Question about Mitsubishi WD-65731 65" HDTV
Dark spot I have spots on my tv that are not as bright as the rest of the tv. Is this do to dust in my unit or can the bulb be dirty and needs to be cleaned. How can I clean either or depending on the problem. The model of my tv is mitusibishi wd65-731. thanks and hope to hear from you
  • 133 Answers
Some of thease have round doors on the sides tward the top, there held on by 1 screw, take that off( if you do it while the tv is on, you will see it better, you can reach in there with a soft cloth, or swiffer sweeper, if it doesnt have those doors, then you will need to take the screws out around the screen , from the back, then you can lean the screen forward about 6 inches, reach in there with a duster and wipe the dust off
Posted on Jan 11, 2009
Why do i have dark smudges on my tv
Usually that is actually dust that has gotten in behind the lcd screen.The dust congregates on top of the tv and eventually falls in through the air grids. Im not to sure how to rectify this without opening the tv up not something I would recommend and can break your warranty.
Jan 06, 2015 | Televison & Video
Bright Spot
A fixed blue area on screen may be a display panel (main screen unit)
Here is a link for the boards etc this set uses--take your pick:
http://www.shopjimmy.com/sceptre-x460bv-f120
May 17, 2012 | Sceptre 46 X460BVF120 LCD TV
Mitsubishi wd-73727 have new lamp bulb;did not
Your Light Engine needs replaced. Usually around $600.00-$850.00
Jul 11, 2009 | Televison & Video
Spots on screen
Youlikely have dust inside the optical block on the LCD panels. Cleaning the panels is a tricky job and just shooting compressed air into the block will only redistribute the dust. A qualified tech can disassemle the block and clean the panels
Aug 30, 2008 | Sony KDF-E55A20 55 in. LCD Television
Dark Blotches
This is probably caused by dust, either on the mirror, lens, or possibly inside the light engine. There is a 5" dia hole on the side of the back of the tv where you can take out one screw and take the door off. this is just big enough for you to put your hand through to clean the mirror and lens. Hope this helps.
Mar 30, 2008 | JVC HD-61FN97 61" Television
Dark spots on tv
I have the same TV, and I was getting the black spots on my screen as well. It is dust settling on the bottom mirror. Yoiu can call Mitsubishi and spend 150-200 on getting it cleaned, or you can do like I did and take the front panel off and the 10 screws around the edge on the back of the black plastic border around the screen. Then lift up gently and have someone hold the screen for you and gently dust the bottom mirror. I did this by myself, but it would be wise to have 2 people do it.
Nov 26, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Bright blue spots on lower right corner of Sony Grand WEGA KF50WE610 50 in. Rear projection tv
The spots are from dust in the optical assy. It would need to be replaced because the only way to fix the part would be to disasemble it in a dust free room.
Oct 29, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Spots on the screen
Your problem could be dust or dirt on the lens inside the reflection cavity or the problem could be the light engine. If the problem is the light engine, thank god you have an extended warranty as the light engine alone cost somewhere around 1000 buck. Good Luck.
Apr 27, 2007 | Panasonic PT-44LCX65 Television
Mitsubishi WD-65731 65" HDTV Logo
95 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
