Question about Sony Televison & Video
Sony rear proj tv, no picture, menu appears, but in three seperated colors pin cushioned.
Watching TV and the screen went black. I have sound.Came back on and a few minutes later went black again. Shut it off and turned it on with no results. Unplugged it and plugged it back in and tried again with the same results. Tried the menu it comes up, but the colors (RGB) are seperated and the screen appears pincushioned. Anyone have a clue?.
  • crollo3 Dec 22, 2012
    Found the perfect solution. I put it out by the side of the road for pick up.
    Top Expert:
  • Sony Master
  • 14,553 Answers
Best to first if you have not done so---UNPLUG the set for several minutes and plug back to power to see if that fixes it (it does a lot of the time especially if you had a power outage).
Posted on Dec 22, 2012
techman
  • 3130 Answers
SOURCE: Mitsubishi VS-5041 50 Inch Rear Prorjection TV No image but there is sound!
After 11 years???? OMG This set is a tired pup and should be put to reast. My experience with older sets and your complains are all capacitor problems and is only gonna get worse as the first time around repair will take several capacitors to repair. This set has no user serviceable parts inside so you should not attempt a repair suchj as this on your own.. This repair if you decide to go through the first time will be About 300 to 600 bucks the first time and cost will continue to raise till the sets put to sleep. Good luck
Posted on Jun 01, 2006
SOURCE: Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Posted on Jul 19, 2007
  • 1694 Answers
SOURCE: Samsung DLP HLN5065 intermittent shut off and color scrambled display
bad light engine assembly.......
Posted on Oct 24, 2007
  • 87 Answers
SOURCE: Mitsubishi vs 5051 rear projection tv sound but no picture
No video but good audio Mitsubishi VS5051. Check R509 and R 519, 100 ohm resistors located on the main PCB near the flyback transformer. Also bad connections on any of the yokes and the vertical output IC will cause the same problem.
Posted on Nov 05, 2007
SOURCE: TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Posted on Sep 14, 2008
How to repair LG LCD TV 47LG70-UA no picture or sound
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 12, 2016 | LG Televison & Video
My screen went blank but the sound works fine. We were watching TV when the screen went out. The sound stayed on. We still get sound but no picture. Is this worth fixing? If so what is the best way to go...
all in one day my screen started by showing a u look at top and bottom. all three colors kind of separated from each other and therefore made shadows on all the writing and double and triple vision on people and images. then it drawed in from sides and showed some black. then it popped in the back and no picture. the sound then came back on with no picture. so i shut it off and unplugged it. what do i have to get to fix this? thank you, Robert Hopkins
Jan 01, 2011 | Akai PT5598HD 55" Rear Projection...
52'' Projection TV SONY
this is a problem with the convergence chip. you can try to adjust the convergence in the menu settings of the t.v.
pin cushioning will correct the curves, convergence fixes color seperation.
write the number down before changing them, in case you make it worse.
Nov 11, 2009 | Sony Televison & Video
Sony rear projection tv
How long have this tv had it picture bulb,change before for this tv?Longtime usage,picture bulb the first,must change.
Nov 03, 2009 | Sony KP43T75GRAY 43" Rear Projection...
Sony rear proj; kdf 55
If there is no picture but sound is audible then replacing the projection lamp will do otherwise, the TV requires to be diagnosed for any other hardware damages.
Aug 27, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Watching rear projection tv. A flash and picture went away(Black screen) can still hear program. Is there an easy fix. tv is 13 years old
we have a sony rear projection tv and the picture went but sound is still there. Can you give me an idea what it might be.
Aug 13, 2008 | Sony KP-51HW40 51" Rear Projection...
Tv has no pic but has sound
Does it stay black after you turn it on?
if so, your lamp may be blown.
have an experienced person check, just to be sure.
Jul 02, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Sony kp-46s25
It sounds like you are going to need to have the convergence IC's replaced. Not really a hard job, but the job requires the proper tools, soldering skills, and a service manual to get the proper part numbers and to perform convergence alighnment in the service menu after the IC's are replaced. Good Luck
Mar 28, 2007 | Sony KP-46S25 TV
Televison & Video Logo
54 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
