Can i install windows xp on Laptop Hp 630
I want to install Windows Xp on this laptop. is this possible ?? how ??
  • michelmhanna
    michelmhanna Dec 07, 2012
    Unfortunately No , because i have the method to install XP but I want to buy New Laptop that accept XP as operating System. is this laptop Accept winXP?
    Problem Solver:
  • 6 Answers
I'm quite sure you can install windows xp on your current laptop, but computer specifications do matter. Anyway, this is how you would do it:
1) Insert the windows xp cd or dvd and restart your computer.
2) When starting up your computer, you should get a screen with the manufactorer's logo. There usually is a bit of text in one of the corners of the screen that sais which key to press to go to the "boot menu" (unless you're on an apple computer at the moment, in that case google for "Boot Camp windows xp".)
3) Press this key while you see the screen mentioned above, and you will see a menu in which you'll have to navigate with the arrow keys.
4) As this is different for various manufacturers, look around in the menu a bit until you find something along the lines of "boot from cd"
5) Make sure you activate this, and restart your computer.
6) Now your computer should start up from the windows xp CD.
7) Follow the instructions of the installation.
8) Repeat step 2-4 and deactivate the boot from cd.
9) Done. You should have windows xp installed on your machine.
Posted on Nov 30, 2012
  • 5 Answers
SOURCE: how to install XP in toshiba Satellite L45-S7423 laptop
I found it!!!>>>
Just go to Toshiba support web site Download the Storage Manager Driver for XP 32 then have an External floppy drive with formatted Disk ,install the drivers Files in the floppy connect the floppy drive put the XP sys CD Boot from the CD as in Solution #1 or by press on F12 tell choices boot screen popup select the CD then after that when the third party appear press F6 to chose the Driver for HDD to get recognized by the system. J
Posted on Apr 14, 2008
  • 33 Answers
SOURCE: i want to install windows xp sp2
It's a relatively simply procedure, 1st download all of the necessary drivers for your laptop from Compaq's website under the support section. You'll want the drivers for Window's XP. Either burn these drivers to a CD or place them on a flash drive. Also if you already have documents or data on the laptop that you would like to keep you'll need to back that up as well to either a CD/DVD or a flash drive.
Next you'll need a Windows XP installer disk. Place the disk in your laptop and reboot. The system should prompt you, asking you if you'd like to boot off of the CD press any key. Hit any key and the computer should boot from the XP CD. The system will take a while as it loads up the installer shell. If the system does not boot from the CD you will need to go into the BIOS or CMOS and change the boot order for the computer to make the CDROM or DVD ROM the 1st boot device. The 1st prompt on the installer should be a license agreement, hit F8 to continue. The next steps will pretty much be up to you. Things like where you want to install windows XP, do you want to format the drive, etc. This sounds like your 1st install so you may want to leave everything as default. Windows should detect your Vista install and by default install it as a seperate installation allowing you to boot into either OS.
After the OS has prepared the hard disk and copied all files the computer will reboot and will boot into a installer kernel and will prompt you for even more selections. This process will take longer than the initial portion and most of these settings you can leave at default as well. When this part is complete the system will reboot again and your installation of XP should be complete.
When the system boots into windows it will ask you to create a user name, create a user name or multiple ones. Put in your driver CD or flash drive and proceed to restore your files and install your drivers. That's the revised version of it anyway.
Good Luck!
Posted on Jul 10, 2008
  • 2692 Answers
SOURCE: how to install windows xp sp2 on hp 530 laptop
Place cd into drive.Keep pressing enter until the computer reads the cd.Follow the directions on the screen. That is all their is too it. How did you get an HP without an operating system having been installed? thsi is a windows disk, correct? Not a reinstall disk?Should work the same either way.  If it gives yuo an error or doesn;t work please tell us what happened and we will direct you more. Thanks
http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=3375953&submit.y=2&submit.x=7〈=en&cc=us
Posted on Jan 19, 2009
  • 2692 Answers
SOURCE: how to install windows xp in presario c700?
First download all of the Xp drivers , unless you have then on a disk already. (Link provided below) Next:   Insert the windows Xp disk into the cd driver. When it says ;"OS system found do you want to repair it?" or anythng else say No. If will say reformat driver? Say Yes. Let it run giving it all the information requested  including the registeration numbers that came with the Win Xp disk when you bought the disk by itself.  Install all of the drivers,one at a time .
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&product=3632144〈=en
Posted on Feb 28, 2009
s_4u_11
  • 535 Answers
SOURCE: I can't instal Windows Xp for my laptop Toshiba Satellite L310
because of that u have sata hdd in your laptop you have install sata driver in your laptop and try to install windows xp or use the windows xp darkl edition to install in your pc
Posted on Nov 14, 2009
Hp 650
You need the Recovery CD for your model HP laptop or a Windows XP installation CD plus the product installation code.
The product installation code is printed on the Windows XP label that is attached to the bottom of your laptop.
Feb 26, 2013 | HP 650 Notebook PC
Unable to connect windows xp and windows 7 using crossover cable.
Your laptop ip address setting is correct now there is reason not able to ping windows xp and windows 7 have firewall you need to enable file sharing form windows firewall. Go to control penal > windows firewall > advanced settings > inbound rules and enable file and printer sharing.
Jun 15, 2012 | HEWLETT-PACKARD HP 630/P6200 Notebook
Hp 110-3030NR just bought used, wants a password , will not boot without it, don't know where the f keys are, so can't get to safe mode
Here I collect some popular solutions to help reset HP laptop password if your laptop installed Windows system such as Windows 7/Vista/XP.
Solution 1 Reset HP laptop password by another user account with administrator privilege.
Solution 2 Reset HP laptop password with Offline Windows Password & Registry Editor.
Solution 3 Reset HP password with professional password recovery tool.
If you do not have another administrator account on HP laptop or you have little experience in Windows or LUNIX operations, you can use Windows Password Rescuer to help reset HP password without lose date. This software was provided by DAOSSOFT corperation, it supports HP laptop password recovery in Windows 7/Vista/XP and HP computer installed Windows 7/Vista/XP/2008/2003/2000.
http://www.daossoft.com/knowledge/how-to-reset-hp-password-hp-laptop-password-recovery.html
Sep 18, 2011 | HEWLETT-PACKARD HP Mini 1103030NR Netbook
How to instal xp on compaq presario v3500 laptop.
get the cd xp installer, reboot your machine when appear press any key to install windows press any key and fallow the instructions thqt appear there on screen
Aug 01, 2010 | HP Compaq Presario V3000T Notebook
Respect sir, i have bought your dv41124 nr laptop. in my laptop your hp member should be installed vista. but i don't know about vista family and i easily known about windows xp system. so, i want change...
Yes you can downgrade the Operating System to XP. After installing for drivers you need to download it from web Click Here to Download
Thanks & Regards
Nanda kishore.
Jun 09, 2009 | HP Pavilion dv6000z Notebook
How to install windows xp in hp pavilion dv4-1125nr series???
You should install Windows XP that came with your computer with the recovery program that is built-in with an HP computer. The Windows that comes with your computer includes all the drivers and software needed specifically for an HP Laptop.
Here's a link to HP's website outlining all the ways to Recover your Laptop and reinstall your Windows XP Operating System back to factory default including how to create a set of your own Recovery Disks:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00608578&cc=us&lc=en&dlc=en
Feb 01, 2009 | HP Pavilion dv4000 Notebook
Widows XP
(1) go to Hp.com - load load the necessary Xp drivers for your unit - burn them to cd - then aquire a replacement hdd - install Xp on that - install the required drivers and walla you have one hdd with vista and another with XP
Jan 21, 2009 | HP Compaq 6720s PC Notebook
Installing windows xp to compaq presario 700 pc notebook
HP Compaq Presario 700 series was originally designed for XP and Vista, therefore you can install XP on it.
After installing Windows XP, you will need to install all drivers.
You can download drivers and software for your laptop from HP here.
Oct 07, 2008 | Compaq Presario 700 470024-192 Notebook
How to install XP in toshiba Satellite L45-S7423 laptop
You cannot uninstall Windows Vista, but you can reinstall your previous operating system, which then replaces Windows Vista. To reinstall your old operating system, you must have the original installation disc. Back up your programs and files, insert the installation disc into your computer, and then reinstall the old operating system. To regain the hard disk space used by Windows Vista, reformat the disk during the reinstallation process. After reinstalling your previous operating system, reinstall your programs and files.
Feb 29, 2008 | Microsoft Windows XP Professional
Sounddriver for hp dv2401tu model
if u have sound driver problem in hp dv2401tu then insttal- hp dv2224ea modal audio driver after install uaa bus driver.ok
brijesh ameta
Oct 29, 2007 | Computers & Internet
Computers & Internet Logo
125 people viewed this question
David Payne
David Payne
