Question about Brother PE770 Computerized Sewing Machine
Needle is stalled
I was in the middle of doing an applique and the needle just started stalling and the auto safety warning came on. I have turned it off and also hit the needle positioning button to try to un jam it but nothing is working. What happened was the thread was caught and it jammed.
  • Brother Master
  • 7,365 Answers
Try rethreading the machine top and bobbin
also try a new needle
make sure that the top thread has not come off the top thread takeup
lever
clean under the needle plate and in the bobbin area for lint
Posted on Nov 30, 2012
SOURCE: brother ult disney machine
Marty, it happened to me! I figured it out, if you need help, feel free to email me, it is the bobbin carriage was not put it--not the bobbin spool, but the whole carriage. feel free to email me and I can walk you through it! I just saved myself a trip to the repair! :)
pyles_brandi@yahoo.com
Posted on Jan 03, 2008
  • 6 Answers
SOURCE: Brother 2003D jammed
i am not familiar with the brother safety device myself. however things i would check might be to first check the manual for the machine. if not available try to turn the machine off if it is electronic in hope that it would reset itself. i would also totally unthread the machine and change the needle. embroidery machines need to have needles changed more often due to their high speeds.What type of fabric were you sewing on? Some of the newer machines are just not made to sew on very heavy fabrics and this might be causing something in side to spring. Try to stitch on a lighter fabric with a stabilizer under it
Posted on Apr 30, 2008
SOURCE: Brother CS-6000 Sewing Machine - Jam
I had the same problem.. I think the bobbin used in this machine is no good I replaced mine.. It cost alot too.. but now I do not have any problems.. good luck
Posted on Aug 20, 2008
SOURCE: balance wheel is totally jammed
machine was working fine when suddenly it just jammed up. Everything seems to be fine, but the balance wheel is completely jammed rigid. I've looked at the shuttle and there are no thread jams at all. The needle moves fine from side to side with different stitch selections, but wont go up and down with the wheel.
I have tried looking in the machine, but I can't find any thread jammed.
Posted on Nov 17, 2008
  • 25 Answers
SOURCE: machine jammed wheel will not turn needle will not move
Thread is caught in the hook...Remove the upper thread and bobbin case, turn the hand wheel backwards and forwards by hand and remove the thread remands
Posted on Jun 02, 2009
How to applique with my Quilters Dream sewing machine
You should practice on scrap fabric until you can get the technique down well. There are different kinds of applique.
To cover raw fabric edges, you can do a smooth line of zig-zag over the fabric edge. Set the stitch width to a wide stitch and shorten the stitch length until the thread lays nicely next to each other with no gaps of fabric showing but also not so close that the stitches are on top of each other. There are methods for turning corners or curves that are nice for making a great looking edge.
Some tutorials may be helpful.
How to Applique
How to Do Applique How to Make and Apply Appliques
How to Appliqu Like Pro Sew4Home
Sep 05, 2016 | Sewing Machines
How can I use my Bernina 640 Artista to applique
Perhaps I'm not understanding your question. When doing applique, I use a very tight zigzag stitch with a satin stitch foot or open-toe embroidery foot (so the thickness of the stitches do not create buildup under the presser foot). Set the tension so the bobbin thread stays mostly under the fabric so the top thread is the only thread that shows on the top (sometimes threading the bobbin pigtail will help).
Fuse the cutout fabric to the backing fabric. Then zigzag so the raw edge of the fabric is covered by the zigzag (helps to use a thicker thread so the coverage is easier).
Some newer machines have the ability to miter corners. On my 930, I set the needle position to the outside of the raw edged. Then when I near the corner, I gently, but consistently, narrow the stitch width to an an outside point, since the needle on the outside edge, turn the fabric and gently, but consistently, widen the stitch to full width. This creates a nice mitered corner.
When making curves, stitch small lengths and then sink the needle on the outside of the curve, and gently turn the fabric to follow the curve and repeat while going around the curve.
https://books.google.com/books?id=MQneD8cQ5KAC&pg=PA13&lpg=PA13&dq=mitered+applique+corner&source=bl&ots=1sHsUrkVAz&sig=1WZ-i2-T3RtvUEW797sHxTKiq4E&hl=en&sa=X&ved=0ahUKEwiaoZeiwunKAhVslYMKHewdDFEQ6AEIKzAC#v=onepage&q=mitered%20applique%20corner&f=false
How to Appliqu Like Pro Sew4Home (FWIW, IMHO, the satin stitch on the bird is really a poor example. The stitch is not very even at all--could be the sewing machine.)
How to Make and Apply Appliques (The giraffe is a better example, although choosing a simple design to applique usually yields better results.)
Practice, practice, practice!
Feb 08, 2016 | Bernina Artista 640E Sewing, Quilting and...
Can this to freehand machine embroidery?
If you can drop the feed dogs (or have a plate to cover the feed dogs), the machine has a zig-zag stitch, and you have a darning foot or free motion foot, you can do free motion quilting, hand manipulated embroidery (monograms), and applique on a basic sewing machine. It will take some testing and quite a bit of practice. You can also use an embroidery foot to monogram and applique. You will want to sink the needle into the fabric at every corner and frequently when creating curves so you can move the fabric.
Search the internet for instructions & tutorials on how to set up your machine and the best way to accomplish what you want.
How to Monogram with Basic Sewing Machine
How to Use Monogramming Foot
Machine Applique Tutorial
Machine Applique Sewing
Jan 12, 2016 | Sewing Machines
How do I change the stitch width when using applique patterns?
The stitch width should adjust up to at least 1/4" wide. When doing applique, set the machine so the needle is centered on the raw edge of the fabric. If your machine is not stitching wide enough to cover the raw edge, then perhaps something is amiss with the machine. May need to take it for service.
Dec 01, 2015 | Sewing Machines
How do I fix or clean my sewing machine after I sewed a non sewable applique adhesive?
I DID THE SAME THING WITH STICK ON VELCRO. WHEN THE NEEDLE STUCK IN THE ADHESIVE IT PULLED THE PART BELOW THE BOBBIN HOLDER OUT AND IT HAD TO BE REPLACED. PRICEY REPAIR AND LESSON LEARNED.
Jul 19, 2014 | Brother Sewing Machines
Needle position
Please correct down position and remove the foot and switch off machine. Then set of the up position applique the needle. After machine On.
Nov 21, 2013 | Singer 8763 Curvy
How do you clean brother SQ9050
try changing the needle
try rethreading the machine top and bobbin
make sure to use every thread guide this is important for the tension
try using a different bobbin
also possible that the machine may need some type of adjustment
or the machine could be starting to have a timing problem
Dec 08, 2012 | Brother Sewing Machines
I am having trouble with applique on a memory craft janome 4800.
Upper thread breaks
needle may be in backwards
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
upper tension may be to tight
the needle may be bent or damaged
thread may be hanging up in bobbin case--check area for loose threads or lint
check for burrs on the needle plate & on the bobbin case
May 02, 2012 | Janome Memory Craft 4800QC
Brother PE770 Computerized Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
