Question about Adobe Acrobat Professional 7.0 for PC
HP7210 scanner won't recognize computer
It is on a wireless in home network, I am able to print and fax just not scan.
  • 4,350 Answers
In a wireless setup, the printer needs to be installed on each machine, exactly as you would to have the printer hooked to that machine.
Follow the directions exactly, from the install program provided free from HP.
Posted on Nov 30, 2012
How do I install connect fax and scanner to my computer
There are a minimum of 3 cords:
power
phone
computer (likely USB)
Power to the wall.
Phone to a phone line.
USB cable to the computer.
Computer should recognize the machine is there. Load software.
Sep 11, 2014 | Copystar REFURB HP Office jet 6500...
Won't scan, error message -scanner door is open
Simple solution. I just had the same problem. Make sure the top cover on the left side is snapped in. It wasn't obvious that it was open. They should probably give a better code because it is not the scanner door that is open.
Apr 16, 2013 | Samsung New-scx-3405fw Wireless...
Issues with scanning from Sharp MX2700N after replacing our wireless router.
Driver software wont affect the scanner functions unless its twain via USB. Sharpdesk is weird and thst unit can scan to smb, ftp, and smtp very easy. check DNS settings. Try putting the copier in dhcp mode and let it pull the TCP/IP info from the router again, then set the static address back to what it needs to be. Also turn the firewall in the router off.
Jan 22, 2013 | Sharp Mx-2700n Color Copier / Network...
Can I wirelessly network my hp pec 1350 with a belkin wireless g all in one print server
The Belkin Wireless G All-In-One Print Server lets you easily add an all-in-one printer to your wireless or wired network. It features 802.11g technology that makes sending print jobs faster than ever, and includes a memory buffer that handles your graphic jobs effortlessly. The Print Server is so easy to install that you'll be printing in minutes. Simply connect your Print Server to your Belkin Wireless Router and run the Belkin Easy Installation CD. Next, attach your USB printer to the Print Server and load yourprinter drivers onto your computer. You are now free to print, scan, fax and readcard media* wirelessly from around the home or office. The Print Server also works flawlessly with wired networks through its integrated Ethernet port. Compatible with most USB, network-ready printers, the Wireless G All-In-One Print Server from Belkin delivers even your most data-intensive print jobs with maximum speed and reliability.
*If your all-in-one device has a card-reader slot.
Instructions:http://www.belkin.com/pyramid/documents/external/F1UP0002_EN_QIG.pdf
Nov 21, 2012 | HP Psc 1350 All In One Printer Scanner...
Scanner won't work
Try scanning using our Lexmark Printer Home. To do that, on your computer, click on Start > All Programs > Lexmark > Lexmark Printer Home.
Oct 17, 2012 | Lexmark Prospect Pro205 Wireless...
On my home wireless network, my notebook computer's print jobs go to the correct printer but won't stop printing until it is canceled from the device manager. The PC that is on the network wor
sounds like the print job queue is overloading the wireless network, causing a hang on that side
big print jobs do that even on wired systems might consider adding more printer memory
May 26, 2012 | HP P2035n Laserjet Printer Monochrome
I am having problems making my scanner work - I can't scan a document from the printer/scanner/fax/copier to my laptop
How is the all-in-one connected to your computer? What OS are you using? Did you install the full software, basic drivers or the OS drivers? Are you starting your scan from the computer or the buttons on the all-in-one? Is this a newly installed printer or one that has been used several times with this computer?
The Photosmart C7180 can be used with a USB connection, wired ethernet network, wireless network, bluetooth or PictBridge. For a Mac OS, only the USB connection will work.
If you need the drivers, see http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&dlc=en&lc=en&product=1153754& and select your OS.
If you connected the all-in-one to the computer via a USB connection before installing the software, you may have an OS driver that does not include the scanner driver. Disconnect the USB cable then uninstall the driver. Then install the HP driver. If you do not install the full software, you will not be able to use the buttons on the scanner to launch a scan. You'll have to start the scan from the computer.
If you have the full software, the HP Solution Center is installed. This includes a monitoring program that should run when you start your computer. This listens for the press of a button on the scanner and launches the appropriate part of the HP software. However, you need to set the button destinations in this software first. I recommend manually scanning at least once to set the appropriate resolution and destination folder for your scans. Then in the Solution Center, click Settings, Scan Settings, Button Settings and then Front Panel Scan Buttons. Set these based on your default settings.
If this all-in-one has been working previously, check your connection. Scanning requires bi-directional communication with the computer and can fail even when the printer works. Try a new USB cable and a different port, if you are using that connection. If you are on a network connection, check that the firewall isn't blocking communication. (Temporarily disable the firewall to check.) In Windows, check the Devices and Printers (Win7's name) control panel and check if the scanner is a listed device. Right click on it and check the properties and status. (All-in-ones are often listed twice - as a printer and as a scanner.) HP offers a diagnostic program, http://h10025.www1.hp.com/ewfrf/wc/doclink?lc=en&cc=us&product=1153754&tmp_docname=c02114802 , to check for issues with the scanner.
Try manually scanning with another program than the HP software. Windows includes some options that will acquire scans. XP, Vista and Win7 all include Paint (File > Import from Camera or Scanner > New Scan). Windows7 (and some versions of Vista) include Windows Fax and Scan (click New Scan). If you have the Microsoft Live software, you also have Windows Photo Gallery (works like Paint).
If you are connect the all-in-one to a USB print server, the scanner probably won't work. Try a different type of connection.
If you are using the all-in-one on a network, make sure that the network is up and the printer has an IP address. I've seen routers lose their connection for various reasons. (Rebooting both the modem and router sometimes cures the problem.)
Please add more information on your specific scanner problem and I'll try to provide specific suggestions.
I hope this helps.
Apr 09, 2012 | HP Office Equipment & Supplies
How can I set-up my Lexmark printer wirelessly? I seem to have loss my manual. Help!!!!
Wireless networking your printer or scanner may sound difficult, but newer machines are making it easier to do.
The first step is to get your home wireless network configured properly. Bradley Mitchell, the About.com Guide to Computer Networking, has a fantastic and easy-to-follow primer on networking that's a great place to start.
Microsoft also offers a handy tutorial on wireless-networking basics that will help if you're using Windows. If you're using Vista and running into problems, troubleshooting guide will help.
If you're using Windows 7 and want to share a printer on a home network, follow the links at How to Share a Printer on a Home Network with Windows 7.
Next, learn more about the basics of wireless printing with a primer from Etan Horowitz of the Orlando Sentinel.
If you're trying to use a scanner that doesn't have a network card, you can find some useful software from Remote Scan.
May 28, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
I can't get my HP potosmart C6180 ALL IN ONE PRINTER TO SCAN/COPY OR FAX WITHOUT GETTING A SCANNER FAILURE MESSAGE SAYING UNABLE TO SCAN,COPY OR SEND A FAX
Solved! I now can scan wirelessly throughout my network. I downloaded the drivers for a friends newer HP all-in-one scanner and I can scan. Look for the driver for the 309a series of printers and install it. Complete the install and set up your existing printer. You can now scan, print, fax wirelessly. It includes updated HP apps for these functions that work with OS 10.5. I didn't upgrade to the HP 1.1 drivers through Apple. The file name is: PS_AIO_05_C309a_Net_Full_Mac_WW_102.dmg
May 24, 2011 | HP Photosmart C6180 All-In-One InkJet...
Can I print via my wireless network with HP OfficeJet 6310xi?
Nothing helps. Print servers are capable of connecting a multifunction printer for printing capabilities only. For scanning, you have to connect directly to the Computer or by a Multifunction printer with wireless capabilities.
Jan 15, 2009 | HP OfficeJet 6310 All-in-One Printer...
Adobe Acrobat Professional 7.0 for PC Logo
55 people viewed this question
Top Adobe Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
