Question about Ricoh SP C221SF Aficio Printer
Enter service mode on xante cxl30 - Ricoh SP C221SF Aficio Printer
Magenta Stained product on a Xante Ilumina
i want to ask few question, are you using correct envelopes for this machine or can you use any type, is the weight of paper like is 20lbs
paper, or is it cheap 99 cents paper.
the port where the color ink is spout or ejector port is issue.
call the manufacture customer care center ask for technical services.
go online to the following sites for more help or informations.
www.ask.com/mfg.name/make/model/
/service/manuals/
/operational/manual/
/troubleshooting/guide/
/FAQ/
/customer/service/telephone#/
Oct 06, 2015 | Xante Ilumina 502 GS Digital Color Press...
How to enter service mode
Sorry my friend but i don't think CL30 has a service mode
Nov 30, 2012 | Xante CL30 HSE Laser Printer
Non paper sense error
1. Power the unit on while holding the Menu Up + Menu Down + Help buttons, and continue to hold them until "System Maintenance" is displayed.
2. Press the Menu Down button until "Diagnostic Mode" is highlighted, and then press the Enter button.
3. Press the Menu Up button until "SWITCH SCAN" is displayed, and press the Enter button.
4. Press the Menu Up button until "REG L/R_DENS_WEIGHT" is displayed, and press the Enter button.
5. 4 Hexadecimal numbers will be displayed. Only look at the 4th number. xxx, xxx, xxx, xxx (example: 09E, 27D, 000, 12C) 6. Adjust the 4th number as close to the desired 12C as possible (acceptable range being: 10E ~ 13E) by rotating the adjustment screw (See illustration below).
May 31, 2012 | Xante Ilumina Digital Color Press Printer
My Xante Accel-a-Writer is not communicating with my macmini. I understand that OSX 10.6 doesn't support appletalk, and have configured the xante as an LPD printer and entered its IP address. The mac...
First, I would recommend that you connect the Xante Accel-a-Writer to a Windows OS computer (xp/vista). Observe if it will function perfectly. This will determine whether you are doing something wrong or if the problem is from the Xante Accel-a-Writer or if they don't support each other.
You can test the Xante Accel-a-Writer on a friends windows OS computer if you don't have one.
Let me know the out come so that I can direct you further.
Good luck.
Oct 19, 2010 | Office Equipment & Supplies
Registration of colors. The magenta and cyan are alittle offset from the black. I can get into registration mode but do not know which keys to hit to adjust.
When you get to registration mode, press enter, then execute will appear, then press enter. Then display will say adjusting. Remember magenta, cyan and yellow register to black. If registration is still bad you need to remove the four drums and transfer belt. To the left you will see a plastic move it to the left and you will see a white plastic with two sensor one at each end. This clear plastic get dirty and then you have bad registration. Clean it with a Q-tip. This two sensors are locate just below the left of the transfer belt, one at each side. This usually get dirty with residue of toner.
Jul 06, 2009 | Xante Ilumina Digital Color Press Printer
Xante 1200, paper jam front. Red light is blinking without a paper jam.
PROBLEM: Paper Jam. XANTE 1200, Tabloid size, B&W, Printer —Red light blinking fast indicating paper jam upfront. If you checked everything, trays, ink cartridge etc., and see no paper jam anywhere, take the top cover off and look inside the (head) for the jammed paper! This printer is problem free. It has given us the best service for many years.
Michael J. Frangos, Baltimore, Md.
Feb 04, 2009 | Xante AW 1200 Laser Printer
Continuous Paper Jamming
I would refer you back to your technician. Xante printers are a more specialized product.
Jul 30, 2008 | Xante Accel-a-Writer Laser Printer
REGARDING ZANTE AW1200 DRIVER
http://xante.com/support/aw1200/
Download from here
Dec 29, 2007 | Xante AW 1200 Laser Printer
Unable to get Xante printer to work
When I send a job to the printer via Ethernet, nothing happens on the printer. I only get a solid red light. Why?
This is an indication of a media size mismatch. Make sure that the correct media size is set on the tray to which you are printing, and try the job again.
(from http://www.xante.com/support/aw1200/)
John
(Xante ASA)
Nov 19, 2007 | Xante AW 1200 Laser Printer
Ricoh SP C221SF Aficio Printer Logo
44 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
