Question about Sony Playstation 3 (PS3) Console
Ps3 doesn't work propley with samsung hd tv
Hi my brothers ps3 wont work propley with his new samsung hd tv. he's tried both hdmi sockets on the tv but in which ever socket on the tv the hdmi cable is pluged into the picture on the screen always flickrs and sometimes just disappears. what should he do?
  • James Woodgreaves
    James Woodgreaves Jan 14, 2009
    my brother has solved the problem. he just had to change a setting on his ps3 from 1080p to 720p
  • Anonymous May 10, 2009
    i have the same problem....wen i plug in my hdmi cable my screen jst stays blank, ive tried changing video settings in my ps3 settings but wont allow me 2 go any higher than a 420i resolution.....please help so frustrated
Keep ypur finger on the off button for 20sec
Posted on Jan 11, 2009
    Problem Solver:
  • 4 Answers
When I was having this same problem, all I did was this: The HD television when plug up to the PS3 will see it and asked you to change settings when you click yes the problem is solved. So, start over turn on television then PS3 then choose yes to change settings.
Posted on May 10, 2009
Hi I've just got my son a relisys tv model
I thought they only made computer monitors, but you are right they make televisions as well.
relisys tv model Google Search
Apr 01, 2017 | Video Game Consoles & Games
Samsung 2007 27" TX-T3092WH will not support HDMI or cannot see PS3?
HI,
Do one thing While PS3 is in standby mode press and hold the power button on the frond panel of PS3 for 30 seconds (factory reset). After doing this you will get video from its composite video.
Also check the hdmi If you didnt get the video through HDMI then,
PS3 out puts Full HD 1080P video through its HDMI out put. IF your tv doesn't support Full HD then it will display format not supported or Software not support.
If you want to get video through HDMI then do the following.
Connect the PS3 to any Full HD tv (friends or relatives) and go to its menu ,select HDMI settings. then down scale the video from 1080p to 1080i.
After that connect the PS3 to your tv you will surely get the video.
Ajin
Jun 16, 2012 | Samsung TX-T3092WH TV
Hi, I have a samsung LE40B750. It is connected
Ur tv some how causes HDMI 1 and 2 port hubs link together so changes back and fourth 1 or 2 HDMI hubs will not a difference.Ur tv have 4 HDMI hub ports wright?Tries not to used HDMI hub ports as like HDMI ports like 1,2,3,4 to as in sequences.Tries used like 1 and 4,2 and 4,3 and 1 as skips sequences might work for ur tv.Tries to hook up the PS3 system as the old format hook up same hook as PS2 format like used the PS station old RCA AV cable hook up.Then that should not causes conflict at all because now tv have two difference kind of format hook up.
Sep 05, 2011 | Samsung Televison & Video
Connecting Ps3 with philips tv (full hd) when i got hd cable in, and click to switch so the ps3 uses hd to show things and i than switch over to the channel i plugin the hdmi cabel it gives blac kscreen
If it's the first time using your PS3, use the composite cables that came with it. Turn on the PS3 go to video settings and switch the input to HDMI. After you've switched to HDMI, turn the PS3 off and connect your HDMI cable, go back to video settings and change the resolution to 1080p. If this isn't the first time you've used HDMI for your PS3, make sure your T.V. is on the correct input. If the T.V. is on the correct input, try switching the HDMI cable to a different input. If that doesn't work try using a different HDMI cable, testing different HDMI connections if you're still getting the black screen. If none of those work then it's probably a problem with the PS3, but just to make sure try plugging something else with HDMI to see if that works. If another HDMI device works, then it's your PS3, if it doesn't then it could be a problem with your HDMI connections on the T.V.
May 04, 2011 | Philips 52 In. LCD HDTV
I have the same problem with my Samsung LE46A656 A1F Full HD
If it was doing it on your old console then its the TV not the PS3.
Causes: HDMI cable (Replace cable), HDMI socket on TV (Get it repaired), If it happens on all HDMI inputs then the video board maybe faulty, Interference - location of PS3 to other equipment.
The first thing to do is move everything else away from your TV except for the PS3, now factory reset the Samsung TV and make sure your firmware is up to date my records show that an update came out in May for your TV, also factory reset the PS3 and setup the HDMI video settings using the wizrad in the PS3, now connect the PS3 through all HDMI inputs to see if its one input or all, if all inputs are the same then the TV maybe faulty.
Let me know how you get on.
Thanks
Sep 05, 2009 | Sony Playstation 3 (PS3) Console
Sony ps3 an samsung tv
Well your PS3 Can't connect with your TV to the Samsung, because PS3 Was made HD Blu-Ray. If your TV/Samsung is not supported by High Def. or Blu-Ray, it will not work, you will need a different HDMI Cable, and it should work fine.
Hope this Helped.
Jul 12, 2008 | Sony Playstation 3 (PS3) Console
No sound through ps3 hdmi
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
Jan 08, 2008 | LG 42LC2D 42 in. LCD HDTV
PS3 not working thru HDMI cable
Same happened to my ps3 one week from new , took it back the the shop and got a refund.
Oct 06, 2007 | Sony Playstation 3 (PS3) Console
PS3 not working through HDMI cable
connect PS3 to TV select HDMI channel on TV press AND HOLD power button on PS3 until screen resolution selection page appears.
PS3 should now work.
had this problem, this solved it.
typical repairman looking for work :)
Sony Playstation 3 (PS3) Console Logo
418 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
