Question about HP PhotoSmart 7350 InkJet Printer
HP 7350 printing goes through the motions but nothing
My printer suddenly began not printing anything. When I push "print" the printer responds with feeding a paper and the cartridges run across the top of the page a couple times, then feeds the paper on through. If I push "test" under the printer controls, I get a good test page, so I know the printer cartridges are good, the printer works, and the connection is good between the printer and computer. I have also reinstalled the drivers and checked the HP website for updated drivers.
Any ideas?
  • valor54 Jan 12, 2009
    This happened when I replaced the black ink cartridge. I put in a different one and the same thing happened just in case there was just enough ink in the other one to print the test page. I have uninstalled the printer and reinstalled it. Also upgraded the driver. It still will ot print. Test page is good but when I try to print any kind of document, webpage, and pictures it will not print paper just comes out. Prnt head goes across and then spits out the paper.
  • jlfordpty Jan 31, 2009
    I have the same problem as mentioned above. Does anyone know where else we can find the answer? HP hasn't been much help.
I had the same problem and couldn't figure it out until I found this on the web - I changed the DEP setting and now I can print just fine. Hope this helps you too!!
Julia
Source:
http://www.tech−archive.net/Archive/WinXP/microsoft.public.windowsxp.print_fax/2006−06/msg00081.html
· From: Shawn D <ShawnD@xxxxxxxxxxxxxxxxxxxxxxxxx>
· Date: Sat, 10 Jun 2006 07:40:01 −0700
I just figured out my issue. It had to do with DEP − Data Execution
Prevention. I had remembered that I was fooling around with this a couple
weeks ago and had changed it to "Turn on DEP for all programs and services
except those I select" in which I had Windows Explorer checked. I just got
done selecting the original which states "Turn on DEP for essential Windows
programs and services only", rebooted, and now I can print again to my hp
7350 printer.
The DEP can be found under control panel−>system−>Advanced Tab−>Performance
Settings−>Data Execution Prevention Tab
Hope this helps.
Posted on Mar 06, 2009
  • 1 more comment
  • JackieLizett Feb 13, 2011
    Thank you so much. It works! Yeah!!!! I was desperate. Thanks again!
  • Chris Erdman Jun 21, 2012
    Thank You very much! DEP was the problem.
Thanks, it worked. I am so happy to have it be able to use as this is double side printing printer that I need.
Posted on Mar 12, 2009
I had the same problem. All tests indicated computer, printer and all connections were working appropriately but it still would not print. Even changing the ink cartridges did not help. However, once I reset the DEP, it began working like magic. THANK YOU! Spread the good word -----
Posted on Mar 11, 2009
My HP 7350 Prints Almost Nothing
You should try going into the properties and running the head cleaning that will fix ya right up
Aug 27, 2009 | HP PhotoSmart 7350 InkJet Printer
Acts like it's printing, ink is good, but nothing prints out on paper.
Nothing at all? Poor you are. The pump may damage or lost electricity.
May 31, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Won't print at all
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 04, 2009 | Canon PIXMA iP2000 InkJet Printer
Getting wet blurry pictures from the hp 7350 printer, what is wrong?
go int the printer utility and run the "clean print head" or nozzles, they are all a bit different
Dec 20, 2008 | HP PhotoSmart 7350 InkJet Printer
I have a hp 2820 and it will not print copy or scan. it goes through the motions like it is printing but nothing prints on the page. any suggestions
Could be a bad laser, or the laser shutter may not be opening. If the Laser shutter is not opening. it can be because the printer cover has a broken notch. The notch pushes a button under the cover to open the shutter.
Dec 08, 2008 | HP LaserJet 2820 Printer
My printer Wont print anything.
Hi liza,
your best bet is to uninstall/re-install your printer drivers That should reset your printer back
Jan 12, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP PhotoSmart 7350 InkJet Printer Logo
458 people viewed this question
Seeker5211
Seeker5211
