A blue screen comes when windows installation start 0x0000007B
When start the installation of window xp then first loading all files when setup is detecting the hdd then blue screen comes i change the all the parts even ram, processor, hdd, cable, smps but problem is still
  • takshakchand
    takshakchand Nov 30, 2012
    run chkdsk/f error of blue screen
  • 27,725 Answers
BSOD Bluescreen of death can be caused by a number of things
If the PSU power supply units fan is not working the PSU is faulty
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
A bad or faulty motherboard data lead or its connection if its a flat 40 pin ide it will be the first to fail
make sure all leads have a dust free secure connections
A bad driver loose or faulty lead or not having enough ram or the RAM modules might be dirty.
Might be getting hot
Check you CPU make sure its securely seated and has thermal grease
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
Remove the memory modules from their slots.
Take the opportunity to clean the slots on the motherboards and the memory module connectors.
Use compressed air to blow dust away and clean contacts with a soft cloth.
Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components.
Then reseat the modules.
You should hear an audible click when they are in place.
Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard.
You might not have enough RAM random access memory not having enough will cause your computer to run over its maximum limits and can cause the blue screen of death and hang and cause memory dumps
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to
compatible ram also you will have an option to scan your system
you should always ask the seller if they guarantee the compatability of the ram before making any purchase
if you dont want to install more ram uninstall some unnecessary programs
make sure your ram modules have a dust free secure seating and the CPU central processing unit has thermal paste
If eventually you can get a screen
Click start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver.
If you computer came with a motherboard disk the drivers could be on it
or you might have to download one.
or it might be a virus right click in bottom toolbar select task manager applications to see what is running and processes to see what is ticking over.
http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information
malware protection
http://100-downloads.com/download.php?p=615
windows xp microsoft security essentials
http://100-downloads.com/download.php?p=614
windows 7 microsoft security essentials
Hope this helps.
Posted on Dec 02, 2012
SOURCE: can't install xp
you first should tell me which blue screen and what does it says, any way try another cd or version.
Posted on Aug 05, 2008
SOURCE: Win XP Service Pack 2
-TRY TO CHANGE THE CD\DVD-ROM AND THE DATA CABLE
Posted on Nov 07, 2007
joey64
  • 209 Answers
SOURCE: msi 478 socket mother board
to: pubudu,
you said that your ram is ok, but i think it's the ram which is your problem because of memory dumping with color blue. yes your ramis ok but the reason why not ok is because the latency is not compatible with your settings in bios
Posted on Dec 01, 2007
colliewob
  • 781 Answers
SOURCE: Help !!!! BLUE SCREEN While Installing Windows Xp
This is a long shot but set your BIOS to default and try
I have installed windows XP on machines with only 256MB ram had to change disk a few times but got it done
Your should have sufficient ram not to I think you have a M/board conflict try removing everything except what you need to install windows
Posted on Sep 29, 2008
SOURCE: Problem with DG31PR board while loading windows 2003 server.
you can use 2003 server service pack 2 &fix this problem
Posted on Dec 20, 2009
Encountering the Error STOP 0x0000007B when Installing Windows XP on Optiplex gx270. Error occurs when Setup starts loading Windows Setup Files.
That error is a boot device error and you need to check the BIOS to see what is listed for hard drives and other devices and see if AHCI is enabled etc.
Oct 27, 2017 | The Computers & Internet
I want to install windows xp on dell inspiron mini 1018 but i am not able to install.some blue screen comes.please help
turn off your antivirus before you try to revert back to xp. your system antivirus might see this as an attack on your windows 7,thus it won't allow you to install a different system.
Feb 25, 2012 | Dell Inspiron Mini 10 Netbook
When i start win xp setup from wintousb software bcz i want to install win by usb after loading win files it gives blue death screen technical info:...
try going into the system setup or bios screen and see if you can find a setting for SATA Operation or SATA Mode for the hard drive. if you can find this, select ATA or AHCI and test the installation again. hope this helps.
Apr 16, 2011 | Computers & Internet
BOOTMGR is missing Ctrl + ALT + DEL I have ADVENT Notebook I have connected up A disk Drive via USB I have booted up with XP Home Edition it starts to load files then the Blue screen pops up to say that ''...
this error can come if ur pc doesnt supports windows version thats why i recommend u to change the version of windows u r installing.
if this doesnt work then mail me at aquif@in.com ,bcoz the next technique is much more advanced.
Mar 29, 2010 | Computers & Internet
Error while trying to install windows xp Stop: 0x0000007B on a dell Optiplex sx270
The most popular Blue Screen of Death error in Windows is the STOP 0x0000007B error, sometimes called the 0x7b error or the "INACCESSIBLE BOOT DEVICE" BSOD.
This BSOD (which is actually the common name for a STOP Error) could mean that there's a serious hardware problem with a hard drive controller, a driver issue, or even a boot sector virus.
In your case though, this is most likely one of 4 capacitors that are known to blow out on any SX270. Slide the bar at the back of your PC to the remove cover side and look inside for swollen caps. Remove the fans and cpu cover as well and check around there. Replace any bad ones you can find with old caps borrowed from an old motherboard if you have one, or new ones from any decent electronics parts warehouse. This fix has worked for me on every SX270 I have ever had.
Mar 10, 2010 | Dell OptiPlex SX270 PC Desktop
I bought lenovo G550 last week. It came with Windows Vista. I want to install Windows XP on it. I have found that lenovo has driver for windows XP so that will make my life easy :-) But when I try to...
you are most likely getting a BSOD with a stop error code of 0x0000007B which is caused by the Windows XP CD that you are using doesn't have the SATA Hard Drive controller driver needed to recognize and utilize the hard drive. If Lenovo has XP drivers for this model then they should have a SATA driver (roughly 394k) that will need to be loaded FROM A FLOPPY DISKETTE during the boot to XP. (XP Requires the driver to either be slipstreamed into the CD or loaded from a floppy diskette. Trying to load the controller driver USB or a different CD will not work)
http://www.digitgeek.com/how-to-slipstream-sata-drivers-into-xp-cd/
Jan 11, 2010 | Computers & Internet
Stop:0x0000007B tried to boot in all modes..we go to blue screen with stop: cannot get a command prompt either
Issue : Blue screen with Error0x0000007B
Solution
I recognize the importance of resolving this issue and I look forward in providing you with the necessary assistance you need.
The above error comes if the boot volume is corrupted and cannot be initiated by Windows XP. or You are installing Windows XP on a mirrored boot partition that was created by Microsoft Windows NT 4.0.
To completely resolve your issue i think you have to reinstall the OS.
Have to format the Hard drive
requirement
the OS - XP Home / Premium Installation CD
Disk formatting is the initial part of the process for preparing a hard disk or other storage medium for its first use. The disk formatting includes setting up an empty file system. A disk formatting may setup multiple file systems by formatting partitions for each file system.
Check this following Video Link
Help you with uninstall and reinstall the XP
Jan 03, 2010 | Dell Microsoft Windows XP Home Edition
I hav a laptop cq60-104tu. i want to install xp on it but it gives an error message. what should i do???
Go to the bios and change the SATA into ATA before installing window xp. You will find this option under hard disk type.
Sep 25, 2009 | Computers & Internet
Os loading
go to the bios , change the hard disk support from native to legacy
Oct 31, 2008 | Compaq Presario Notebook
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
