Question about JVC PD-35D30 35 in. Plasma Television
I have sound, but soemtimes no picture. After repeatedly turning the TV of and on it works agian and then stays on until switched off. Teletekst and menus work (altough flickering), just no video.
    Top Expert:
  • JVC Master
  • 74,459 Answers
Check its main power supply regulator board for any loose solder terminals.
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there.
Posted on Nov 30, 2012
  • Maxva Nov 30, 2012
    Thanks Gopakumar, but I cannot find a search function on this side. Do I miss something
  • The Knight
    The Knight Nov 30, 2012
    There is no search function with that site. Just see it in 'Timeslide' option. You can select this option by pointing the mouse over the box at toe top left of the site. From the drop-down list, you can click this option. It will give you a list of posts by which you can select as you need. If you clik 'Home' it will give you the latest updates too Ok.
2 Suggested Answers
  • 105 Answers
SOURCE: My tv picture cuts off at the top, losing scores or tops of heads
Have you tried the "Aspect" button below the menu keys of the remote? Try "Full" Aspect and see if this improves things for you.
Hope this helps.
Posted on May 21, 2009
Proscan LED TV Will power up the red standby light & standby on amber when turned on but does not show picture or sound unless I unplug and replug over
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Feb 14, 2016 | Proscan Televison & Video
Got no picture no sound
look for more dry capacitors unplug the x and y board and check voltages
Dec 03, 2013 | Televison & Video
Lcd tv loses picture, power lght flashes grn; picture return
It sounds lamp is weak in TV and requires replacement.
I would be in better position to help you out if you post model and brand of your TV.
Dec 31, 2009 | Televison & Video
Only the sound comes in my tv no picture at all . When i switch it on the sound comes over but no pictures.any suggestions please?
you have to turn the screen control up a bit.there are 2 conrols on the flyback transformer,top one is focas bottom one is screen,turn it up 1/8 turn turn set off then on.repeat this until picture appears(if you turn it up too much picture will be to brite with lines and will shut off) if it shuts off just turn contron down a bit then restart it.
Sep 24, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture problem
This is a common problem with this TV set. You can get the parts, chips, and instructions to fix it your self from www.TvRepairKits.com
Aug 09, 2009 | Philips Magnavox 51MP392H Rear Projection...
Picture works normal for 10 ses then turns off. (3 blinking light
Re-position the safety switch behind the lamp door and if still the same try replacing the lamp.
May 27, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Blank screen on startup on Sony KV-32FX20U
All Sony sets will stay blank until the circuit is ready to power the tube. If there is a problem detected inside the set, the tube will remain vlack and the standby light will blink. This blinking will repeat a count as follows: Blink count, pause for a second or two, repeat the blink count, etc. Some Sony sets will play for a while then flash off and on. This is usually an indication that the picture tube is starting to fail. In your case, you should see a blink code. If you can update this with the blink count, I can use that info plus the model number listed above to provide a possible cause and the parts required to repair the set.
Dan
Mar 29, 2008 | Sony KV-32FX20U 32" TV
Open Questions:
JVC PD-35D30 35 in. Plasma Television Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
