Where can i purchase a main power board for my LG Model no: 42LC46-ZC
I Need a main power board for my LG TV but struggling to find one the main board part number is Part no EAX32268301/8 i have also provided some other details of TV which are 706WRMHOK251/ Pro Code;42LC46-ZC-AGCVLJG. Please contact me if you can help
    Master:
  • 879 Answers
Contact the authorized service center for LG
Posted on Nov 30, 2012
epik559
  • 44 Answers
SOURCE: code number for sky remote
Call the manufactor of that remote and ask for Funai remote codes.
Posted on Jan 03, 2008
SOURCE: Sky remote code for LG 42LC46 tv
After spending hours on this I found that code 0206 worked on my sky+ remote(with LG 42LC46). On an old sky remote, prior to version 4 (inside the battery compartment), just use 206.
This code was actually for a LG 42PX5D but it works perfectly on my tv.
Posted on Aug 04, 2008
  • 927 Answers
SOURCE: Which Replacement Power Board for LNT4665F Samsung LCD TV?
Howdy,
It would be a lot cheaper if you just replace the two caps that have gone bad. Just get a cheap solder pencil from the store and about an inch of solder and you are in business.
The Power Supply Board is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thaks for using FIXYA, BIG IRISH.
Posted on Jan 02, 2010
  • 16 Answers
SOURCE: Tv wont turn on
Replaced two N-Channel Mosfet transistors(FQPF13N50CF-ND) and some faulty electrolytic caps in the power supply. I found the Mosfets online at Digi-Key. Mosfets are difficult to read. Only one read bad but I replaced both because they are in the same circuit. Set works great now.
Posted on Mar 30, 2010
SOURCE: If anyone is in need of Polaroid lcd tv parts contact me
usually capacitors are the problem on the TDA03211c power supply. 450v (volts) @ 10uf. change both. beside inverter filters.
Posted on Mar 31, 2010
My TV backlight started to get dim and splotchy a few weeks before it failed. Do I only need to replace the LED backlight strips on my LG TV?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Nov 05, 2016 | LG Televison & Video
LG 42LC46 wont show any hdmi input for more than 3 mins
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary
Feb 16, 2016 | LG Televison & Video
42lc46 zc
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Mar 26, 2014 | LG Televison & Video
I've been having a few problems with my LG
Good morning to you! When the screen goes black, have you tried to go into setup on the remote. Adjust the brightness of the screen. Or as I am sure you have done to restart the TV when the warning sign comes on the screen that the TV will go off affter 5 min. The classical action is to disconnect both the router and the box that keeps all the stations in it. Disconnect for 2-3 minutes, connect again. I do apologize for not knowing the name in English. ( english is not my mothertounge) Hope this can help you on the way. Then there is always the user manual that can be downloaded free and look in the troubleshooting page. ( I did that the other day, had lost the paper onr) Kolbrun
Sep 18, 2013 | Televison & Video
Need a power supply for an lg 42lc46 lcd tv
mine is a 42ld450ua with a cracked screen works and i need a screen so what will you do whith it if you can not find a power supply. you can try shop jimmy for that ps.
May 30, 2012 | LG Televison & Video
42lc46 int no picture but sound I have repaced faulty caps and resoldered dry joints
Its most likely a mainboard problem, it could have been the power supply capacitor failure caused damage further down the line. I usually start with the power supply to when i repair them, but then if they have video problems i try to locate another mainboard to swap in, troubleshooting the mainboard without schematics and one off components that can't be purchased because they are proprietary makes for a hard repair.
Jan 01, 2018 | LG Televison & Video
Model 42lc46. 42 inch lcd tv will not turn. Seem to be getting no power at all. Tried everything I can think off. Any suggestions??
Hello jendavies59,
Welcome, and thank you for using FixYa!
To answer your question: Your issue is with the Power Supply Board within the TV.
Eitehr the Power Supply Board will need to be removed, and examined for burned out (Bulging) capacitors; or you can just have the board professionaly replaced.
I have included a link, below, to show you what the board looks like. You may also order one from there, but be mindful, it is over-seas, in Europe.
Power Supply Board
http://www.lcdtvparts.co.uk/index.php?main_page=product_info&cPath=15_99&products_id=1493
Have a great day!
Sep 19, 2011 | Televison & Video
Please i need urgent help Tab, caps lock, 1... not working button Y = HY button H = HY button C = ZC Button Z = ZC
go to ebay put model number in search ... buy new key board easy to fit too. and cheap...
Feb 27, 2011 | LG Computers & Internet
LG 42LC46 ZC AECVLJG about 6 years old, we r having trouble switching it on. There is no red light on or sometimes it flashes on and off, usually it has been a good set. we r with sky and HD, ca
The most likely cause of this problem is the power board.
Take the cover off, make two-three good high-resolution up-close shots from different angles and send them so we can tell you if there are visible issues with it.
For more detailed troubleshooting you'll need a voltemeter and tons of patience.
http://www.coppelltvrepair.com
Oct 15, 2010 | LG Televison & Video
Jan 14, 2008 | LG 42PX5D 42 in. Plasma HDTV
Televison & Video Logo
234 people viewed this question
Top Televison & Video Experts
