Question about EA - Electronic Arts Need for Speed : Most Wanted
Need for speed most wanted key 20 digit code - EA - Electronic Arts Need for Speed : Most Wanted
Need to reset speed dial numbers but cannot get the cursor to appear.
Dear
Storing One Touch Dial Numbers 1Press Menu, 2, 3, 1. 2Press the One Touch key where you want to store the number. 3Enter a number (up to 20 digits), and then press Set. 4Enter a name (or leave it blank), and then press Set. 5Press Stop/Exit. Storing Speed Dial Numbers 1Press Menu, 2, 3, 2. 2Enter a three-digit (a two-digit for FAX-4100e) Speed Dial number, and then press Set. 3Enter a number (up to 20 digits), and then press Set. 4Enter a name (or leave it blank), and then press Set. 5Press Stop/Exit.
Thanks.
Feb 03, 2015 | Brother IntelliFax-4100e Fax
Where can I find operating instructions for a Jazz 4400 telephone. I want to change the speed dialing to 10 digit but can't find the original instructions.
Jazz 4400- Programming an Autodial key: 1) Lift handset wait for dial tone 2) Press SAVE key 3) Dial the number you wish to save 4) Press SAVE key again 5) Press the Autodial key that you want to save number to. // Notes: The number can be up to 16 digits. If you need to add a pause (for PBX system) press REDIAL key. //
Jazz 4400 has 10 Autodial keys each can store 2 numbers for a total of 20 saved numbers. Press SHIFT key before Autodial key to access second number. Their is a HOTLINE key to store one frequent or emergency number programmed same as Autodial.
Aug 20, 2014 | Nortel Jazz Plus 4400 Speakerphone -...
How do i reprogram my speeddial numbers on jazz 4400?
Hello.
From NorStar Support:
To Program Personal Speed Dial Numbers: (Numbers 71 - 94 only.
1. Press the Feature button, then * 4
2. Enter the 2 digit code (71 - 94). that you want to assign to that phone number
3. Enter the telephone number, then press the OK softkey
4. Display will show: "Entry xx stored"
If the above doesn't work, try:
  1. Press [Feature] [*] [4]
  2. Enter a two-digit code from 71 to 94.
  3. Specify the external line by pressing a line button, a line pool button, or the intercom button. If you don't specify the external line, the system automatically chooses a line for the call.
  4. Dial the telephone number you want to program (up to 24 digits).
  5. Press [Hold].
  6. Record the code and number you have just programmed.
Hope this helps.
Feb 02, 2011 | NorStar Jazz Plus 4400 Corded Phone
How to reset sharp ar 122en
Hi, to reset the problem signs or codes, key in the following in this order and a speed of a second per key press;
  • C Auto C Auto, display must go off or blank.
  • Enter desired code followed by Copy key press. Others have sub-codes and will require you to press Copy key again after that sub-code. For example H2,H3, U2 and H4 needs once Copy key press while developer or maintenance signs require pressing 20 then Copy key then 01 then Copy key.
Hope i have adequately answered you.
Jan 22, 2011 | Sharp AR-5316 Advanced Digital Imager...
I REPAIR THE MACHINES IN AFRICA SO I NI THE ERROR RESET CODES
Perform the following procedure to enter the simulation mode.
"#" key Interrupt key "C" key Interrupt key
Main code Start key Sub code Start key
Usual "reset" codes:
14 - Trouble cancel (except for U2)
16 - U2 trouble cancel
20 - 01 Maintenance counter clear
24 -01 Jam total counter clear
02 Trouble memory clear
04 SPF counter clear
06 Paper feed counter clear
07 Drum counter clear
08 Copy counter clear
09 Printer counter clear
13 Scanner counter clear
14 SPF jam total counter clear
42 01 Developing counter clear
There are codes and subcodes.
example if yiu want to clear the maintenance counter , you have to enter simulation mode and then enter 20 / Copy key /01 /copy key.
I hope it helps you.
regards,
Adi
Nov 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
I lost the manual to the Canon LaserCLASS 510 and need to delete one of the fax numbers already programmed. I know it's a simple step, but everything I've tried hasn't worked. All I want to do is edit the...
If you still need the manual I have the electronic version of the Reference and Facsimile guides
You may want to print the list of the speed dial numbers before so you know which one(s) you want to edit and to have a backup list in case something bad happens -> Additional Functions button then press arrow keys until 8. Print Lists appears then press Set button. Press arrow keys until Print Lists appears then hit Set button then use arrow buttons until Speed Dial List appears then press Set then select the list you want to print (1-Touch, Coded Dial or Group List)
Additional Functions -> press arrow keys (or plus/minus) until 5. Add. Registration appears then Set button
Presss arrow keys until 2. Coded spd dial appears then press Set button
Press Coded Dial then enter the 3 digit code for the number you want to edit (or use plus/minus) then press Set button
Press arros keys until 1. Tel number entry appears then press Set button
Jun 09, 2010 | Canon LaserCLASS 510 Printer
Forgot how to add new phone numbers and names to my phone
Creating Phonebook Entries To store names and numbers in your Phonebook, please follow these steps: When the phone is in standby mode, press [phonebook icon] (on the left side of the four-way key). To create a new phonebook entry, press the NEW soft key. Edit Name appears. Enter the name for this entry (Edit Name). Use the keypad to enter a name for this entry; the name can contain up to 1 6 characters. (See page 1 1 for instructions on entering text.) If you do not want to enter a name for this entry, your phone will store this entry as No Name. Press the OK soft key when you are finished. Enter the number for this entry (Edit Number 1). Once you have stored a name, EDIT NUMBER1 appears next. Use the number keypad, [right] or [left] on the four-way function key, or the DELETE soft key to enter the phone number 1 ; the phone number can contain up to 32 digits. If you need the phone to pause between digits when it’s dialing (for example, to enter an extension or an access code), press [redial/pause] to insert a two-second pause. You will see a P in the display. You can also use more than one pause together if two seconds is not long enough. Each pause counts as one digit. Press the OK soft key when you are finished. EDIT NUMBER 2 appears next. Use the same procedure when entering the phone number 1 to enter the phone number 2. Press the OK soft key when you are finished. Assign a personal ring tone for this entry (Personal Ring). You can attach a personalized ring tone to each phonebook entry; the phone will use this ring tone when this person calls. Move the cursor to highlight one of the 20 different ring tone options. As you highlight each ring tone, you will hear a sample of that tone. When you hear the ring tone you want to use, press the OK soft key. If you do not want to use a personal ring tone for this phonebook entry, select the NO SELECTION option, and the phone will use your standard ring tone setting. Assign this entry to a Speed Dial number (Speed Dial). Your phone has 1 0 speed dial numbers, 0 to 9. Move the cursor to select the speed dial number you want to assign to this phonebook entry, and press the OK soft key. Select NO SELECTION if you do not want to assign this entry to a speed dial number. Press the OK soft key. You will hear a tone confirming that the new phonebook entry has been stored, and DONE! appears in the display. Note: When the shared memory is full, the oldest Caller ID message is overwritten.
Jul 19, 2009 | Uniden 5.8GHz Dual Cordless Phone
Loading speed dial numbers on a XS1215
1 press the memory key(phone on standby mode)
2 choose from number 0-9. enter the number of choice. this will be the speed dial number where you can store the entry. scroll through the list and press the select/channel key twice.
3 STORE NAME will appear. when it's flashing, you can enter the name then press select/channel key. (name can be upto 13 char)
4 STORE NUMBER will appear. when it's flashing, you're ready to enter the number. (each number can be upto 20 digits) If you have an account number, you can store it so that if you call a hotline that needs that account number, you can just press the speed dial number key. you can also press the pause key after the number if you want a 2 second delay before it rings. you can put several pauses
5 press the memory key. if the phone is idle for 30 seconds and you did not press the memory key, it will return to standby mode.
6. press the end key
Nov 12, 2008 | Uniden Cordless Phone
Spp n1000
1.Press PGM. The Talk/Batt Low lamp flashes.
2. Press SPEED DIAL.
3. Press one of the dialing keys (0-9) to store phone number. You will hear confirmation beep.
4. Enter the phone number you want to store (up to 20 digits)
5. Press PGM. You will hear a long confirmation beep and number is stored. Tall/Batt Low lamp goes off.
Do not allow more than 20 between each step of the procedure. If you enter a wrong number, press PGM and start over.
Jan 20, 2008 | Sony SPP N1000 Cordless Phone
Uniden 900MHz phone model EX17960A
Using the Speed Dial Memory
Storing Numbers in Speed Dial Memory
Your cordless phone can store up to ten numbers in the speed dial memory.
1) When the phone is in standby mode, press the memory key. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number; each number can be up to 20 digits.
7
3) If you need the phone to pause during the dialing sequence, press
the redial/p key to insert a two-second delay between the
numbers. You can enter multiple pauses to increase the delay.
Each pause counts as a digit.
4) Press the memory key again.
5) To store this number as one of the ten speed dial numbers, enter a
digit from 0 to 9. If there is already a number in that speed dial
setting, it will overwrite the previously stored number without
warning. You will hear a confirmation tone indicating that the
number has been stored.
NOTE: When storing numbers into memory, if the handset is idle
(i.e., no key is pressed) for more than 30 seconds, it will beep rapidly, and the phone
Dialing a Stored Number
1) When the phone is in standby mode, press the talk key, and listen for a dial tone.
2) Press the memory key and enter the speed dial entry (0-9) that has the stored number you
want to dial. (If you enter a digit that does not contain a stored number, the handset will
beep rapidly, and the phone will not dial.)
Nov 13, 2007 | Lands Phones
EA - Electronic Arts Need for Speed : Most Wanted Logo
Top EA - Electronic Arts Video Game Consoles & Games Experts
 Shayaan Tanwir
Shayaan Tanwir
Person On the...
Level 1 Expert
Tony
Are you an EA - Electronic Arts Video Game Console and Game Expert? Answer questions, earn points and help others
