I have a DESA LMFP33PRB unvented fireplace. The remote controls the on/off and all the other functions, but it will not control the flame control, "the part that you can lower the btu and raise the b
The remote also had to be near the unit to work sometimes even with new batteries.
  • 72 Answers
You may have a bad receiver that has lost its ability to control the servo motor and adjust the flame height. Part#111441-02 Proflame Receiver. It may also explain the poor reception.
Posted on Nov 30, 2012
  • 2557 Answers
SOURCE: remote control working with fireplace.
try www.dimplex.com go to customer sevices they should be able put you on to a local dealer in your area
hope this is of some help
Posted on Dec 13, 2008
  • 188 Answers
SOURCE: REMOTE CONTROL DOESNT WORK
Some of the remotes that originally came with those units did not work or last very long. The manufacturer then later offered another remote to replace the first units. It looks like the model number you provided is a serial number, not the actual model number. I suggest that you contact Master Parts at 800-446-1446 with your model number (you should be able to find it directly on your unit with the serial number you provided) and they should have that replacement available for purchase. You also can find them on-line at www.masterparts.net. I hope this helps you!
Posted on May 21, 2009
SOURCE: My remote control will not turn the fireplace on,
Clean the sensor on the unit, make sure no dust or ash on it. good luck
Posted on Oct 11, 2009
  • 89 Answers
SOURCE: our propane fireplace pilot light is on but there
Be sure the valve is in the on position.
Posted on Nov 03, 2009
  • 232 Answers
SOURCE: I have a gas log fireplace with lmfp33pr log unit.
did you put new batteries in both the remote and the remote sensor box . if so you will need a new remote you can buy for about 100 bucks it includes the remote and remote sensor, its not hard to install . any gas log supplier can assist you
Posted on Dec 04, 2009
Unionaire wall mounted a/c/heater only works manually.Remote control no longer works even with new batteries.Should I order a new remote control or is the transmission problem from the wall unit?
check the remote operation with your cell phone
put new batteries in the remote , turn on the cell phone to camera and point the remote at the lens of the phone
press any button/s on the remote and a white dot will appear on the cell phone screen
that is the infrared of the remote transmitting
that would then mean that the receiver in the wall unit is not working
Aug 26, 2016 | Heating & Cooling
How do I order a new hitachi tv remote unit
I popped mine apart and cleaned the negative battery connection. Works like new
Feb 11, 2015 | Hitachi Televison & Video
Do bush tv remote controls stop working even with new batteries
Sometimes, the buttons we push on the remote become worn out and need to be pushed extra hard, or a new remote may be needed.
Oct 20, 2014 | Televison & Video
My Valor fireplace won't turn off with the remote
Easy turn the gas cylinder close then its off,Or you could have a faulty control valve or thermo couple .Thermo couple is the small device looks like a probe to detect heat this is normally directly in the small pilot flame.The pilot flame if not burning will not open the control valve for the other burners to come on.If the other burners come on but do not go of when turned off. then need to check control valve.
Jan 06, 2014 | Televison & Video
My x6 infocus does not react to the remote control
sometimes there is a switch near the battery or on the bottom of the remotes to disable it. otherwise some projectors have an option in the menu that you need to turn on to be able to use the remote, it should be under IR options
May 11, 2012 | InFocus X6 DLP Projector
I have a Desa EFP33PR ventless fireplace. In Auto it works just fine. In Manaul the pilot will light but when I release the gas valve control knob it goes out. Some times, if I rotate the control knob...
It sound like you may need to clean the pilot on the fireplace and then reseat the thermocouple.
Here is a link you may want to look at:
http://www.allpartsinc.com/mmAllParts/Others/Reseating%20Instructions.pdf
Sep 13, 2011 | Desa International Unvented Gas Space...
Fireplace will start but shuts off in about 30 seconds
Here's a few things to look for. After you light the pilot and turn on the burner, look at the pilot flame. Is it still a strong blue flame and it is still heating the thermocouple? If the pilot flame is a lazy yellow, it may not be able to keep a good enough flame on the thermocouple to keep it hot. The solution? Turn it all off and let it cool down. Take a can of compressed air, like you use to clean computer keyboards, and using the attached straw, blow out the dust or spider web that's partially blocking your pilot orifice. Where the pilot flame is usually lit, blow right down that flange, as well as through the air hole that is on the side of the pilot assembly. If you do it right, the pilot flame should be a nice and strong blue color. Another thought. Is this a vented or unvented fireplace? If it's vented, make sure it has the oxygen it needs to burn by checking for blocked vents or opening a closed fireplace fume above it.
Douglas
Nov 19, 2010 | Desa International CGCFTP Compact Heater
My Amplifier YAMAHA DSP A-2 not working remote controler befo time to time worked but now completley dost not work
Is the remote the fault or the machine. I would try new batteries I know this is obvious but even new batteries can be faulty. One way to check if remote is sending out a signal is to use it near a radio on mw it will cause interference, check battery terminals are clean and not had caroded batteries inside. not much more you can do if none of the buttons work but change the remote, you can probably get one on the internet ,
pete
Nov 09, 2010 | Yamaha AX-396 Amplifier
I have a Grundig GU22DVD TV/DVD combo and the remote has stopped working even with new batteries. We,ve just moved it to a new house and need to tune in the digital channels without the remote. Is this...
Take out the battery an hour,put in back in,have the same problems.The remote is dead.Try website like Remotes.com to buy an exact remote.Yes,u can use the manual control buttons on right side of the tv,but a little hard.
Sep 06, 2010 | Grundig GU19WDT 19 in. LCD TV
Heating & Cooling Logo
233 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
