Question about Kenmore 96112 / 96114 / 96119 Electric Kitchen Range
Need to know amps needed for Kenmore Electric Stove Model 790.9611
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
30 amps
Posted on Nov 30, 2012
JULIANFIX
  • 975 Answers
SOURCE: my kenmore electric range 9621 shut down
check inside the stove for some kind of fuse , also check with a multimeter set to OHMS the circuit breaker of the stove to see if theres continuity . hope it helps
Posted on Apr 21, 2008
jsrock516
  • 5911 Answers
SOURCE: I have a kenmore stove 362.7361193 pilot not on
There isn't a pilot light on MOST modern gas ranges. The top burners are controlled by individual igniters through a common spark module. The oven, however, is controlled by an igniter on each manifold. One for bake, one for broil. If you are having problems with ONE of the oven features, I would suspect a bad igniter. If BOTH oven features are bad, you may have a bad Electronic Oven Control (EOC) board. If the oven works, but none of the surface burners are working, I would suspect a bad spark module. The following link explains a little theory on oven igniters:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
Since your range appears to have a common gas safety valve and regulator, all burners are fed fromthe same gas source. Which means, if you have ANY burners lighting, you probably don't have a gas problem.
I hope you can determine what your problem is from the information I provided. If not, please post back and elaborate a bit more on your symptoms so that I may assist you better. I hope this helps you.
Posted on Jul 22, 2009
milten1
  • 1304 Answers
SOURCE: what causes a kenmore electric stove to flash f10
usually that is associated with a runaway temp depending on the moddle
you would need to replace the sensor
goto sears dot come typee in your model number
they will ship you the part
Posted on Oct 06, 2009
  • 401 Answers
SOURCE: purchased a a kenmore 90152 stove. i need to know what
Whatever the manual states. Usually a double 50 amp on #8 wire
Posted on Jan 02, 2010
emissionwiz
  • 79847 Answers
SOURCE: Kenmore Gas Stove model 911.3652191
If you can't get the part you are sunk here, sorry,. I do suggest you go on line and try all the parts sources you can find, get the part number and type it in the search window and see what shows up, if you don't have the part number of the panel then call the repair service and ask for it.
Posted on Sep 05, 2012
My Kenmore stove, model #79095680301, was baking some food when it made a loud popping sound. Since then, the control panel doesn't work (and we can't turn on the oven without the control panel). The stove...
Joe,
Sounds like you need to contact a qualified Kenmore technician. It could have burned out an element, wires to the element, etc., but you'll need to be fairly skilled to check these components.
Try contacting Kenmore directly here:
Kenmore Customer Care Customer Service Information
Feb 08, 2018 | Kenmore Electric Smooth Top Stove
I have a kenmore 953 freestanding stove, my wife was making pizza and the oven made a strange sound, the display is no longer working, the oven stopped heating, and she attempted to turn on the burners,...
If you will type "SearsPartsDirect" into your search engine, you can then enter your model number and you will see all the parts of your stove.
What should have happened was, either an element failed, or the element wire connection inside the wall of the oven failed, or a wire has "toasted" in the electric box inside the back of the stove.
You will need to take the oven out (away from it wall, perhaps) & give it a good inspection with an electric meter to find out where the problem lies.
God bless your efforts.
Oct 02, 2017 | Kenmore 9535 Electric Range
My range top is not excatly level how do you level a glass top range?
Most ranges have leveling legs. Remove the storage drawer and look to see if the legs have threads. Then twist a leg clockwise to raise one corner or counterclockwise to lower it. (It could be reversed - it's been awhile since I leveled a stove.) Adjust as needed to get the stove level front to back and side to side.
BTW: the parts diagram for the 95002 chassis is here: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Range-Parts/Model-66595002100/0582/0124111/P0101022/00003?blt=06&prst=&shdMod= .
I hope this helps.
Jan 12, 2011 | Kenmore 95002 / 95004 Electric Kitchen...
Moved into this house. Has no manual on Kenmore glass top stove, on how to use self cleaning oven. Looking for manual or directions on how to use it. Only have model # 790.96011400 and serial # VF50635079
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Apr 13, 2010 | Ovens
Correct wire gauge and circuit breaker to use?
If it is only the oven that is electric and not the entire stove, the required wire size is 10/3 with ground and a 30AMP circuit breaker. If it is the entire stove then you need 50AMP range cable and a 50AMP breaker. If your doing your microwave also, you need a 20AMP breaker and the wire you need is 12/2 with ground.. If the current breaker you were running was 30AMP I would keep that for your oven and run new wire for your microwave.
Feb 23, 2010 | Kenmore 79383 Dual Fuel (Electric and Gas)...
What causes a kenmore electric stove to flash f10
Sep 29, 2009 | Kenmore Kitchen Ranges
I have locked my Kenmore self cleaning stove, now it won't open
Sorry you gave the sereial # for the oven. Need model #. Here is an manual that might work for you. cout and past in address bar.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0309524.pdf
Or you can go to this web sight and look up your oven.
http://www.managemyhome.com/mmh/answers/Answers.action#l4q106688
Good Luck
Dec 18, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Problem with Kenmore Electric stove
I have kenmore stove mod.790-95660103 you turn on any top burner . T he small one inside the big burner comes on Roy
Nov 24, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 96112 / 96114 / 96119 Electric Kitchen Range Logo
348 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
