Question about Whirlpool Washing Machines
No power on my awo/r5206 washer
No power on my awo r5206. fuse+socket ok.
3 Suggested Answers
  • 6277 Answers
SOURCE: whirlpool AWOE 8748 has no
Sorry but with such a fault it is extremely difficult for anybody on this forum to remotely guess what is wrong with your washer.
It could be internal wiring/plugs sockets, control panel switches, control PCB.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 16, 2011
  • 240 Answers
SOURCE: no power
something is loose or power not correct. ck polarity at outlet. narrow pin is hot wide is neutral and round center is gnd. 120v hot to neu and gnd 0v neu to gnd
Posted on Sep 17, 2012
AWO/D4405 whirlpool washing machine has power to machine but nothing lights up or works ?
all washers have a switch without them the washer would cease to operate. Check power source (outlet at the wall. ) use bed light lamp to test. if thats ok you may have a a faulty switch or an internal safety fuse blown
Jan 31, 2015 | Whirlpool Washing Machines
MY WHIRLPOOL WASHING MACHINE AWO/R5206 CONTROLS ARE NOT LIGHTING UP AT ALL. CHECKED FUSE IN PLUG AND FUSE BOARD NOTHING WRONG.
I am sure there is a electronic control board on the machine. I will bet the control board is defective.
Nov 26, 2014 | Whirlpool Washing Machines
I have a whirlpool awo/d8140 washing machine that has suddenly seems no power. I have changed the fuse tested the plug and socket and nothing apears untoward when taken the lid off. Any ideas? Cheers Neil
If there is power to the main board, would suspect the board is the issue, however, if the pump, motor , water solenoid ect has a fault, machine will not fire up
Nov 22, 2014 | Washing Machines
Service light on awo/r5206 washing machine
Resetting the washing machine: Follow these tips, click on: Reset
Jan 20, 2013 | Washing Machines
Whirlpool AWOE 8748 has no power. Changed fuse and tried in a different socket. Still no power.
John C
Jul 16, 2011 | Whirlpool AWOE8748 Front Load Washer
There seems to be no power to my washer while all the other appliances in the same room are fine. The fuse box is OK. Is there a reset button on the washer itself?
hi.
first thing to do is plug the washer into a different socket.
if the washer still does not work, then there should be a fuse, either in the plug, or inside the machine itself.
if the washer works in a different socket, then there is a problem with the socket itself which should be dealt with by a qualified electrician, as a fault socke or wiring in the wall can be a serious fire risk.
if you are in any doubt, consult a qualified electrician.
hope this helps
Jul 12, 2011 | Kenmore HE2 Plus Front Load Washer
My Hotpoint ultima WT721 1200 spin keeps tripping out all plug sockets. Have changed fuse but still does it. What could it please?
hello, bad earth check all the wired connection to the washer if these are ok then check your socket wires make sure wires are tight if these ok then there may be fault inside the washer power supply hope it helps
regards
shaun
Jan 15, 2011 | Hotpoint Washing Machines
Had power cut now machine wont work changed the fuse still nothin
check power from the wall socket if its ok the doorlocks and motors are prone to blowing the circut board can be expensive
Jul 30, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
44 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
