Question about Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher
Everything is clean and still no spinning
For: maytag jetclean plus 2 dishwasher Problem: nothing is clogged or dirty and it seems that the arms are still not spinning. Also suspect a water pressure problem while the hose that is connected is not tangled or obstructed. If there is a schematic diagram of how the pieces are supposed to be installed, it may help me find the problem as well. Thanks in advance, S.B.
  • 6 more comments
  • Lady Kluck Jan 08, 2008
    We have a Maytage Quiet Series 100 model #MDB5600AWQ. It fills with water however it does not spray. Thankfully it drains. What is the problem? I have wiped it out and made sure that there was nothing inside the spray holes. Is there anything we can do? We did not get too many uses out of this yet.
  • Anonymous Jan 21, 2008
    have a maytag quiet series 200. Just stopped spraying. Sounds like it's running, but water just collects in the bottom. Liquid detergent dries on door.
  • nashtone Jan 21, 2008
    have a maytag quiet series 200. fills up in the bottom with water. no spraying. liquid detergent dries on door.
  • Anonymous Feb 09, 2008
    dsbfj dsjk sdfg
  • Musthave Feb 09, 2008
    Maytag Jetclean doesn't spin water out to rinse. Just dries detergent in door and dry cleans dirty dishes grim to dishes. The water pools and drains in bottom. I have cleaned out all additional build up (lime) in spinners and around base spinner. Checked known traps.
  • Anonymous Feb 18, 2008
    no spin and that is it, seems like water pressure is very low Maytag Jetclean Dishwasher quiet Plus, water puimps im and out of the machine, it is hot, the spinner has a small amount of water shooting up a few inches, no water or spin on the top bar at all
  • BullDozer1 Dec 10, 2008
    Seriel number 26311429ex - Dishwasher begins cycle - fills bottom with water and hot but never begins actual cleaning cycle. Seems to go through a series of cycles but cleaning never begins. When finished dishes are not cleaned. All lights are and buttons on the display are apparently functioning.
  • jean_aiton Dec 16, 2008
    Washer will fill up but not push water through arms to actually clean dishes. ????
    President:
  • 1,314 Answers
I need your serial num its important 17
Posted on Jan 04, 2008
SOURCE:
Dishes are`t clean ,arms dont spin during wash cycle
what is the model # how mutch water is in the basin?
Jun 28, 2009 | Dishwashers
Dishes not clean. Lower spray arm possibly not moving.
Remove the lower basket so you can access the lower arm.
Does it spin freely? If not, remove and clean the rotating point. Make sure the spray nozzles are not clogged and there as no chunks of stuff inside the spray arm.
Jan 24, 2009 | Maytag 24 in. MDB8600AW Jetclean II...
Maytag Jetclean problem
Hi!!! 10 years is alot for a dishwasher..You could have a plugged drain pump.Check your drain pump.All make sure that the water inside your dish water is hot inside it should read over 100 plus..Good luck..
Jan 03, 2009 | Maytag MDB9600A Jetclean II Built-in...
No-spin
the spinning of the arms is created by the force of the water shooting out of the holes. your top arm may have debris build up in it that prevents proper water flow. u can also remove the arm and see it there is build up on the contact point were it rotates. clean it if its dirty. "dishwasher magic" is good for cleaning mineral build up in your system. also, make sure your not putting dishes on the top rack that are too tall and prevent the blade from rotating
Dec 01, 2008 | Maytag MDB9600A Jetclean II Built-in...
DISHES ON TOP RACK NOT GETTING CLEAN.
MAYTAG MODEL MDB7160AWB DISHWASHER
fills,starts wash cycle and shuts down about 2 min. into cycle
Nov 12, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Maytag jetclean eq plus dishwasher: soap problem
This could be due to 2 problems: not enough water or water is not being pumped hard enough through the system. The 'not enough water' is easy to check - open the door in the middle of a wash cycle. If you have enough water (about 1" or more) then that is probably ok. The 'not pumping hard enough' could be as simple as plugged up filters and holes in the spray arms. Remove the racks and disassemble the lower spray arm and the filter assembly all the way down past the screen. Clean the arm holes, throughly clean the screen, clean everything. Pull the top spray arm and throughly clean the spray holes there. Put it all together and run a cycle. You should see a pronounced increase in the sound of the water spraying around. This should fix your problem - it did for me.
Mar 11, 2008 | Dishwashers
Maytag jet clean dishwasher model# dwc7400aaw
Normally when you have low water pressure and/or cleaning issues, this an indication of a clog in your main wash pump. You will need to remove the lower spray arm and the coarse screen to get to the main wash pump sump. Inspect the impeller area of the pump. This area is usually where accumulations of debris collect and keep the pump from pulling enough water. Things like orange seeds, lemon seeds, bottle cap liners, chicken bones, and jar labels are just a few of the items I have personally found. Although, dishwashers do a good job at removing most food particles, they are not garbage disposals. I bet you will find a clog in the sump somewhere. Let me know if this helps.
Jul 31, 2007 | Jet Tech Systems STEALTH Dishwasher
Maytag jet clean model#dwc7400aaw
Check to see in you have enough water in tank. The dishwasher fills then recirculates this water under pressure. If you have water in tank, listen to see if motor is running or not. If it is, you may have clogged jet holes in the wash arms.
Jul 31, 2007 | Maytag MDB9600A Jetclean II Built-in...
Maytag Jetclean Super Quite Plus II Dishwasher
open the door when working and check the spray arms are rotating. if not, the jets in the spray arms may be blocked. very fiddly to clear but doable
Apr 07, 2007 | Maytag 24 in. MDB5600A Jetclean II...
Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher Logo
197 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Mike
Marvin
Marvin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
