Question about Sony Bravia Kdl40ex400 40-inch Class Television 1080p Lcd Hdtv
I have a sony kdl40ex400 bravia tv shop said backlight curcuit board is bad theres only 3 boards in the back wich one controlls that curcuit
  • 129 Answers
SOURCE: Sony Bravia TV went Blank
COULD BE LVDS CABLE LOSE OR NOT MAKING A GOOD CONTACT , IF IS NOT THAT UNFORTUNATELY IT WILL BE NECESSARILY TO REPLACE T CON BOARD
YOUR RATING TO MY ANSWER ITS HIGHLY APPRECIATE
THANKS
Posted on Jun 29, 2008
  • 58 Answers
SOURCE: "Upgrade" of Backlight Panel
just replace what failed.
I replace the surface mount FETs on the inverters.
Posted on Dec 06, 2008
  • 453 Answers
SOURCE: Sony Bravia 46S2010 LCD backlight ok , no video
yes it is
Posted on Jun 18, 2009
SOURCE: Sony Bravia television hdmi stopped working
Installing a new software update will this issue. All you need is a compatible USB flash drive. Go to support on Sony.com. Look up your tv model and if there is an update, just follow the instructions to install it yourself. I have a KDL-46S5100 and this worked great. The download and instructions page I used was : http://esupport.sony.com/US/perl/swu-download.pl?upd_id=4769#install
Posted on Oct 10, 2009
  • 28 Answers
SOURCE: Sony Bravia with really bad ghosting
The little board on top attached to panel.
Posted on Jul 05, 2010
Sony Bravia KDL-xbr4 Replaced TCON board All worked great for a week Had an issue w/ HDMI cable at the box fixed it and now tv comes and the goes off to 6 blinking red lights
6 red flashes- backlight issue, bad main board, or power board or inverter boards- check standby volts on power board. "backlight on" volts should be 3-5v from main logic board then 24v to inverter
Have this from a youtube link find BUT
Better is to look first also on bad leaking or bulged capacitors thats better to replace in the bad components to get a repair because active components died on bad capacitors but after a while because on the build-in protection circuit by faults like deformed or leaking capacitors and even several fuse resistors then after replace a complete board again after a while you will may be get the same kind of problems again, take If you find some or much bad capacitors replacements 10 volts dc higher . begin with control on the power supply first of all.
Sony Bravia TV kdl red blinking led light error codes solutions Sony KDL 40XBR4 KDL 40XBR5 KDL 46XBR4 KDL 46XBR5 Service Manual
Jan 05, 2017 | Sony Televison & Video
Sony bravia kdl40ex400 will not turn off but screen is black. what is wrong?
Sounds like corrupted firmware. An update might be necessary. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
Jul 13, 2016 | Sony Bravia Kdl40ex400 40-inch Class...
Sony lcd tv not pwering on
After replacing the main board, a software update should be done. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 16, 2014 | Sony KDL40EX400 40 inch BRAVIA 1080p LCD...
I need to replace a broken screen on a sony bravia kdl40ex400. I have worked on a lot of electronics, but never a tv screen replacement. Can i get the parts myself, and if so, is it changable by me?
Yes - just be careful with the ribbon cables. You are going to be replacing the LCD portion - behind it is the backlight assembly. Some may come with the entire assembly in one. You may need to do a little research to get a replacement - use Google to find a distributor.
Feb 09, 2011 | Sony KDL40EX400 40 in. HD-Ready TV
My Sony Bravia KDL 40EX400 has no sound coming out of TV. If I hook up my surround thru audio reciever I gets sound. Can someone help with this problem?
speakers in tv or wiring going to speakers or in menu someone has muted internal speakers or plug on pcb board has lost connection
Feb 04, 2011 | Sony KDL40EX400 40 in. HD-Ready TV
I just bought a sony kdl40ex400, 40" lcd tv and when i first turned it on the picture quality was poor and there are 2 vertical blue bars running down the screen at all times how do i fix this
The tv Tuner signal board is bad,must be replaced.This tv is new,bought it,under a year old?So this tv is still under warrenty.Call Sony for a warrenty repair.
Oct 16, 2010 | Sony KDL40EX400 40 in. HD-Ready TV
Tv turns on has sound
Have flashes of picture about 30 sec, or so?Than the 2 long LCD inverter boards are dead,have backlight make no difference.Tries to reset the tv back to factory setting by,unplug,replug the tv and cable box back about an hour later,let the tv Tuner board to reset it self,the cable box upgrade it softwares.After this,u still have the same problems,than the Tuner board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy the 2 long refurbishes LCD inverter boards or the Tuner board for the replacement.
Jun 24, 2010 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Power light blinks along with clicking sound
Most likely it going to be a power supply related problem. The red blinking light is a code for a TV tech to diagnose the problem on the power supply board itself or the board that regulates the power for the screen. Some manufactures call it a Backlight Inverter Board. A TV repair shop should be able to look at it for you and tell you which board is bad.
Replacement boards can be found at a good price at Shopjimmy.com
Sep 05, 2009 | Sony Bravia KDL-42V4100 42 in. LCD TV
I have a Sony KDL-40V2500 LCD 1080P TV there is no picture the
A 4 flash shutdown indicates a backlight problem. It can be acused by a bad backlight inverter board (the backlight power supply) or by a defective backlight in the panel. There are fuses on the backlight inverter board called "picofuses" which will need to be checked in order to isolate the problem to the board or the panel. If the fuses are good, you have to replace the panel (very expensive!). If the fuses are opne, most likely the back light inverter board has failed.
Nov 25, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony Bravia Kdl40ex400 40-inch Class Television 1080p Lcd Hdtv Logo
51 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
