Question about Welding Tools
Bought a C K Systematics spool gun with a control module (MHG) , looking for manual and wiring diagram.
Control Module has a number stamped on it. GB6-1620 . Maybe someone know who bought out this company or a link to find out more , Thanks,Ray
  • 8 Answers
SOURCE: Not sure how to connect the magnum sg spool gun
Needs to be in dcep, or reverse polarity to weld aluminum
Posted on Aug 12, 2009
  • 53 Answers
SOURCE: Extend cable from control module to bass module?
40' speaker cable for 3·2·1® or CineMate® system $20.00. Why distroy a system. http://www.bose.com/controller?event=VIEW_STATIC_PAGE_EVENT&url=/home_entertainment/theater/systems/surround/cinemate/accessories.jsp#tabs
Posted on Jun 24, 2008
luxur4
  • 92 Answers
SOURCE: need wiring schematic for miller 140 wire feed welder
No problem,email, write or phone for this information, Miller personel are very obliging as are most Welding manufacturers.
Posted on Jan 23, 2009
  • 62 Answers
SOURCE: Control Module WMA34
If my memory serves me well, the plugs/wires will only fit the correct spots on the module, and I believe there is a "jumper" on the original module, make sure you remove and install in the new module..Good Luck
RMK
Retired GE Technican
Posted on May 21, 2009
  • 94 Answers
SOURCE: Please help me i need the Lighting Control Module diagram
http://i28.photobucket.com/albums/c216/thomaspedemon/99lcm1of3.gif
http://i28.photobucket.com/albums/c216/thomaspedemon/99lcm2of3.gif
http://i28.photobucket.com/albums/c216/thomaspedemon/99lcm3of3.gif
follow the three links for complete wiring diagram of lcm
Posted on Jun 30, 2009
Wiring diagram for 2005 grand marquis for rear defroster
Relay maybe . free wiring diagrams here http://www.bbbind.com/free_tsb.html Enter vehicle info. year , make , model an engine size . Under system click Body & accessories ,then under subsystem click on rear window defogger . Click the search button then the blue link .Looking at the diagram you will see three fuse's , a relay ,lighting control module , defroster switch . The switch is a input to the lighting control module , the lighting control module will supply a ground to the control side of the rear window defroster relay ,energizing the relay sending B+ power to the defroster grid.
Sep 28, 2017 | Cars & Trucks
Where is the ecm located on a 92 Plymouth acclaim
NO ECM (engine control module). The skamatic does show PCM powertrain control module. Look under the hood, near the back of the motor. On the frame rail or the fire wall. Power Distribition center (PDC) should be ther as well.
Repair Guides Wiring Diagrams Wiring Diagrams AutoZone com
Mar 08, 2017 | 1992 Plymouth Acclaim
Where can I get the heat control wiring diagram?
How do you know there is no B+ voltage ? Did you check with a volt meter ?
Red with white stripe wire gets power from AIRCON fuse 15amp I/P fuse box.
HVAC Control Module The HVAC control module is a GM LAN device that interfaces between the operator and the HVAC system to maintain air temperature and distribution settings. The battery positive and ignition 1 voltage circuits provide power to the control module. The control module supports the following features:
Is your HVAC manual or automatic ?
Is yours
Nov 26, 2015 | 2008 Saturn VUE
The low beams the windshield wipers rear windshield wipers quit working all the fuses seem to be good everything seems to be proper what's the problem
Well Chuck it depends on the make , model an year vehicle you have ! You would need to look at a wiring diagram to see if these thing's have anything in common . Maybe a electronic control module controls them ! GM vehicles use the BCM - body control module to control these thing's in some vehicles , Ford uses The GEM - generic electronic module or SJB - smart junction box an Chrysler has there modules too ! You can go to www.bbind.com for free wiring diagrams ! click on technical information then TSB'S wiring diagrams ! Good luck
May 14, 2015 | Cars & Trucks
I have 2010 Ford Taurus SHO seats. I believe they are 8 or 10 way memory seats. Trying to retrofit for a street rod. Have a few wiring diagrams but not enough. Can't get power to any motors yet. Numb
Problem Solved !!! I traced every wire, Bought manuals, Ended up buying a passenger seat wiring harness and removed driver memory control module plus harness. Installed new passenger harness and it works great ! You need VIN# when ordering part, Order number is slightly different then number on wire harness but when it came in numbers matched. AU5T 14D230 J4CP7
Nov 15, 2013 | 2010 Ford Taurus SHO
I need a wiring diagram for the ignition control module and distributor cap on a 3.0 V6 motor
Hey Billie,here's a guide to how to replace the ignition control module.Here's what it look's like.Here's the connector.Read this.
Jan 17, 2013 | 1995 Ford Mustang
Looking for wirirng diagram to install my oven control module for Rnage model # 790.95032503.
It seems someone else was having a similar problem on a different website, and the moderators came up with the following page for a wiring diagram for your model number.
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316441458en.pdf
Feb 28, 2011 | Kenmore Kitchen Ranges
I need a schematic to replace the PCM (Powertrain Control Module)in my 1994 Fodr thunderbird 3.8L V6 without/supercharger ..Is this is Big job for a backyard mechanic and how long should it take, my real...
  1. Easy job and should have no problems here some help
    Disconnect the negative battery cable.
  2. Detach the engine control sensor wiring connector from the ignition control module by pressing down on the locking tab where it is stamped PUSH, and remove the connector.
  3. Remove the ignition module and the module bracket from the front fender apron.
  4. Unfasten the two ignition module retaining screws, then remove the ignition module form the module bracket.
To install:
0900c1528006b5b4.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 2: The ignition module on 1994-95 vehicles is mounted on the front fender apron
  1. Install the ignition module onto the module bracket. Tighten the retaining screws to 24-33 inch lbs. (2.7-3.7 Nm).
  2. Position the ignition module and bracket assembly onto the front fender apron. Secure with the retaining bolt and tighten to 35-50 inch lbs. (4-5.6 Nm).
  3. Attach the engine control sensor wiring connector to the ignition module.
  4. Connect the negative battery cable.
Nov 19, 2009 | 1994 Ford Thunderbird
Jun 30, 2009 | 1999 Lincoln Town Car
Welding Tools Logo
279 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
