Question about Cell Phones
Got "APN NOT DEFINED" from my PowerMaxPro with GSM
When I start a diagnostic of the communication module, I've got this message "APN not defined". I know where to set it but my mobile phone contract doesn't allow GPRS and besides I don't need it for sending SMS and voice call. How can I completely disable GPRS on my PM Pro ?
  • 39 Answers
SOURCE: APN Settings
obtain the right gprs and mms parameters from service provider and all will be right
Posted on Sep 03, 2007
SOURCE: Activation Of GPRS & Settings of GPRS
pls give gprs is active but pls give setting
Posted on Jan 27, 2009
SOURCE: Nokia E71 does not send SMS messages
You have to save all your data first , then you have to format the handset by switch off and then pressing * and 3 and green button and the power button all at the same time un till it asks about country setting and time etc
Posted on Jan 12, 2010
  • 10 Answers
SOURCE: at command supported phones
AT command supported phones are
Nokia
2100, 3610, 5210, 8210, 8250, 8290, 8850, 8855, 8890
Sony Ericsson
R520, R310, R320, T28, T39, T68, T68i, R600, T610, T310
Posted on Apr 29, 2010
SOURCE: MMS problems with Samsung Gravity
did u ever get this fixed? I am having the same problem! sarahjjac@yahoo.com
Posted on Feb 23, 2011
How to fix code U0155 for 06 Ford f350
Gas or diesel ?
U0155 - Lost Communication With Instrument Panel Cluster Control Module Description: Missing message concerns are logged by a module upon failure to receive a message from another module within a defined retry period. Possible Causes:
  • Open VPWR circuit to the sending module
  • Open GND circuit to the sending module
  • Open network circuits to the sending module
Diagnostic Aids: Carry out the diagnostics for the associated network module. Application Key On Engine Off Key On Engine Running Continuous Memory All Refer to the Workshop Manual Section 413-01, Instrument Cluster. Do you have a scan tool that can talk to the I/P cluster ?
  • The instrument cluster does not respond to the diagnostic tool
  • Circuit or connection in the controller area network (CAN)
  • Instrument cluster
  • Go To Pinpoint Test H .
May 12, 2015 | Ford Cars & Trucks
Diagnostic Codes
Sounds like the link between your dashboard and the main ECM is starting to go bad. Without this link your dashboard will not work. P0600 ****** Communication Link Malfunction Source: http://forums.focaljet.com/mk-i-tech/522844-every-trouble-code-defined.html
Jan 29, 2014 | 2008 Ford Focus
I have a GE Profile fridge, top freezer. Ice buildup keeps blocking thew evaporator fan. I've defrosted 2x, checked evap drain for blockage. But ice buildup reoccurs after 2-3 days. Turning up the
You have a defrost problem. Locate your defrost timer while the unit is iced up and turn it until you hear a defined click. At this point open the freezer and listen for ice cracking. If Ice starts cracking then it's your defrost timer bad. If ice doesn't crack, then you have a defrost component bad ( heater and Bi-Metal) Ohm out your heating element and replace if there is no continuity. You can usually find defrost timer either under the front of the box, in the fridge around the light or thermostat or sometimes in the back at the bottom. The dial on the timer can only be turned one way with a large flat head. You will hear the difference in the way the clicks sound for the defined click. Good luck.
Mar 09, 2013 | Refrigerators
Mms settings for RAZR i
Starting from any of your home screens, go to 'Apps (the circle around 6 square dots at the bottom center) > Settings > More... (the last item under WIRELESS & NETWORKS) > Mobile networks > Acess Point Names' and see if an MMS APN is already defined there. Tap over it to change something you find to be incorrect. Otherwise, tap 'Menu (the 3 square dots at the bottom) > New APN', and fill in the data you'll find there according to your carrier's instructions. Either way, once you finish changing and/or entering data, tap 'Menu > Save',
By the way, if your phone's user guide happens to be missing, feel free to download it from this location.
Anyway, please, let me know if you need further informations.
Regards,
Carlos
Nov 15, 2012 | Cell Phones
2003 Land Rover Range Rover;SES light came on, had it scanned and came back w/code p1453. Can you tell me common symptoms of this code and what a fix may be?
Diagnostic Test Code (DTC) P1453 is a "Manufacturer Specific" code, which means that it is defined only by the manufacturer of the vehicle and does not exist in any standard lists of DTCs, such as the standard SAE J2012 listings.
DTC P1453 for a 2003 Land Rover Range Rover, is defined by the vehicle manufacturer as "DM-TL REFERENCE CURRENT TOO LARGE"
The possible causes listed by the manufacturer are"
> DM-TL Module
Please note that DM-TL is an acronym for "Diagnostic Module - Tank Leak". This is the module that performs the diagnostic testing on your evaporative emissions system.
So, basicly what is happening here, is that the system that was designed to test the system and warn you of an impending failure, is what is actually causing the system to fail.
Jun 13, 2012 | Land Rover Cars & Trucks
My TI 84's diagnostic on button isn't working!!
I believe that there are a few things mixed up here. The DiagnosticsOn command turns the diagnostics on to allow the calculation of the correlation and the determination coefficients for the Regression models for which they are defined (meaningfull).
Regardless of the Diagnostics ON or OFF option, the residuals are calculated automatically and stored in the RESID list. You can have the graph of the residuals displayed. By examining it you might decide to select a different regression model.
See Chapter 12 of the manual, which you can find at this address.
Feb 29, 2012 | Texas Instruments TI-84 Plus Silver...
What is apn settings
Access Point Name (APN) is a computer protocol that typically allows a user's computer to access the internet using the mobile phone network.
On a technical level it is a configurable network identifier used by a mobile device when connecting to a GSM carrier. The carrier will then examine this identifier to determine what type of network connection should be created, for example: what IP addresses should be assigned to the wireless device, what security methods should be used, and how/or if, it should be connected to some private customer network.[1]
More specifically, the Access Point Name (APN) identifies an IP Packet Data Network (PDN), that a mobile data user wants to communicate with. In addition to identifying a PDN, an APN may also be used to define the type of service, (e.g. connection to wireless application protocol (WAP) server, multimedia messaging service (MMS)), that is provided by the PDN. APN is used in 3GPP data access networks, e.g. general packet radio service (GPRS), evolved packet core (EPC).
Aug 02, 2011 | Computers & Internet
What is the description of Code P1550 as defined on emissions test for 2000 Volvo S80?
P1550 "manufacturer controlled speed metering"
Basically the code means the ABS module either lost communication or there is a fault in either front WSS's.
You need to get a scantool to access the ABS to really diagnose it.
Apr 01, 2010 | 2000 Volvo S80
Iam not able to install bsnl3gmobiletv on my samsungGT-S5603.I live in barmer(rajasthan).Thereis 3g service avaliable here
You musy define three access points.
1. bsnlnet : a) Connection name - bsnlnet b) data bearer - packet data c) APN - bsnlnet d) Authentication - Normal e) Home page - www.bsnl.co.in
2. Bsnl Live - a) Connection name - Bsnllive b) data bearer - packet data c) APN - bsnllive d) Authentication - Normal e) Home Page - www.bsnllive.com
3. Bsnlstream - a) Connection name - Bsnlstream b) data bearer - packet data c) APN - bsnlstream d) Authentication - Normal e) Home page - www.bsnl.co.in
One more to be defined is Packet data Connection - When needed Access Point - bsnlnet
Mar 15, 2010 | Cell Phones
I can't recieve or send picture message on my rogers lg shine unlock phone.
i got a unlocked phone lg shine with rogers to.just got it fixed through att.if you have att then ill tell you how to fix.you must type in exactly how i do if its a capital put it in and do it in the order i put down.
go to menu/settings/connection/network profile.
hit new
connection title:
User Defined
authentication:
PAP
username:
WAP@CINGULARGPRS.COM
password:
CINGULAR1
APN:
wap.cingular
exit out to menu
go to internet
settings/browser settings/accounts
hit option button
new
account name:
MEdia Net
home page:
http://home
connection mode:
TCP with Proxy
proxy address:
wireless.cingular.com
proxy port number:
80
security:
non-secure
time out:
300
network profile:
User Defined
no go out and back to your menu to messages
message settings/picture setting or multimedia settings/message center.
hit option button again and new
name:
AT&T MMS
mmsc url:
http://mmsc.cingular.com
mmsc proxy:
mmsc port:
80
connection mode:
TCP with PROXY
network profile:
User Defined
save
will take you back to message center screen
hit activate n done
i tried all the code on this site nothing worked.this one does work for changeing roges settings to att
Jul 25, 2009 | LG Shine (CU720) Cell Phone
Cell Phones Logo
27 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
