Question about Brother MFC9320CW All-In-One Printer
Replace pf kit mfc 9320cw - Brother MFC9320CW All-In-One Printer
  • 215 Answers
SOURCE: Replace the PF KIT 1 On my MFC 8460 N
that refers to the automatic feed. in other words, your main paper cassette. the MP kit is for the manual bypass tray. if paper is feeding ok and your not having problems, you can reset the message by pressing "menu" " *2864" within 2 secs. now you are in maintenance mode. push "88" should show "parts replacement." using arrow buttons go to reset pf1 kit and press "ok" or "start" to reset. press "stop/clear" to back out to maintenance mode screen. press "99" to exit maint. mode. do not mess with any other settings in that mode as you could render your machine inop. however, you may want to reset the "fuser life" while you are in maintenance mode "88" as both of these messages are supposed to come up at 100,000 pages. chances are unless you've had fuser replaced, that message will be coming up soon also.
good luck,
razors
Posted on Mar 27, 2009
komguy
  • 2306 Answers
SOURCE: pf kit 1
Brothermall.com has all the Brother accessories.
Posted on Aug 20, 2009
SOURCE: Resetting "Replace PF Kit 1" message
Same with me on my MFC 8870DW. The procedure worked perfectly:
1) Turn off printer
2) Press and hold menu button and turn on. Keep holding button until you see maintenance on display.
3) Press 88. This brings up parts replacement menu.
4) Press Up arrow until you see the part you replaced (laser, fuser, pf kit1, pf kit mp).
5) Press the OK button.
6) Power off and restart printer.
But how do I know whether or not I really NEED to replace a PF Kit1? I guess I'll find out if it recurs soon.
Joe
Posted on Feb 08, 2010
  • 518 Answers
SOURCE: the 7050 brother machine comes up with pf kit
the manual has the prosedure
Posted on Jul 07, 2010
angelo_mlc
  • 1035 Answers
SOURCE: how to reset brother mfc
Hi. Here's the procedure.
1) Turn off printer
Posted on Oct 23, 2010
How to reset pf kit mp of brother mfc-8460n?
Hello ,
First you have to enter in service mode , then to go to reset menu , and reset pf kit mp an then to live service mode
1. Service mode : menu*2864 , you have to make it fast until the lcd is on : maintenance mode
2. reset menu 88 , now you have to go to pf kit mp and reset
3. Live service menu with 99 or shut down the mfp and after 10 sec restart
Mar 03, 2016 | Brother MFC-8460N All-In-One Printer
Message reads "Replace PF Kit" but everything is working fine. Is this an error and if so, how do I clear it??
The PF kit has life expectancy, if everything works fine just reset its counter.
Press "3 & 9" together, select the desired parts counter reset.
Aug 19, 2014 | Brother MFC-9320CW Color Laser Printer -...
Brother MFC-9320cw printer has stopped printing because it is at 50,000 sheets fed & says it needs to 'Replace PF (print feed) kit'. It was feeding just fine. Brother says I have to go to an aut
(1) Open the printer and wait for the carriage to slide over. If for some reason it does not follow these instructions:
(a) Unplug the printer
(b) Manually slide the carriage over until you can get the ink cartridges out.
(2) Remove the ink cartridges from the print head.
(3) Use cotton swabs dipped in hot water or a mix of hot water and isopropyl alcohol to thoroughly clean the print head.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now
If that does not work then you have one of two possibilities:
(1) One of the ink cartridges is defective and causing the error
(2) If it's definitely not that, then the print head will need to be replaced.
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For Brother Printer Support
Apr 18, 2014 | Brother MFC9320CW All-In-One Printer
Need to know how to replace my cartridge
Replacing the toner cartridge is an easy task.
Check out this link and replace your toner cartridges by yourself.
May 16, 2012 | Brother MFC-9320CW Color Laser Printer -...
What is a PF Kit 1?
hi
PF Kit 1, is the Paper Feeding Kit, number one.
http://www.retrevo.com/support/Brother-MFC-8460N-Multifunction-Printers-manual/id/260ag208/t/2/
User manual above.Below is your service and repair manual.
www.scribd.com/.../BROTHER-MFC8460n-Series-Service-Manual
Below is what the kit is for another type of printer to give you the idea.
Oct 08, 2010 | Brother MFC-8460N All-In-One Printer
It says to replace the PF Kit 1 what is that?
solutions.brother.com/Library/pdf/pfkit_hl6050.pdf
Aug 04, 2010 | Brother MFC-8460N Laser Printer
REPLACE PF KIT1
THIS IS HOW YOU WILL RESOLVE YOUR ISSUE OF REPLACE PF KIT1 ON UR Brother MFC-8460N All-In-One Printer
1) Turn off printer
THIS WILL DEFINATELY RESOLVE THE ISSUE
REPLACE PF KIT1 : THIS IS IN REGARDS TO THE MAINTENACE DISPLAY THAT YOU HAVE ON YOUR PRINTER
TAKE CARE AND HAVE A NICE DAY..
Jun 22, 2010 | Brother MFC-8460N All-In-One Printer
1) Turn off printer
Joe
Jun 18, 2008 | Brother MFC-8460N Laser Printer
Brother MFC9320CW All-In-One Printer Logo
514 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
