Question about Microwave Ovens
Microwave whirlpool JT 379 won't heat up
After showing "error 2" it appeared to be working (allows programming, rotates) but fails to heat food up, both in the microwave and oven functions. In the stand-by position it claims to be set to other functions, e.g. "6th sense".
SOURCE: microwave oven does not warm food up
I have not solved my problem,I have decided to buy a new microwave rather than pay for this amount of money on a telephone advice when you have said on your site that it is free.I will also spend further amount of money, to call an electrician after your advice,so I will be better of buying a new one.
Posted on Jun 11, 2009
catriver
  • 878 Answers
SOURCE: My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
Waleed, Since the microwave is going through all its motions we can feel safe that the oven and magnetron thermostats are ok. If they were bad you would not have a display. Just inside the control panel to the left, you have 3 switches which the door activates. A primary (top switch) a secondary (bottom switch) and a monitor switch (middle). If the primary or secondary switch is not closing when the door is shut, you high voltage side will not activate, therefore no heat. If the monitor switch failed or found either the primary or secondary switch closed with the door open, it would blow the main fuse and the oven would be dead. Therefore Im leaning on either the primary or secondary switch not operating correctly. When checking these switches, unplug and discharge the capacitor. This is high voltage. Good luck
Posted on Jun 17, 2006
  • 97 Answers
SOURCE: MICROWAVE OVEN NOT HEATING UP FOOD
Will need to pull apart to check....common failure with magnatron fuse....but could be magnatron, capaciter, diode. sugg to have a tech look at....if your not able to check, also call manufacturer, sometimes will cover.
Posted on Jun 10, 2009
tgmusicgirl
  • 92 Answers
SOURCE: my delonghi 800w microwave oven works but does not heat up food
If your handy with getting the cover off and looking inside... check the obvious.
I suspect :
fuse
thermister
relay
If both microwave and Heating elements dont work, then I will assume the magnetron is ok, ans we are dealing with a high voltage issue... and you will need at best... a volt meter and or neon troublelight...
moust appliances have a simple schematic inside... I would start with the heating element first... trace wiring back to circuit board... usually one side of the heating element is connected to the white wire (neutral) and live (Hot) side is controlled thru the circuit board... so finding the neutral should be easy... then trace with neon light or voltmeter...
I know easy for me to say... but with everything else working... it doesnt seem to be the microprocessor that controlls the unit...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
Posted on May 06, 2010
mosekha
  • 23 Answers
SOURCE: My microwave starts however food does not heat up.
Micro wave as the name suggests produces heat when the micro waves aimed at an object causes the water molecules inside the object to vibrate hence producing heat.The gadget responsible is the magnetron. If your magnetron is not receiving ht voltage or receiving but faulty, then your micro wave wont work please take precaution when opening micro wave due to high voltage caps that remain charged sometimes even when it is off.check the high voltage fuse/ diode and capacitor if they are fine and the step up trans former o.k then the only option is to replace the magnetron
Posted on Aug 02, 2010
Frigidaire microwave plate won't turn
The motor for the rotator is bad. It has to be replaced.
May 06, 2013 | Frigidaire Microwave Ovens
Microwave won't start when pressing the start botton
call Chas&son,s appliance repair at 579-379-0993 and they will come out the same day no less okay
Feb 13, 2013 | GE JE2160 Microwave Oven
Feb 13, 2013 | Microwave Ovens
GH7155XHS Microwave control panel
If you do not want to get the newer model due to configuration changes it does not appear that you have another alternative other than to replace the logic board on unit. And unless you can spot a very obvious issue with the board, there is no way for you to fix it especially if it is a bad ic with beaucoup connections to the board.
Mar 24, 2017 | Whirlpool GH7155XHS Microwave Oven
The glass tray in my microwave won't rotate
The turntable motor is defective and must be replaced to remedy the situation.
Apr 04, 2012 | Whirlpool Microwave Ovens
Whirlpool microwave model GT4175SPB-2: sounds like it is running properly but is not heating up
No! by all indicators it is the magnetron and a tricky replacement. The cost to repair should be measured against a new one.
MY MICROWAVE IS NOT HEATING
If the microwave is turned on and you can hear the fan working when you set the time you should make sure of those things:1. You have selected the proper programme. Some microwaves have a control desiged to use the programs on the buttons. if you want to you the buttons to set time you should select "microwave" or a similar button and then press the power level like "1", "2" or "80", "100" (being percentage) and then press the buttons for timing.2. If you have used it for a while and it suddenly stopped heating the food, than it could be that your magnetron (a spare part) has burned out. Have a specialist replace it, or just get a new microwave, the price difference won't be that great for standard issue microwaves.
Feb 25, 2012 | Whirlpool Microwave Ovens
How to switch off Demo Mode in JT 379 Micro? Please, help!
Open the door and then push the start button for 5 seconds till you hear a beep.
Jan 29, 2012 | Whirlpool Microwave Ovens
It is making different kind of noise and won't generate heat.
Most often with MW's the Magnetron fails that as well as the high Voltage Diode. MW's are NOT to be trifled with they are lethal to service and MUST be done by an experienced professional.
The best thing to do is contact Whirlpool, and ask for a referral to an authorised service center, make contact here and when face to face first only ask for a "Quote" as to costings and go from there.
Sep 10, 2011 | Whirlpool GH7155XHS Microwave Oven
Microwave Ovens Logo
309 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
