I got n150 notebook.1 day later i installed win xp and i again installed win 7 but this it says no free space while disk is formatted. My hd is 250 gb.
  • 2,878 Answers
It may be partitioned. Try Start > Run (aka Search in Win 7) type dskmgmt.msc. Look for your drive there. Right clicking will give you the options of initializing, creating disc partitions, assigning logical drives, and formatting. If this seems a little daunting. A wizard should load. If not there is refresh icon on the toolbar.
Posted on Nov 30, 2012
5 Suggested Answers
Beni S-P
  • 1006 Answers
SOURCE: Xp hangs and pc stop responding during Xp installation.
Location off viruses is on SYSTEM RECOVERY and it can't be cleaned.It's just one way:
If u can change the PIN off HDD.It can do just programmer!
So my solution is just buy new hdd
Posted on Nov 24, 2007
  • 50 Answers
SOURCE: Gateway MX6421 Notebook hard disk problem
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
21
Posted on Jul 25, 2009
male_28_cam
  • 1555 Answers
SOURCE: VISTA Acer Laptop (My Boss's) - Replace it with XP - Help Fast
Well just yesterday i removed vista from a lenavo desktop. When i tried with the installation cd setup it didn't allow and got a lot of beep error from the desktop. Then I got a partition manager formatted c drive and then booted through a dos bootable cd which keeps the drivers and command files in ram and then inserted xp os cd and through command prompt started the xp setup by typing d:enter d:dir (got the list of files and folders then typed d:setup and xp setup started and installed later I got all the relevant drivers from the net. Its not easy to get drivers from net.
Posted on Nov 11, 2009
Current009
  • 135 Answers
SOURCE: xp installation problem
“No Hard Disk” error displayed on XP install (SATA drive versus ATA/IDE drive) The two most most popular types of hard drives in personal computers are ATA (also known as IDE hard drive) and SATA hard drives. Many newer computers have SATA hard drives installed, but your computer may have either an (older design) ATA/IDE hard drive or a (newer design) SATA hard drive installed.
After removing Vista, when you reboot your computer, a “No Hard Disk” error may be displayed if your computer has a SATA drive installed. To fix the “No Hard Disk” error, you may need configure your computer’s BIOS settings so that it can recognize the SATA drive installed in you computer. Reconfiguring your BIOS is typically not required if your computer has an ATA/IDE hard drives installed.
Step 1: Activate your computer’s BIOS menu. The first or second screen your computer displays on status may display which key (or keys) you must press to activate your computer’s BIOS menu. You can also look in the index of your computer’s manual for “BIOS” or you can try passing the [Del] or [F1] key when text is first displayed after powering on your computer.
Step 2: BIOS menus vary by computer, but there are seldom more than a few menu categories. Review the “Main” and “Advanced” menu categories to locate your hard drive setting. When you locate the hard drive setting, be sure to note the original drive setting in the bios so that you can restore the original drive setting if your new configuration doesn’t work.
Step 3: Change the drive setting to “IDE,” then save the BIOS settings (usually by pressing the [F10] function key then restart your computer.
If changing your BIOS hard drive setting to IDE doesn’t work, return to step one and restore the original hard drive setting
If it is ok , Please vote for me...!!!!
Posted on May 31, 2010
Windows 7 64 bit tv
Drivers for notebook Samsung N150
You can download free drivers for notebook Samsung N150/N210/N220. All required drivers for Win 7 are available for download, including drivers for audio, video, chipset, Wi-Fi or usb
http://drp.su/drivers/notebooks/?v=Samsung&m=N150/N210/N220&id=428&l=en
Feb 05, 2014 | Samsung N150 Notebook
Tip
Dual Boot Xp & windows 7
First you have to create partition.You need at least two partition. One in which you intall Xp and other for win 7. WARNIG BACK UP YOUR DATA BEFORE THIS.*(You can create partion by any hard drive manager you can make a hard drive partition in control panel>administrative tool>create & manage hard drive partition)
Now install xp first in one partition. If you have pre installed then avoid this step.
Now install Win 7 in another partition.
After you restart the machine will ask to chose your os. & just select the required OS.
If any problem appears then just put win XP disk & repair it.
You cant install win Xp after windows 7.
You have to format win 7 before installing Xp.
Commiting any of trick or Tweak you need to backup your data in another HD partition
on Mar 10, 2010 | Computers & Internet
Installed win 7 but want restore to xp
To reinstall win XP from usb flash drive you need WIndows XP cd, 1 gb flash drive and Novicorp WinToFlash. Download WinToFlash to your computer and follow instructions to transfer Windows XP from cd to flash drive, After that boot your notebook from usb device and select "TXT Mode Setup Windows XP, Never unplug USB-Drive Until After Logon" then install win xp normally, but format C partition. After first start of your notebook boot again from flash drive in "TXT Mode Setup Windows XP, Never unplug USB-Drive Until After Logon". Now windows is starting, go to start/my computer right click on it and go to properties in this windows go to advanced tab and there go to startup and recovery, click on settings, in new window go to edit tab and in new window change the line "multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP" /noexecute=optin /fastdetect" after windows XP write the type of your XP Professional, Home Edition, or Media Center. Now you can remove usb flash drive and boot normally from hdd.
Nov 12, 2012 | Advent 4211c Notebook
I have duall opreating system. One is xp another one win7.When i format my laptop.than load first xp-32bit.Than i load win 7.after finishing all the win-7 instlation.restart the system than i feace the...
Hi.
The "tfght" message means that some of the files, folders and sub folders are compressed.
Boot the Windows 7 DVD, choose Custom install, on "Where do you want to install Windows" screen, click on Load Driver. Now use the mini-explorer which pops up to rightclick on System HD then choose Properties. Uncheck "Compress Drive to save Disk Space" for All Files and Sub-Folders. Restart.
That should solve the problem.
However you may have to start again. Click on the link below for an in-depth guide on how to dual boot XP and Windows 7.
http://www.sevenforums.com/tutorials/8057-dual-boot-installation-windows-7-xp.html?ltr=D
Good luck and regards.
Jun 09, 2011 | Computers & Internet
HDD cannot be detected after reformatting
Ok, unfortunately, even though, you had two partitions they were both on the same Physical drive, now you cannot "Format & Partition" without breaking the install, as the Win 7 is the "Boss" and when you formatted you have wiped out all you boot track information, You maybe have a shot, if you get a Win 7 install disk, and boot off of it, then ask it to repair your "Boot Sector" this may allow you to Boot into Win 7,if you are lucky. Then you can use as normal. But if you cannot do that, you will have to boot from a Win 7 or Vista or whatever OS you wish to install,and follow the instructions, and do a complete reinstall of the OS. If you wish more than one partition, in the setup, it allows you to choose the size of your drive, so simply do all that, at that time.
May 08, 2010 | Acer Aspire 4720 Notebook
How can i install xp in my lenovo SL400plz get full info for it.. i'm already format my HD and i get 232GB but my HD space is 250 GB so wht can i do now...? I download all driver for xp. Plz help me...
You can actually follow the steps here in this website. Just choose below if it's XP SP1, 2 or 3.
http://www.windowsxpprofessional.windowsreinstall.com/indexinstallguides.htm#(Service_Pack_0_and_1)
Jan 11, 2010 | Lenovo ThinkPad SL400 Notebook
Will not run xp pro i'm stuck in 2000 mode mother board is ak77 pro 133 vt8233 will not run xp pro i've been told im pretty much sol. Is this true?
If you have a valid Win XP Pro CD and want to install the operating system you'll need to format your hard disk drive. If you have allot of data on you're hard disk drive, (In Win 2000) Suggest you create a second partition within the free space of you're hdd and install windows XP Pro. Boot you're system with the XP CD. Pay close attention to the display screens. Follow the instructions for creating a second partition.
Format the new partition. (Quick). Install windows XP on the new partition. Once completed you can copy your personal data to win XP.
If you choose to keep the win 2000 partition and you do not wish to have a dual boot system than remove/delete the root files from the 2000 partition. These files; Autoexec.bat and Boot.ini. You're new XP Boot.ini should read like this;
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /usepmtimer
Once you're satisfied an no longer need win 2000 use windows diskmgmt.msc from the run command to delete the win 2000 partition.
Win 2000 uses a FAT16 where Win XP uses the FAT NTFS.
Cheers!
Mike
Jan 07, 2010 | Acer AOpen AK77 Pro(A) (91.89A10.104)...
175gb missing from 250GB hard drive
Appreciate the "Ask Me".
The only plausible explanation for the missing disk space would be the protected folder "System Volume Info".
Re-formatting would not restore your free space, however, re-partitioning would. May I suggest that you try PowerQuest Partition Magic. Of course like formatting, re-partitioning would completely delete the partition itself and would grant you back the entire disk space.
Unfortunately you can not use the same with the 1st partition since that is your active partition and presumably where your OS is residing. A workaround is to use another hard disk temporarily and transfer all the contents of partition 1 and make that eventually as your primary HD. Thereafter, re-partition again the entire 250Gb HD.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 27, 2008 | LaCie (300770) 250 GB Hard Drive
Booting
dear one
you have already used the HP Operating CD to set up your hard drive (and formatted your hard drive, and installed XP, and installed the drivers, and really don't want to do that again), you can still “fix” the partitions - as long as you have the space for Quickplay outside the XP partition.
1. Boot from you HP operating system disk.
2. Press ENTER to set up Windows XP
3. Press F8 to accept License Agreement
4. With your XP partition highlighted (it’s usually C:) press Esc.
5. Make sure you have at least 250MB of unpartitioned space after your XP partition. (If you don’t, you probably have to delete XP and start all over.) I had to delete the 204 MB partition I created in the first place.
6. Once you have your XP partition and at least 250 MB of unpartitioned space, press F3 to quit. (Don’t mess with the XP partition!)
7. Press F3 again.
8. Remove your HP operating system disk.
9. If you’re really fast, you can stick your Quickplay disk in before it reboots. Otherwise, let XP load, put in your Quickplay disk, and restart.
10. Quickplay should load successfully.
11. Note that when this is done, Quickplay will actually only use 204 MB of the space after your XP partition. It just needs more than that to actually run I guess.
oke
cropp
Mar 15, 2008 | HP Pavilion dv4000 Notebook
Unable to install Win XP on Toshiba portege R500
make the SATA disk mode from ACHI to Compatibility in the BIOS. once its done without any problem you can make partitions, installa Windows XP. hope this helped you. thanks.
Ammar.
Oct 02, 2007 | Toshiba Portege S100-S1133 Notebook
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
