Question about Denon AVR 1312
How to connect samsung LN40C530 tv to Denon AVR-1312 Receiver
Connections
SOURCE: Denon AVR-887 and Wii
I'm dealing with the very same frustration. Best I can tell, the problem with my setup is that this model (avr-887) can't pass component video input out through HDMI. Can anyone confirm that?
Prior to setting up the Wii, I'd only been using a single HDMI output from the denon to my tv/monitor.
The only solution I've found is to add a component video output to the monitor -- which is unfortunate. I'd much rather have only the single HDMI out.
Would love to hear if there is a way to set this up without having to add the additional component output...
Posted on Dec 26, 2007
SOURCE: AVR 810 Denon Receiver Sub Woofer Hookup?
Denon AVR-810 was a quite out-dated model. I had owned since 1992. It shown 'Protection' on the screen for 2 months ago and not yet been fixed. Better to replace a modern one or repair it at a reasonable costs.
Posted on Jan 04, 2008
SOURCE: Best Way ti connect a Denon AVR-1602 Surround Sound system with a Bell Express View Satlite reciever and Plasma TV
Is the sub woolfer out powered? My sub woolfer is not
Posted on Jun 25, 2008
SOURCE: Denon AVR 2800 digital hookup to PS3
If your TV has an HDMI input, hook up the PS3 w/an HDMI cable to the TV. This will give you a high def picture (set up the PS3 to output the max resolution your TV displays). That will take care of the video side.
Next hook up an optical cable from the PS3 to the receiver. In the PS3 menu, you have to change the audio settings to output the sound via the optical cable.
Finally to get sound out of the receiver to the speakers, you have to setup the receiver source input. For example if you setup the PS3 to play thru "VCR" input, then you have to make sure the VCR input is setup to use either optical 1 or optical 2 for sound (whichever one you have the optical cable plugged in from the PS3).
  • I found this solution on a different site... it worked for me. I needed to change the sound settings in my ps3 to optical... then i selected dolby 5.1.... that took care of my sound.
Posted on Dec 24, 2008
  • 119 Answers
SOURCE: hi denon to cable box to samsung lcd
Unless you are having res. issues you can use component / optical / coaxial cables to connect all your devices to your denon and from your denon to your tv using component cables also
Posted on Feb 25, 2009
How do i reset denon avr -1312 receiver
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Search the site by brand name to your Device.
Sep 25, 2014 | Denon AVR-1312 5.1-Ch A/V Home Theater w/...
Denon AVR-1312 turns on displays for a second switches off and the red light starts to flash
you most likely have a shortedchannel in the amp that would need to be repaired
Jul 31, 2014 | Denon AVR1312 51 Channels Receiver
Can I get audio out on a denon avr-1312
what are you wanting to audio out to? the AVR is the audio component of a setup so am unsure as to why you would want to
Feb 27, 2014 | Denon AVR 1312
Denon avr-1312 receiver and mitsubishi hc3000 projector - Video keeps dropping out
Hi, it could be a number of things, go to your browser type in the model followed by support, look at there info, is there enough life in the bulb? if it were mine i would clean the shutter and go on from there but try that what i have said example >>.denon avr-1312 support << hope this helps :)
Nov 30, 2013 | Mitsubishi HC3000U Multimedia Projector
Denon 1312 receiver composite video inputs do not work.
I'm having the same problem with my Wii output. The manual for the Denon AVR-1312 says that analog video signals (i.e. component/composite outputs from the Wii) are not converted to digital video signals (i.e. HDMI output from the rcvr). I'm running only HDMI to a projector, so the video signal is essentially lost. The fix appears to be to run an additional composite cable all the way to the projector. Sounds like your fix is the same. No Wii tonight! :(
Jul 07, 2012 | Denon AVR-1312 5.1-Ch A/V Home Theater w/...
NO SOUND FROM 6 MONTH SHARP AQUOS 60" LCD CONNECTED TO DENON AVR 1312
Check to make sure that when you are on that input that HDMI shows up in the front display. If it does not, then you need to turnit on. If it still does not, you could have a problem with your HDMI board on your receiver not recognising the signal.
Jul 03, 2012 | Denon AVR-1312 5.1-Ch A/V Home Theater w/...
Connect wii to Avr 1312 Denon
What you would have to do is connect the video output of the wii directly to the video input of the bug projector. Also connect the audio cables to it as well. Then connect an audio cable to the projector's audio out or otherwise labeled as "variable out" then connect the other end of that to the matching input terminal, found often labeled as "audio in" on the receiver's grouping of input selections for TV.
Then, on the projector, select the video mode you connected the wii cables to.
Jun 18, 2012 | Denon AVR 1312
RE: Denon AVR 3300 - I cannot get the system setup menu to display on Phillips P50PFP5332D tv screen? All connected components work and sound great, but I cannot see Denon's Setup menu on tv to a
I understand, it's something I've misunderstood on my denon avr-790 as well when connected to a samsung 8000 series led tv.
The answer isn't in the receiver's settings (you can be on whatever source you want on the receiver end when toggling the menu). You need to toggle through the tv's sources to find the menu (usually found on hdmi 1). I've spent towards an hour recently troubleshooting only to find that it was the tv's source that wasn't set properly and I was trying to change the receiver's settings instead of the tv's source.
Hope that helps!
Jan 16, 2012 | Denon AVR-485 Receiver
Just bought a 46" Samsung
http://www.retrevo.com/support/Denon-AVR-589-Receivers-manual/id/23110dj893/t/2/
This is a site where you can download a manual. I'm not familiar with Denen however, you should be able to go out of satellite receiver(HDMI) to your receiver input(tv/sat) then to your HDMI input on tv. Your receiver might show video and sound through another port of receivers options, ie; video 1, video 2, etc. Check all putput options for your picture and sound. Hope this helps.
Mar 04, 2011 | Denon AVR588 Receiver
Hi denon to cable box to samsung lcd
Feb 25, 2009 | Denon AVR-5803 Receiver
Denon AVR 1312 Logo
24 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
