Question about Acer Power FV PC Desktop
Ware each wire goes on motherboard
Wires ave come out dont now how they go back
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 77 Answers
Need a picture of the wires and connectors
Posted on Nov 30, 2012
The Pink and green wires in the bunch of wires near the right wiper under the hood has been cut by the belts I need to know what those wires are and how to fix them. I have picsbut dont know how to post...
The wire from the battery cable is the body ground. It should be connected to the inner fender on a bolt. As for the two broken wires, can you put them back together with sealed **** connectors.
Jun 27, 2010 | 1992 Buick Park Avenue
Changing engines in a Chevy van 1986 not getting fuel and we have one plug i can find ware it goes its a two wire plug pink wire with black stripe and a gray wire and one other question some one told...
Is this carbureted or Fuel injected? What size engine? The plug sounds like it goes to the secondary air injection solenoid. If the coil isn't on top of the cap the timing adjust wire is tan with a black tracer and it is taped to the harness near the distributor.
May 14, 2010 | 1985 Chevrolet Chevy
Park Ave Computer Removal
Try a small screwdriver, the plastic clip might not be releaseing or just use a little more force, try rocking back and forth and pull, it will come out.
Aug 01, 2009 | 1994 Buick Park Avenue
Horn switch is not getting power, 1994 Buick Park Ave Ultra
Have you checked the fuses? ON a buick, under the steering column there will be a set of wires. When depressing on the horm there will be 12 volt ground to the black wire. The black wire is the wire that goes to the horn relay. If you can trace ground through the wire to the relay, then the problem could be your relay. You can also put +12 volt to the horn to be sure the horn is good. If the horn sounds when putting a +12 volts the the problem again could be the relay.
May 20, 2009 | 1998-2002 Park Avenue Door Lock & Alarm...
I have an 945gzt-m v 1.0 and dont know were the pwr sw wire goes
Yes.
First, let's orient the view of the motherboard, so we are both looking at it the same way.
The processor is at the top middle, and the Front panel header, is to the very bottom right hand corner.
Right next to the motherboard mounting hole.
The Front Panel header goes across the bottom edge of the motherboard, lengthwise.
Looking at the top row of pins on the Front Panel header, No.2 Pin is at the far left. Pins 2, 4, 6, 8 and 10, go across the top.
Looking at the bottom row, No. 1 Pin is at the far left. Pins 1, 3, 5, 7, and 9, go across the bottom.
The power switch wires go to Pins 6 and 8.
The HDD LED wires go to Pins 1 and 3.
The power LED wires go to Pins 2 and 4.
On the power switch wires, the Positive (+) wire goes to Pin 6. Just in case this wire is marked.
(Doesn't really matter which way it goes, because it's a switch!)
On the HDD LED wires, the Positive (+) wires goes to Pin 1.
On the power LED wires, the Positive (+) wire goes to Pin 6.
Apr 15, 2009 | ECS 945GZT-M (V1.0) Motherboard
Dont know where an item should go
This is an internal speaker. Find the speaker pins on the mother board. Should be somewhat close to the front panel connections.
Mar 23, 2009 | Abit NF7-S V2 Motherboard
Wiring
Here you can find the user guide
http://www.epox.com/usa/download.asp?link=2Rq22Q2N3o2ta30Ab00C0z0bv0V22sq21j0wB10ca33o3m0W0EF1O3r00d1A0Iq30m1dZ03O0r1fH0B0E1B1s00Rd03r0Ct01aG00U1CR3c00H3LD02n1D1b2v2h2R2pN3a00u0J&function=download&id=1368
these must be a picture of the motherboard with the connectors tagged into it.
I think the audio one is in the bottom right corner of the motherboard.
The audio connector of the chassis probably has a false pin so that you can't plug it wrong(but if the chassis has a connector that looks like a bunch of loose cables, you need to carefully read where each one goes, I'm sure the manual says it clearly)
Feb 19, 2009 | EPoX EP-P4MKI Motherboard
Belgian Waffle Maker Problem
Here is what is happening, and if you're out of warranty and so inclined how to easily fix it yourself.
Make sure you are unplugged from the wall before doing anything or you will get shocked. You do not need to take the bottom cover off the base. You do not need to take the top plate apart (they super glued one screw in the top plate (lid), you'll strip out the screw head trying to remove it anyhow). All you need to open is the bottom plate, it has 4 screws in it you will see when you open the lid, these screws are not super glued and will come out. 2 on each side in the back, 2 in the center of the front, long screws go in the back, short in the front.
There are 2 white wires, 1 black wire, 1 green wire that run up the neck of the waffle maker to heat the top and bottom heating elements. The 2 white wires are neutral, the green wire is a ground, the black wire is power.
This black wire runs from the electronic control board in the base of the unit, up the neck in the rear, through a thermal fuse, to the bottom element then jumps up to the top element. All you need to take apart is the bottom plate, the part you pour the batter into. It has 4 screws you will see when you open the top plate up, take those out and you are going to find the black wire is covered by a white rubber like tube about 3 inches long. In the center of this rubber insulation there is a metal clip with a single screw. Take that screw out, pull off the metal clip and slide (don't cut) the rubber like insulation back.
You will find the black wire is crimped onto a silver metal bullet looking component. This component is called a "thermal fuse", its designed to fail at 240 degrees C. Its obviously a design flaw and the thermal fuse is under rated for the actual heat within the device. Its also a one shot fuse, so when it blows it kills power on the black wire from going to the top and bottom plates, thus no heat. It is not resettable.
I didn't even cut mine out (Waring is very skimpy with their wire, they don't leave you even a hint of extra wire to work with). I just tightly twisted the bare metal wire on each side of this component like a bread tie leaving the blown fuse in place. Then be sure to slide the rubber like insulation back over all of the bare metal so it is covering the black wire on both sides. If you don't it will short out and blow your house circuit breaker when you turn it on.
This thermal fuse was probably a requirement of the UL Listing. Its over kill, everything in there is metal so if it over heats in that area there is nothing flammable to burn. If a run away temperature occurs the wire itself will melt, short out and trip your house breaker. There are stacks of these units brand new with this same problem anyone reading this is having, the thermal fuse is under rated, the fix is simple.
Aug 20, 2007 | Waring WMK300 Professional Belgian Waffle...
Acer Power FV PC Desktop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
