Question about Brother MFC-5840CN All-In-One InkJet Printer
Faxing and or copying a black streak developes, answer??
How do I get rid of streak only when faxing or copying, not when printing from Web.
    Genius:
  • 2,120 Answers
Open up the document feeder by pulling up and clean the scanner glass
Posted on Jan 11, 2009
  • Flipper VonVeiner
    Flipper VonVeiner Jul 20, 2014
    Don't forget the thin strip of glass on the left hand side -- that's the only part of the glass that gets used if you are using the ADF
How do I fix this
Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans
support.hp.com/us-en/document/c02881567
Figure : Sample output with vertical colored bands or lines ... Remove any paper from the automatic document feeder (ADF) tray. ... To protect the scanner, do not spray the glass cleaner directly on the glass. .... determine if your printer is still under warranty, and then Contact HP Support to schedule a repair or replacement.
How to get rid of lines on a copied page - YouTube
? 2:10
https://www.youtube.com/watch?v=xTJpCg5sHl0
Feb 17, 2010 - Uploaded by Wayne Springer
When you make copies on your copy machine, does it ever leave a black vertical line ... QLS ' How to Eliminate Vertical Linesfrom Scans, Copies & Faxes ... Part 2- Fix or repair color laser printer with fading, light print, or lines ...
Dec 29, 2015 | Office Equipment & Supplies
Dried-out white-out causing black streaks when printing or sending docs
If you said what your unit was (make, model year, etc.), I did not see it. So, what is it?
Is your device also a copier? If so, and you make a copy of a BLACK sheet, what does the copy look like?
Apr 18, 2017 | Brother Personal FAX-190
My brother MFC 8500 is receiving alright but everything I send out has a big black streak going down the right side of the page. Confirmation page also has big black streak.
Let me see if I got this right.
The received fax is clean but when you send one out it has a black streak on it.
Cool! So far so good.
Makes sense because for sending, the fax scans the original document and parts of the scanning area could be dirty and so on. Therefore a black streak may appear.
The same black streak would also appear when you make a copy, because the original document must also be scanned.
Logical!
However for receiving faxes, the machine uses the internal memory and the print engine only, and the same applies to printing the transaction report, which comes from inside via the print engine.
The scanner has no rol in either situation.
Now I'm lost!
May 31, 2011 | Brother Office Equipment & Supplies
Hi, I have a black line that runs from top to bottom of the page when scanning, faxing and copying. How do I fix this issue?
the blcak line that runs from top to bottom is due to a dirty misaligned print head...do a full printer maintenance on your printer/scanner . Once the heads and rollers get clean and the printer is aligned, it should get rid of any black streaks or lines. I own a Brother Printer/scanner and it did the same thing to me, as soon as I ran maintenance on it..it fixed the black straks and lines I had on my prints.
Jun 18, 2010 | Brother MFC-9420CN All-In-One Laser...
My color copies have a black streak on the front and back of each copy. What can I do.
i have an lexmark 6500 all in one copier. If I print from the computer the copies are o.k., however, if I print a copy from the copier the copies have a black streak on them. How do I get rid of the streak on my copies
Nov 11, 2009 | Epson Aculaser C1100 Printer
Papers come out with black streeks on them from my sharp FO 4450
If everything is coming out with streaks, it's most likely your cleaning blade which is part of the drum cartridge. I've also seen this from 3rd party toner. Get Sharp toner for your Sharp fax if you don't have it already. If your black streaks are only on copies and sent faxes, this indicates that your scanner is dirty. It's located where you feed your paper in. Lift this part up and you'll see a strip of glass running front to back about 1/2 inch wide. Clean it and that will get rid of lines.
Oct 12, 2009 | Sharp FO-4400 Fax
I have a black streak all on one side when i copy ?
If it is just when you copy and not when you print then it is a cleaning issue. Toner cartridge would cause the line to appear on copies, printouts and faxes. There is a piece of glass inside the auto document feeder that is probably dirty. Open up the document feeder as if you were clearing an original document jam. Look for a piece of glass inside the ADF, it will run the length of the document feeder. There is probably some dirt or another popular problem is white out. Clean off the glass with glass cleaner or alcohol and it should fix the problem.
Oct 04, 2009 | Brother IntelliFAX 4100 Laser Fax
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
Dirty copies.
Does this streaking problem occur when printing (not copying)? If it does then you are probably looking at a consumable issue. Alot of times black streaking is caused by a defective or spent drum. Is your drum new? There is also a blue piece on the drum unit used to clean the corona wire that cleans the drum. Have you tried moving it back and forth several times?
If the problem only happens when copying and the streaks are as bad as you make them out to be then you problem have a bad CIS unit (scans your originals for faxing or copying)
Inkworks
866-381-0541
Nov 21, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother MFC-5840CN All-In-One InkJet Printer Logo
123 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
