Question about Camping, Backpacking & Hiking
Need a replacement bulb for a proteam enroute spotlight 3000000 candle power. please help!!
Item number is 360/109-at-029. not sure of the wattage 12v! tried their web site but is unavailable at the min.
  • perry Nov 30, 2012
    not sure where to get one from. bought this with no bulb! can any one help ? thanks
brainyass
  • 242 Answers
SOURCE: Vector Sport Spot 1,000,000 candle power spotlight
6 Volts, here is info from site.
VEC127Y
VECTOR SPORT SPOT 1 MILLION CANDLE POWER CORDLESS-RECHARGEABLE SPOTLIGHT
  • HIGH CANDLE POWER QUARTZ HALOGEN BULB DELIVERS A BRIGHT AND TIGHT BEAM
  • AREA WORKLIGHT IN HANDLE PROVIDES UP TO 15 HOURS OF LIGHT WHEN FULLY CHARGED
  • PROVIDES CONTINUOUS SPOTLIGHT USE FOR UP TO 25 MINUTES WHEN FULLY CHARGED
  • HIGH IMPACT, BREAK RESISTANT ABS AND POLYCARBONATE HOUSING
  • TOUGH, WEATHER RESISTANT AND BUILT FOR RUGGED OUTDOOR USE
  • REPLACEABLE 6 VOLT, 6 AMP HOUR, NON-SPILLABLE, SEALED BATTERY
  • LOCKING TRIGGER FOR ON/OFF LIGHT CONTROL
  • INCLUDES AC AND DC CHARGING ADAPTERS
  • INCLUDES BUILT IN HANDS FREE WORKSTAND
Posted on Sep 17, 2008
SOURCE: BLACK & DECKER CARLITE
The replacement bulb has the part number P361235WFL - H available to order through Wilts Electrical (in the UK) cost is £10 plus VAT (There is however a minimmum order value of £15) so it attracts a premium of an additional £3.50 plus VAT.
Posted on Nov 13, 2008
97F350diesel
  • 1326 Answers
SOURCE: need a replacement bulb for coleman 12v spotlight
Try the home depot or any local department store where they sell the camping equip/flashlights. Usually they have replacements for them their
Posted on Sep 05, 2009
SOURCE: I need 3 light bulbs for a 3 million candle power
Hello! I have a marinepro, 12-volt, 3 million candle power spotlight (mpn #MPAT-996). I found out that the manufacturer is RoadPro (866) 622-7979. After contacting them, they said the replacement bulb is an "H3 12v (volt) 100w (watt) and can be found in the Walmart camping section or should be available at any car parts store. I'm going to go to Walmart to find mine. Hope this helps others!
Posted on Jul 13, 2010
CarlGlas
  • 283 Answers
SOURCE: Vector 2M Pwr Spotlight replacement bulb
It takes a H3 bulb which is available at most parts stores and Wal*Mart stores in the automotive section.
Posted on Jul 29, 2010
I NEED A POWER CORD CHARGER FOR THE 3,000,000 CANDLE POWER HALOGEN SPOTLIGHT. WHERE CAN I FIND ONE
If this is the usual sort of halogen spotlight, it is usually supplied with a mains charger adaptor and a lead to charge it from the car cigar lighter socket.
Both those items are also commonly supplied with a range of car-related rechargeable items, torches, jumpstarters and so forth.
I have several such items and I find the 12 volt lead and mains charging adaptor completely interchangeable between all of them. Rechargeable halogen spotlights generally have a very disappointing battery life of around 20 minutes unless a very expensive professional model is bought.
If it is not a rechargeable type that must be permanently connected to the car cigar lighter, the power cord is usually permanently fixed to the lamp but if it isn't, the cable will need to be substantial enough to carry several amps - something similar to that of perhaps a large coolbox.
Apr 11, 2017 | Camping, Backpacking & Hiking
What kind of bulb does the vec137c-wm 1,000,000 spotlight take?
Hi daved750...
Remove the bulb and take it to your local auto parts retailer and show him the bulb, most of the bulbs that are used in the lights that you describe are available and a lot cheaper than ordering at the website of the dealer.
The bulb will be a 55 or 60 Watt HID bulb..The higher the wattage the brighter the bulb...but the less time the battery will last..
For a one million candle power bulb...it will be the 55 Watt bulb
Please take time to rate me
Sep 07, 2011 | Camping, Backpacking & Hiking
I need a replacement bulb assembly for a Vector Power on Board 3 million candlewatt spotlight. The small light works, but the big one doesn't and you can see where it is burnt where the wires come...
Hi snikmn...
Disassemble the flashlight.
Take the bulb out and take it to your local auto parts place and they will be able to give you the bulb that you need.
It will probably be a 55/60 or just a straight 55 or 60 watt.
The higher the wattage the brighter the light, but the less time it can burn at that setting.
Sep 07, 2011 | Vector 3 Million Candlepower Rechargeable...
Bad blub where do i get another
These spotlights are, essentially, automotive headlights powered by small batteries. Accordingly, take your old bulb to an auto parts store and match it to one of the headlight bulbs they carry. You'll find many bulbs that look just about right; the key is to find one (or more) that has the exact same base as your bulb so that it'll just plug right into place.
Before buying a new bulb, you can also double-check your old bulb with a simple test for continuity. Properly treated, these bulbs have a reasonably long life, and I wouldn't rule out corrosion in the bulb socket or some other issue that's keeping your bulb from lighting up. Of course, if you can see the torn or burned out bulb filament, it's pretty obvious that you're going to need a replacement.
Jun 02, 2011 | Cyclops CYC-S250 Thor 2.5 Million Candle...
How to replace a bolb in a dorcy 41-1088 spotlight
I charged the battery overnight, and it was working before I charged it, and now it will not work. What could be wrong with it. The bulb doesn't look blowed.
Tommy or Kathy Ingram 304-425-1120
Nov 03, 2010 | Dorcy International Dorcy 5 Million Candle...
How do I change the light bulb in my Vector ACV 127Y?
Remove the black rubber ring from the face then unscrew the reflector. The replacement bulb is the same that goes in most common driving and fog light and may be purchased at most auto parts and Wal Mart stores.
Aug 03, 2010 | Vector Spotlight - 1 Million Candles...
I need 3 light bulbs for a 3 million candle power spotlight from Gordon 12Volts
Mar 08, 2010 | Vector 3 Million Candlepower Rechargeable...
I need a 90 watt bulb for my 15 millon candle watt
Check Home Depot, they should have it, if not in the store then online
Oct 08, 2009 | Vector 3 Million Candlepower Rechargeable...
VEC127Y
Sep 07, 2008 | Vector 2M Pwr Rch Spotlight
Camping, Backpacking & Hiking Logo
262 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
