Question about Vacuums
Zenith dehumidifier ZD300Y0 does not drain out the hose anymore? Is it a sensor or something else? Thanks
4 Suggested Answers
  • 185 Answers
SOURCE: Zenith zd300y0 dehumidifier has 01
replace sensor ***'y p/n 6877a30013r
Posted on May 16, 2011
  • 1833 Answers
SOURCE: dehumidifier Zenith ZD300y0, indicates
Make sure that you have water bucket and drain hose properly connected.
You may need to replace the sensor.
Posted on May 26, 2011
  • 5382 Answers
SOURCE: I own a Zenith dehumidifier,
The manual for the Zenith 30-pint dehumidifier is available here: http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&productId=202051348&langId=-1&catalogId=10053&cm_sp=BazVoice-_-RLP-_-202051348-_-x . Click on the More Information tab. The direct link for the manual is http://www.homedepot.com/catalog/pdfimages/c7/c7bae79a-98a8-4c05-9e59-8f2bd71106f7.pdf .
I hope this helps.
Posted on Jun 15, 2011
I'm just looking for a owners manual for a Whirlpool Dehumidifier model AD50USL3 to see if there is anyway to connect a hose to run to a drain instead of having to empty the water collection chamber.
If your looking at the front panel of the unit look on the left side of the bucket there is a cover for the optional hose attachment.
Jun 20, 2011 | Vacuums
Hi, I have the Dehumidifey in the boat and have connected a pipe to the back so it draind continually out . The problem is that it still fills up the container and doesnt drain out the pipe. I cannot find...
Pipe or hose must be totally sealed to dehumidifiers output. Then make gravity work... all pipe runs must be downhill, or else it will back up and come out the dehumidifier.
Jun 18, 2011 | Vacuums
I have hooked up a hose to my firgidaire energy star dehumidifier, 25 pint, but it is still draining into the bucket. What do I do?
Cut out the plastic in the bucket where the hose attaches to allow the water through.
Jun 01, 2011 | Vacuums
We have a zenith dehumidifier model ZD300 & the bucket full light keeps flashing. the percentage number wont go higher than 1%. we have turned it off/on & unplugged it. When we do this it will...
I've had the same issue with mine. I am a 12 year refrigeration tech. I checked the float switch which would normally cause that indication light. However manually pushing the switch and then checking it with an electric meter that was not the case. I think that is instead, an error code set by the manufacturer to assist the service tech when or if this failure occurs during the warrenty period. I also checked the next possible failure in the sequence of opperation which would be the compressor overload relay. That is sometimes why, as some people have posted, that after when unplugging the unit, it operates for a short time then again fails. In my case that was the failure. If that would have not been it than I would have tried the compressor start relay. I purchased the overload relay from my local HVAC/plumbing supply for around 7$. The control can easily be replaced by any handy homeowner. Also, as a service tech, 7$ and two wire nuts is better than a 145+$ service call.
Nov 28, 2010 | Vacuums
I have a GE dehumidifier that i hooked a garden hose to for direct drain. it will work okay for awhile then will only drain into the drain bucket. is there something i can do to ensure that it will drain...
This seems to be a fairly frequent complaint on these GE dehumidifiers, and none of the solutions I've read here or anywhere else have fixed mine. My hose is clear, straight downhill, tight to the nipple with a good gasket, no plugs visible in the nipple, but has always filled the bucket rather than drained through the hose (and it's always bone dry). After two years of this and emptying the bucket, I'm about ready to disassemble it to see if I can fix it but with all of the other unresolved complaints I've seen GE should step up to the plate and post a solution.
Aug 19, 2010 | Vacuums
I hooked up a hose to my Whirlpool dehumidifier for continuous drain and returned the bucket like the manual states. The bucket continues to fill and shut off. Model AD25DSS1 Serial Q1123013
Hi, check to make sure the drain hole connection on the Dehumidifer's reservoir, that you have the hose hooked to, isn't plugged.
Also, you might want to see if the hose connection on the reservoir, still has the "knock out plug" still in place. Look at the hose connection on the reservoir, and if you can't see through it, or put a screwdriver through it, you need to punch it out the middle with a screwdriver. Open up the hole as much as you can so it will drain into and through your hose.
Check your hose also, as it might be plugged, disconnect it and blow through one end to make sure the water can flow through it.
Those are the only three things that could be preventing it from draining out the reservoir, through the hose connection, and through the hose to your drain
Take care
Jul 18, 2010 | Vacuums
Vacuums Logo
99 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
