Question about GE Profile : JVM3670BFBB 36" Over the RanMicrowave - Black
Touchpad does not work any longer. Is there something to check, or is this a service call.
I have unplugged to power down, and still nothing when plugged back in. Display is on...no buttons work.
  • GE Master
  • 9,047 Answers
You have a failing membrane keypad.
On some models you can order just the membrane keypad. It's more work, but it's cheaper.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
On other models, you have to order the control panel frame which comes with a new keypad already on it. This costs more, but it's an easy DIY job.
A YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes, is here.
Some connectors have a lock.
You can order GE parts from the Pros here.
Posted on Dec 01, 2012
  • Charlie Gardella Dec 03, 2012
    Thank you. I will look into trying this first. Great reply!
3 Suggested Answers
  • 5 Answers
SOURCE: GE Sensor Microwave JES1855 died
Mine went dead after about 6 months. I had problems with my breakers and I found out that it was the microwave that blew all of them. I also found out that this perticular microwave is a fire hazard and should be recalled. It has caused me alot of headache. The breakers in my house are brand new and they are put out by GE also. It caused me to loose the food in my freezer, I did not know my freezer had lost power. It would cause my entire lights to go off and then they would come back on. I have checked around and I found out that the power cord on the back of the unit is very loose. I had a person to come in and look at it, he thinks its the power cord.
Posted on Jan 17, 2010
fathitkf
  • 1871 Answers
SOURCE: touchpad is not working
Hello :
If touch pad has gotten wet, then allow to dry for several days. Avoid spraying cleaning liquid near touch pad.
Check for insect infestation. Insects (cockroaches most frequently) will appear under clear surface of touch pad or under readout window; they like the warmth of the circuit boards.
Place window mesh over vent to keep insects out.
good luck .
please rate !
Posted on Mar 29, 2010
Microwave started beeping with nothing in it now it says SE or 5E
These issues are usally due to a defective touchpad or control board. Troubleshooting would require disconnecting the touchpad ribbon cable from the control board to see if that made the problem go away.
Jul 17, 2014 | Microwave Ovens
Whirlpool MWD308
follow this steps and fix it. God bless you
  1. Controller is confused A power surge or random non-reproducible action of the universe may have resulted in the controller's program ending up in an infinite loop. Pull the plug for a minute or two to reset it.
  2. Defective Interlock switches This can result in the controller thinking the door is open and ignoring you.
  3. Cleaning Cleaning solutions (spray cleaner) may have gotten inside and shorted out the touchpad or controller. If this happens remove the touchpad, let it air dry for a few days, and then attach it back on the microwave.
Nov 26, 2013 | Microwave Ovens
Kenmore Ultra Wave microwave Model # 665.61652 Quit Working
There are fuses in the unit but why did they go bad? something else has to go bad to cause the fuse to blow, unless the fuse got old or had bad connections at the fuse holder. Can try a new fuse then run and see if it works. Just don't run it empty, just put a container of water in it to test. If it works check all connections and see if any are loose or browned like it has been hot. That's where your problem will be.
Aug 12, 2017 | Microwave Ovens
Microwave oven touch pad problem
The keypad very well could be worn from use and be working intermittently. Replacing the keypad (and the keypad face if it is a separate piece) is the most logical solution.
Aug 22, 2012 | GE Microwave Ovens
It stopped working what to do to start it
1. The touchpad and external mouse drivers should be able to work together. Just make sure that you have the touchpad enabled. To see if you have the touchpad enabled, hold the Fn key and press F9. The combination Fn-F9 locks and unlocks the touchpad. If pressing Fn-F9 once, twice, thrice does not seem to lock/unlock your touchpad.. then you might not have the Toshiba hotkeys working or enabled. So lets forget it and try step 2. If Fn-F9 solved your problem.. there you go !
Arrow The way it works is you have to keep holding Fn key and have to hit F9 once, that should lock the touchpad. Again if you keep holding Fn and hit F9 again, that should unlock it and so on..
2. Sometimes this solves the problem.. Do a power cycle of your computer.. i.e., unplug the AC.. take the battery out.. Plug the AC back in and try to turn computer ON with AC alone (i.e, leave the battery out and just start computer with AC power).. Once windows loads up and everything is fine, then turn system off. Unplug AC.. put battery back in.. Plug AC back in and restart computer.. All should be working now.. if not, keep reading..
3. Click on START>go to RUN>type devmgmt.msc
4. Now in the Device Manager, click on the + sign next to Mice and other pointing devices. Right click on each device listed under "Mice and other pointing devices" and Uninstall ALL the MOUSE Devices you see listed there..
attention Make sure you ONLY uninstall the Mouse devices and not ALL devices from Device Manager like your CD, Display etc.. Just uninstall the devices listed under Mice and Other pointing devices after you have clicked on the + sign to the left of it..
5.Install Drivers
6. In the page that came up saying Downloads ( All operating systems, All categories ), at the top drop the list Filter by Operating System and select Windows XP (I am assuming you have XP.. if you have another OS, select that instead).. then on the right of it, drop the list Filter by Category and select Touchpad.. then click on the button "Apply Filters"..
7. Now you just see two drivers listed..
09-30-2004 Toshiba Utility
Touchpad Toshiba Touchpad Enable/Disable Utility for Windows XP (v1.27.0.3; 09-24-2004; 5.34M)
06-15-2004 Driver
Touchpad Alps Touchpad Driver for Windows XP/2000 (v6.0.303.5; 05-26-2004; 2.43M)
Click on the Download link on the right.. Save them to your computer somewhere in a folder or desktop, where you can remember.. After the files are downloaded, double-click on the file.. Unzip.. then Run.. and it will install the driver..
8. Restart your computer.. Now the Touchpad should be working fine.. Try Fn-F9 combination.. i.e, keep holding Fn key and tap F9 once, twice to see if it locks/unlocks the touchpad..
Jun 29, 2011 | Microwave Ovens
R-8350, No power to touchpad, but interior light works
The touchpad has its own fuse which has probably blown due to a surge perhaps related to the turning on of the fridge. Removing the cover from a microwave is potentially lethal due to the large capacitor to drive the magnetron. However, this is usually well away from the front panel. If you do venture in you should first unplug the unit and when the outer cover is removed, discharge the large capacitor with well insulated pliers -= otherwise keep well away from it. The fuse you are interested in is on the pc board behind the touchpad. Replace it with exactly the same fuse (usually a slow blow fuse).
Sep 22, 2009 | Microwave Ovens
My touchpad on my microwave quit working.
may i please ask you how old is the machine? what you need to do is open it up and have a very good look at the pads. check for ware and tare. give the contacts a clean. may i please ask are you pressing the pads two hard? please check the light. it may just need to re new it. if you have a meter. check the circuit board to see if it is getting any current. also you like to change the fuse. check that you are getting the correct power? from the mains cable
May 04, 2009 | Kenmore Microwave Ovens
My quasar model# mq8899w will not start.
hi my name is mark, you will need to remove the cover to get to the door switch. #1 unplug microwave leave unpluged for 10 minutes or more. remove cover. find a piece of card board from the back of a paper writing tablet say 2'x3' you use that as a gauge. close the door on the card. loosen screws that hold door switch and adjust switch assembly so all the microswitches are closed, reinstall cover but dont put the screws in plug in oven and check operation. if oven works install screws. if not there might be other problems. make sure you unplug the oven for 10 minutes or more before removing cover. hope this helps. thanks for your question.
Mar 17, 2009 | Microwave Ovens
Error code on touchpad....
EE4 means that the unit is not set to the proper level for the line voltage at the place where it's installed, or that may have a faulty outlet or power line.
Assuming yours is a Sharp R23-series, we have uploaded the full service here.
But I've attached an excerpt to show you how to check / set your proper voltage level.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 19, 2008 | Sharp R-23GT Microwave Oven
GE Profile : JVM3670BFBB 36" Over the RanMicrowave - Black Logo
278 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
