Question about NorStar M7324 Telephone
Want to assign another extension to access another extensions voicemail box on a Norstar CIS system
Currently and external numberXXX-XXX-XXXX is ringing on a specific number AAA and then going to its vm. What the customer wants is for the external number to not only ring on AAA but also another number BBB and then all goes to BBB voice mail.
    Scholar:
  • NorStar Expert
  • 277 Answers
Configuration/Sets/BBB/LineAccess/LineAssignment:
Assign the Line XXX to BBB as Appear and Ring or Ring Only (on intercom key)
Now the line rings on both sets
Administration/Capabilities/Sets/ AAA & BBB:
-Change AAA\'s Forward No Answer Ring count to 4 rings
-Change BBB\'s Forward No Answer Ring count to 3 rings
-Obviously make sure the Forward No Answer is pointing to the DN of the voice mail system on both sets
-Make sure Forward Busy is set to Non on both sets
Because the ring count is shorter on BBB all calls will dump in the mailbox of BBB
Posted on Nov 30, 2012
  • 6 Answers
SOURCE: Voicemail
It sounds like you are using a voicemail service from a provider, meaning you did not buy the voicemail system with the phone system. If you confirm, I can tell you how to fix this.
Posted on May 13, 2008
  • 18 Answers
SOURCE: My phone on our Norstar system rings & rings
Fress F985 u will get voicemail DN. Note down ur voice mail DN.
Go to programming of Norstar which will be F**266344 password will be 266344.
Dispaly shows u terminal and extensions.
press show
then next display will show u capabilities.
Press show then next display will show u FWD no answer.Press show then change put the voicemail Dn which u had written then next.
Now call will go to ur voicemail provided u have ur own presonal mailbox. If it is not there u will have to createe it otherwise it will go to general delivery mailbox.
Hope it will be helpful for u.
Thanks.
Posted on Jul 12, 2009
consultel1
  • 860 Answers
SOURCE: How do I send a call to internal voice mail?
Use feature 986 (transfer to VM) then enter in the co-workers extension number. That will bypass the extension and send the caller directly to his voicemail.
Posted on Jun 30, 2010
consultel1
  • 860 Answers
SOURCE: I had deleted a mailbox
It sounds like you didn't attach his extension to the mailbox if your getting a log prompt.Look at F983>1020000>mbox>chng>his ext. #>next>and see if his ext. # is listed here. Also, whats his ext. number? It's not 100 per chance is it?
Posted on Sep 17, 2010
SOURCE: Voice Mail Access with No Phone Terminal
how do turn on auto attadent on phone system m7324
Posted on Jan 20, 2011
How do I activate a line on a Nortel system to set up a mbox without a telephone extension?
Hi!
All phones that are plugged into the system are automatically assigned an extension. This is a good thing, and it keeps life simple. When you have a specific line assigned to a phone, all it means is that you have the phone programmed to appear and ring on that particular phone set.
In short, find out your extensions number by pressing feature * 0 intercom. That will be the extension that you put in to add the mailbox to that phone.
Now, I am assuming that you are using a voice mail system. If you are not, then you can have your phone service provider set you up with an external voice mail on a particular line.
Let me know if you have more questions.
Jan 06, 2012 | NorStar M7310 Corded Phone
When logging into the voicemail for a Nortel T7316E i get the Mbox Locked warning. I have followed the steps to reset my password and have successfully done that. I then proceed to access my voicemail with...
You're resetting the wrong password. Keep in mind that mailbox numbers and extension numbers are not always the same. When you're resetting the password, make sure that the EXT assigned to it is the right one !! If you're resetting the reception mailbox, it's usually mailbox 100 (regardless of what the extension number is)
May 10, 2011 | NorStar T7316E Corded Phone
CP100 Auto Attendant transfers direct to voicemail
The norstar extension may be setup up for Call Fwd to voicemail, or call fwd/busy. Also, Custom Call Routing may be setup to send the caller directly to the mailbox.
Nov 10, 2009 | NorStar CallPilot 100 Voice Mail, 10 mail...
Unable to add voicemail box on Norstar system
If the mailbox is made, you need to check the programming under sets, FWD no answer, that needs to forward to the extension on the voicemail.
Jun 08, 2009 | NorStar CallPilot 100
Nortel 7310 voicemail will not reset
You dont have the EXT of mailbox 222 assigned to ext 222. Go under F983 press mbox press chg press 222 press ok press next it was say EXT: see what ext is assigned to put in 222 press change enter 222.
If it tell you that 222 is already assigned you have to find the mail box it is assigned to. Usually involves checking every Mbox starting with 221
Hope this helps.
Apr 14, 2009 | Nortel Norstar 16-Line PBX Speakerphone
How to chg a norstar mailbox from 'General Delivery' to 'User'
check under the mailbox set up ( where you created it) for that extension that the extension number of that phone is on that mailbox> in other words, you could create mailbox 221, but assign it to 222. The Gen Delivery box is 100 which is the catch all for transfers that cannot be completed.
Jan 07, 2009 | NorStar T7208 Corded Phone
you should be able to dial the voicemal system internally and it will prompt you for your box number and code, or from outside the system there should be a code that will allow you to enter voicemail from the main menu of the auto attendant
Dec 23, 2008 | NorStar M7324 Telephone
Norstar T7316 can't make call forward work
This worked for me:
Feature 4, 0 1 (xxx) xxx-xxxx
Mike
Aug 06, 2008 | Nortel Norstar 16-Line PBX Speakerphone
Norstar M7324 Corded Phone Problem
i need help to get into a voicemail that we do not have the password
Dec 11, 2007 | NorStar M7310 Corded Phone
NorStar M7324 Telephone Logo
176 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
dan4261
Level 1 Expert
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
