Question about Bernina Sewing Machines
Bernina 700 (1966) The drop feed knob does not raise the feeder so the material will not move forwards.
I have moved the knob to both positions but it will not move the material under the needle.
2 Suggested Answers
  • 6 Answers
SOURCE: I have an older 1998 portable Bernina with feeder problems.
Maybe just working that bullet shaped part will get it going. If it's a 930, you need to turn the handwheel to make the dogs get back into 'operational mode' after you move the knob.
Sometimes the mechanism is stuck behind the knob. Don't force the knob. It's possible to take the motor casing off and work it loose. Use TriFlow lubricant (small black bottle Sherwin-Williams) and leave for a while. Push gently with a pencil. Whatever you do, don't whack it with a hammer, like some folks say. It likely needs to move in the other direction (if it's stuck in 'regular' mode) i.e. towards the needle end.
Posted on Jan 18, 2009
Why has the bottom feed dropped on my bernina 1011it dosent move the material when sewing
check the position of the forward /reverse lever/ knob
in the middle will not move the material in either direction
Dec 17, 2016 | Bernina Sewing Machines
Material won't move? How to adjust feed dog if that is the problem
Is the feed dog raised into sewing position and not dropped as for darning? Feed dogs need to be in the raised position in order to pull the fabric through the machine.
If the stitch length is set too short, it will cause the fabric to barely move thereby causing the machine to stitch in one place.
Raise your presser foot and gently rotate the handwheel and watch the feed dogs. Do they rise when coming to the front of the machine, move toward the back of the machine, drop down below the needle plate, and move forward to the front of the machine again? If so, the feed dogs are working properly.
If the feed dogs never rise, they are in the dropped position for darning or free motion quilting when you would move the fabric manually.
If, on the other hand, the feed dogs do not move at all, then they are seized and you should probably get your machine serviced.
Apr 09, 2016 | Sewing Machines
Bernina 440
The jagged teeth on sewing plate are not moving to move the material forward. U will have to look under the machine to check out the mechanism that is supposed to move them and find the part that is the cause of no transmission of power to the teeth assembly.
Feb 15, 2016 | Bernina Sewing Machines
Raise and lower the feed dogs
the feed dogs are the saw toothed piece under the press foot
they go down move forward raise up move back in time with the needle to pull the material through for the next stitch
the amount of movement ( stitch length) is set by the position of the forward and reverse lever/ knob
Dec 10, 2015 | Sewing Machines
How do I lower and raise dogs on the bernina 1008
unless there is a mechanical failure , the feed dogs are governed by the forward/reverse control
if it is in neutral position then the dogs will not move
Oct 27, 2015 | Bernina Sewing Machines
The Feeder Dogs are not moving forward or backwards on my sewing machine.
Are the Feed Dogs dropped? Check your manual for the location of the switch. .... otherwise your mechanism has been compromised. Take it in for repair.
Mar 19, 2013 | Kenmore Sewing Machines
Kenmore Model (385.15108200) Fabric not moving
hi! there if your feed dog does not move the fabric forward or backward,if this is so try to run machine w/o the fabric check if feed dog move on cycle,the teeth should be moving upward and downward rotation pushing action on your fabric,the teeth should come out to the plate slot of feed dog.if not adjust upward, and adjust also the presser foot of needle.if your feed dog is not moving when machine running,thre is a mechanical disengage or loosen in shuttle assymble and feeder dog mechanism they link together ubder the machine,as the shuttle move on one stroke the feeder also move also with the needle.Chesk the adjustment and link mechanism.in addition to this try to clean feed dogs by brush chips thread and fabrics sometimes stored on mechanism of feed dogs and shuttle.
Mar 19, 2009 | Kenmore 15208 Mechanical Sewing Machine
Jan 18, 2009 | Bernina Sewing Machines
Machine works but doesnt move forward
Could be that the feed dog is in the down position. The feed dog consists of serrated sections which move together under the fabric and move it under the needle. Run the machine unthreaded and you should see the serrated sections lift above the needle plate, move forward and then drop again. If this doesn't happen the "drop feed dog" knob on the front of the machine could be pushed in. Look for a small knob about 1/2 inch across on the right front of the machine. Push on it and move it sideways at the same time. If it pops out this means that the feed dog is now up and you should be able to sew.
Aug 26, 2008 | Husqvarna Viking 1
Sewing Machines Logo
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
