Question about Akai PT5598HD 55" Rear Projection HDTV-Ready Television
WHERE ARE THE FUSES LOCATED FOR AKAI PT5598HDI 55" PROJECTION TV?
CAN ANY ONE TELL ME WHERE TO LOOK FOR THE FUSES ON THIS MODEL? I HAVE POWER AND SOUND BUT NO PICTURE.
    Champion:
  • 240 Answers
Replace your convergence IC chips it is not a fuse problem.
Posted on Jan 11, 2009
I have 55" akai rear
You are going to have to look for open PICO fuses along with bad bias resistors close to the ic's. You should have close to +27 and -27 volts of B+ on the chips to start with. That will ensure the fuses are good. Then trouble shoot the convergence circuit from there.
Nov 26, 2010 | Akai PT5598HD 55" Rear Projection...
Akai PT5598HDI Rear Screen Projection TV With Blue Shadowing
If the ghosting is like a 3D effect its your convergence ICs , but if its like a blue Halo around objects that usually means your CRT coolant has congealed and will need replacement. The blue is the first tube to congeal for some reason, followed by green. Red seems to be not quite as prone to this. It is a normal occurrence n sets about 4 years old to need the coolant changed.
Jan 25, 2008 | Televison & Video
Color distortion in an Akai ( Cheaper model Rear Projection tv) I
Ur convergence is dead.Try Tv repair World.com.
Buy a whole convergence board replaced it.
Jan 01, 2010 | Akai PT4799HD Rear Projection Television
AKAI PT5598HDI Colors out of line and picture is bowed in on bottom and top.
http://www.fixya.com/support/t1663670-akai_samsung_pt4299hd_convergence Adjust the convergence manually. It's a pain and takes alot of patience. The diagram for the remote buttons helps a lot. If it won't adjust you'll have to replace a part inside the tv. Good luck! Hopefully it'll adjust.
Jun 14, 2009 | Akai PT5598HD 55" Rear Projection...
AKAI PT5598HDI 55 Where is fuse located
This problem is beyond a blown fuse most likely. The fuses for the unit are located on the circuit boards and the back will need to be removed to access them. This problem could be due to a missing voltage that is used to turn on the picture section of the electronics. I would search for a used unit on ebay or parts on ebay and swap out the boards. The board swap is not too complex but voltages are dangerous within the set and service by a qualified electronics technician is recommended on this unit. Thanks and good luck. Dan
May 31, 2009 | Akai PT5598HD 55" Rear Projection...
I have a 55 inch Akai rear projection tv.When I turnit on,the red timer light blink,and that is all.I've heard about this problem on here before.No pic and no sound
on the main board of the tv there is a fuse located if that is faulty this can happen,there are also many other possibilities but check out the fuse first many a times replacing the fuse solves the problem as its very negligible to replace the fuse the cost of fuse is under $1.
Mar 03, 2009 | Akai PT5598HD 55" Rear Projection...
AKAI PT5598HDI 55" PROJECTION TV HAS POWER AND SOUND, NO PICTURE
Open the back of the tv and check Fuses, sound like the high volt over loaded
Jan 11, 2009 | Akai PT5598HD 55" Rear Projection...
Akai replacement parts
You are not likely to find the board easily, but you should be able to replace the convergence ICs relatively easily. Look at the board. Try resoldering the pins on the STK ICs. If that fails to resolve your problem, replace the ICs. There may be some pico fuses located close by or low valued resistors that may be open. Check for those as well.
Keep us posted.
Dan
Jul 23, 2008 | Akai PT5598HD 55" Rear Projection...
PT5598HDI Wiring Problem
the red wire will go somewhere to the right side near the High Voltage section. The green wire is probably antenna. DO NOT get them crossed...
Question. what connector if any is attached? The board will usually have a pin sticking up that is marked...
Jul 13, 2008 | Akai PT5598HD 55" Rear Projection...
Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
187 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
