, 40 dollars (dealer part). You can also pull the vacuum hose off the switch, which is on the firewall and connect it dirctly to valve and it closes the valve, but fits loosley. Use silicone around vac hose if you go this route.
Jun 09, 2009 | 1999 GMC Suburban
Heat temperature issues with Goodman GMP 100-4 furnace
69,000 btuh is adequate for a 12-1400 square foot house.
Otherwise, your thermostat simply tells the furnace to cycle on/off.
If it calls for heat and does not come on, the problem is with switches and relays within the furnace.
Your setting the temp higher only causes the other parts to keep trying until they finally light and heat.
This is based on your information saying it will cycle on and blow cool air--not hot air.
You will have several temperature variations from floor to ceiling.
You probably have ceiling vents as well.
You need a technician to verify the rollout switches, fan relay, inducer fan etc. if the furnace is not firing everytime you call for heat.
Feb 21, 2009 | Goodman CPLE24-1 Air Conditioner
2000 Silerado Heater Problem?
your thermostat could faulty.when it stuck open it won't let the engine heat up to the right operating temperature and will be blowing luke warm to cold air out of the vents.have it replaced that should solve your problem
Nov 17, 2008 | 2000 Chevrolet Silverado
Heating & Cooling Logo
381 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
