Good day i have an imagistics copier,im5520 which shows an error c12c6.May i know how to fix this.sarjax@fixya.com
This copier has been showing c12c6 immediately the copier is switched on.i tried to fix it,but still no development. I realy need an assistance.
Cogz
  • 1326 Answers
SOURCE: malfunction code C0200
A C0200 is a Charge Corona problem and it is a Minolta error code.
Posted on Feb 18, 2008
  • 42 Answers
SOURCE: Xerox Copier Machine - Error U4
before replacing the fuse test it with an ohms meter
you can reset u4 codes from the control panel-let me know if you want further assistance.
Posted on Mar 17, 2008
M2Tech1
  • 313 Answers
SOURCE: Ricoh copier MP 6000 error code
THIS IS USUALLY FOR THE FUSER SECTION IT MAY BE THAT SOME TONER HAS BUILT UP ON THE THERMISTOR AND IT AINT READUNG THE TEMP PROPERLY AT WARM UP OR ON A RUN IT HAS TO OVERHEAT TO GET RIGHT READING TAKE THE FUSER OUT CHECK THE THERMISTORS.. YOU COULD ALSO GO INTO THE SERVICE MODE VIA CLEAR ALL THEN 107 AND HOLD DOWN THE RED STOP BUTTON TILL THE SCREEN CHANGES IF YOU LOOK FOR COPIER SP IN THE FEED SECTION THE FUSER SETTINGS ARE THERE YOU CAN OPEN FUSING TEMP AND CHECK THE TEMPS AT THE TIME TO SEE IF THEY ARE RIGHT.. IF IT SEEMS RIGHT IT MIGHT HAVE BEEN A READ ERROR AND BY GOING INTO MODE AND LOOKING FOR 5- 810 YOU CAN RESET THE SC TURN OFF AND THEN BACK ON IT SHOULD CLEAR... GOOOD LUCK A
Posted on Jun 26, 2009
  • 37 Answers
SOURCE: error code F-35-1 in bizhub 7145 copier
quote is probably in the right price range. you need to look at how many copies are on your machine. look at any future repairs/supplies that will be needed. like drum, developer unit. If these are also needing to be changed soon, you will have to plan on those costs also. Any comparable machine that you get get will be expensive to repair the big items. You have to put all of the money that you spent on the machine and find out how many copies you have made. you can then figure out the cost per copy. At the same time, if this machine does everything that you need from a copier, do you want to buy a new one at much higher cost.
Posted on Oct 17, 2009
SOURCE: Error SC320 Ricoh Copier
Change the polygonal motor of the laser.
Posted on Dec 07, 2009
How to fix Sharp Copier AR-5731 Error code
good day, my Sharp AR 5731 showing the message Call for Service . Code : H4-00 can you help me to fixed my problem. thanks and God Bless
Mar 11, 2013 | Sharp AR-BC260 Color Copier
Error code C0110 on imagistics copy machine which model number is C650
The only reference to that particular code is:
C011
Backup memory problem
Problem with thebackup memorydata.Defective backup ram.
Jan 21, 2013 | Pitney Bowes 460-4 Toner for Imagistics...
Imagistics dl270 code c0070
A error code C0070 means that the toner bottle can not find home position. Did you just install a new toner bottle??? If so, carefully remove the toner bottle and close the front door and let the copier warm up... Once it is warmed up install the toner bottle again.... If it will not clear you have more of a problem with the toner hopper... Good Luck
Jun 08, 2012 | Pitney Bowes 460-4 Toner for Imagistics...
My youtube is blank dos not work how can i fix it so some time shows error on youtubes blanck screen and some times shows me just blank and i do not know how to fix it
Good Day Faraidoongad!
Please upgrade your Adobe Flash Player.
That will fix it.
To download Adobe Flash Player, please go to http://www.adobe.com/support/flashplayer/downloads.html
Hope this helps!
Please don't forget to rate my answer.
Thanks for asking Fixya.
Sep 22, 2011 | youtube.com
The camera is showing a lens error and won't close. Is there anything I can do?
Good day,
This is a common problem and sometimes can be fixed.
Please see details on my tip on how to fix this error here:
http://www.fixya.com/support/r7041378-digital_camera_lens_problems
Let me know if my tip was useful for your problem!
Regards
Jan 07, 2011 | Canon IXUS 970 IS Digital Camera
I have a nikon L-16 coolpix camera.Switching on monitor shows the message "lens error".please help me. Suvendu,india,westbengal.
Good day,
Please see details on my tip on how to possibly fix this error here:
Regards
Dec 01, 2010 | Nikon Cameras
F2-02 Error on Imagistics ZB35 machine
Sharp AR-5620N getting f-2 error. What is the solution
Mar 03, 2009 | Sharp AR-M237 Copier
IMAGISTICS 2620 Error code C0500
How to reset malfunction code C0500 of a imagistic
Feb 03, 2009 | Konica Minolta DiALTA Di200 Copier
Malfunction code C0200
Jan 23, 2008 | Office Equipment & Supplies
43 people viewed this question
k24674
jasbo
jasbo
