Question about LG Dare VX9700 Cell Phone
Lg dare keeps shutting off
Every time i go to display settings my phone shuts off
  • 14 more comments
  • Anonymous Jan 14, 2009
    i cant change any thing because i have this same problem and it is pissing me off
  • ssheil Jan 17, 2009
    I have the same problem, tried adding display settings to shortcut menu and it still does it... Would love a fix for this because I bought my phone second-hand and highly doubt verizon will replace...
  • Anonymous Jan 25, 2009
    everrrrrrrrytime i hit display settings my phones shuts down and reboots!!!
  • Anonymous Jan 26, 2009
    I reset to default and it worked so far. (not complete reset where everything is lost, but just default)
  • apeck09 Feb 10, 2009
    My first dare had problems with restarting when i hit the star on the web browser for favorites i took it to the verizon store and they tried the software update but that did not work so they gave me a new phone and i had it for like an hour and that one started messing up the screen on it would hit buttons halfway across the screen when texting and the calibration would only fix it for a few minutes so i called tech support and troubleshooting it did not work so the third one is on the way i hope this one works
  • Anonymous Feb 18, 2009
    every time i click display settings, the phone turns off and resets itself
  • dolphinluv42 Mar 03, 2009
    Same problem... I noticed my clock wasn't showing on the screen. I went to dispaly settings to see what th problem is, and the phone shut's off and powers up automatically. Verizon says they now nothing about the problem!!! whatever!!!
  • Anonymous Mar 11, 2009
    verizon lg dare phone keeps restarting when I go to display settings
  • sbdons21 Mar 25, 2009
    same thing.  wont show date and time
  • Anonymous Mar 25, 2009
    i had the same problem. l just did what sulotion 3 said and it worked again. I even still had my pics and contacts.
  • meg08griffin Apr 01, 2009
    my phone is fully charged with a full battery in the icon on top right hand corner but it will shut off randomly and will not turn on even when i try to remove the battery. the only way to make it turn back on is to plug the charger into it and then it turns on. But it says charge complete!! Then when i unplug the charger it will remain on for an average of 3 to 30 minutes. Then shuts off again! I have had the phone for only 2 months and I have NEVER gotten it wet or dropped it. I went to the verizon store but they told me to come back tomorrow to update the software in the store because it takes more than an hour. I would like to just get my money back and not keep the dare but do they do that?
  • Anonymous Apr 02, 2009
    My phone keeps shutting off randomly. I've gotten a new one, and have taken mine into the store to get "new software" installed but it still does the same thing. Even more obnoxious, every single time I call someone or answer a phone call, the service drops down by half.
  • Anonymous Apr 16, 2009
    When i try to sync my music, it just restarts... it never used to do that before??
  • Anonymous Apr 19, 2009
    same with me. i have no clock on the front and when i go to display settings it shuts off
  • Anonymous Apr 21, 2009
    I am on the third dare ,and it still keeps shutting off, veizon will not return phone , unless it happens in there possesion, which of course it doesnt.
  • mrsfeige May 06, 2009
    i have returned my phone several times. still have the problem. i was looking at other forums and apparently this is just a problem that verizon and LG seem to be ignoring. the sad thing is that i really like the phone. mine seems to reset when i scroll thru text messages. in fact, it did it in the store four times while i was getting my first replacement. one forum said that they are working on a software update for this, but it still isn't out yet. its very frustrating. friend of mine, same phone...hers reboots when she scrolls thru text messages or uses the favorites side button.
    one question, as they told me to restore defualts, when i do that, and then i go and make the background black and change all the setting, do you think it will happen again? i have decided to simply take my phone back everytime i experience the problem and maybe verizon and LG will get the hint.
    also, someone mentioned that they would not replace the phone without it acting up while you were there...i can't remember if you wanted a new dare or a different phone, but if you just want a new dare, and its less than one year, they need to give you the new phone. good luck!
Go into phone settings, then security after putting in your four digit code click on reset default. Your preference settings will be set to factory defaults and your user data will not be erased. DO NOT CLICK ON RESTORE PHONE! That will reset your phone and erase everything such as contacts and pictures.
Posted on Mar 25, 2009
My phone wasn't allowing me to change display settings either. I went to phone setting, then security and entered last 4 digits of my phone number. I reverted back to factory settings and this did not erase my pictures or contacts :)
Posted on Jan 30, 2009
I just fixed this problem on my Dare. Go to phone settings and security and type in your last 4 digits then hit restore. It does not erase your pictures and contacts like some peoplr state. At least it didn't on my phone. Anyway my phone is back to normal after this reset.
Posted on Apr 03, 2010
You have to go touch "menu" then go to "settings&tools" after that go to "phone settings" and touch "security" put the last 4 digits of YOUR number, go to "reset default" and after it has been reset and such it should work.
It worked for me.
Posted on Jan 31, 2009
We just fixed mine - go to phone settings, security, enter the last four of your phone nbr (unless you've changed it) and reset the entire phone. This WILL completely reset the phone - you will lose contacts, pictures, etc so make sure to use backup asst for your contacts. You will then need to re-program your phone to authenticate it and re-set up all of your settings. Good luck!
Posted on Jan 17, 2009
I'm having the same problems on my phone. It will fine for the longest time then one day it won't work. I've tried restoring it, but it didn't help. I've have bad luck with LG phones. I will not be getting another LG. Everyone I've had has been junk!
Posted on May 04, 2010
  • 4 Answers
I had the same problem. I went to my local Verizon dealer and they told me it was a problem with the current LG Dare software. They offered to update the software, but it still didn't work. I just got it for X-mas so the 1 year warrenty is still good, as would anybodys. In the end the tech support guy gave me a new phone. He told me to come in a get a new phone if it happens again. Luckly it hasn't happened with my 2nd phone, yet.
Posted on Jan 16, 2009
  • 3 Answers
Get a new phone
Posted on Jan 28, 2009
When I press display settings my phone just shuts off.
You might just want to try to calibraite you phone you'll find that in the phone settings it should be the last opition. all you do is touch where the + is at all pionts in the screen it showes it. This may work.
Aug 29, 2010 | LG Dare VX9700 Cell Phone
Shuts off by itself
its a kind of s/w prob u have to go lg care n update the s/w... thnx...
May 10, 2010 | LG Dare VX9700 Cell Phone
How to pairing lg dare w 2005 bmw 750..?
You most likely have to set your Dare to Discovery Mode and have the BMW find it first.
With your Dare browse to:
Main Menu -> Tools & Settings -> Bluetooth Menu
At the bottom right of your scree next to "Show" touch the options menu icon
Select "Discovery Mode"
Then follow the directions for your BMW to find the phone.
Sep 20, 2009 | LG Dare VX9700 Cell Phone
Click on the LG Dare display settings button and the phone resets
all you do is go into your security and settings and reset the phone. it will turn the phone on and back off again. but this should fix the problem and restore the ability to get into your display settings, as well as view your date and time.
Jul 29, 2009 | LG Dare VX9700 Cell Phone
I just recieved my LG Dare 1 day ago and since I have recieved it, I have fully charged the phone but everytime I take it off the charger the battery life will decrease to 2 bars and then it will randomly...
since you bought a new mobile phone,you need to boost a battery for charging more hours first,and people get around 4 hours of talk time. You should empty out the battery fully and recharge it fully, again. Good luck.
i have read the reviews oof DARe.so no worried and if you have weak singal stregnth in your area you might loose you battery power quickly anyway thats not your issue.
Jul 14, 2009 | LG Dare VX9700 Cell Phone
Lg Dare resets when i go in my inbox
Make sure that you have about 150 messages at all times in your in box. I have the same problem when the memory is over loaded it will shut down when you get down there.
Jul 10, 2009 | LG Dare VX9700 Cell Phone
LG Dare locks while typing a text message.
I thought I had this problem too, but then I realized I was pressing the lock on the side of the phone. When holding the phone sideways to get the full keyboard, the phone rests on my pinky fingers so I can type with my thumbs, and the lock button is right where my left pinky finger hits the phone. Very inconvenient, but you just have to be aware of it, maybe change the way you cradle the phone while texting.
Jun 25, 2009 | LG Dare VX9700 Cell Phone
Boy friend locked LG Dare to keep me from using it. Need unlock instructions or master reset
Send me your IMEI. This is a 15digit number that you receive when you input *#06# on the phones main screen. I might be able to help you then.
Jun 02, 2009 | LG Dare VX9700 Cell Phone
Display settings wont open
I had the same problem. What you have to do is go to settings and reset your phone to defaults. It wont erase anything except your settings. So if you had a downloaded ring tone set you would just go in and change it.
-Ty
Apr 05, 2009 | LG Dare VX9700 Cell Phone
LG Dare & LG ENV2 BOTH DEAD
i was talking on my phone yesterday and i just shut off. i plugged it in and it has a full battery but every time i turn it on it only gets to the "registering apps" it shuts off. what is wrong with my phone?
Sep 03, 2008 | Cell Phones
LG Dare VX9700  Cell Phone Logo
6,106 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
