I can't set this on aux to get sound on my computer how do I do this it keeps setting to arc
Samsung HT- C5500 , they're connected by hdmi and audio(red and white) the speakers work when i watch a movie but not when i try to use them for watching tv, why wont it work?
we provide career option in Thailand like ccnp certification
and hardware and networking
Posted on Nov 30, 2012
We use a Samsom MDR 1688 for a conference venue. Usually we record our conferences and broadcast them. However, it seems to be problem getting the sound from the mixer into the computer we use for...
The AUX output is your best bet as it is independent of the main mix, so the main volume control won't affect the recording. You will need to turn up the AUX control for each channel you wish to record, and also make sure that the AUX master is up. Depending on the software/ hardware you are using to record, you should be able to set the main record level using the AUX master. Start by setting all the AUX controls to 12 o'clock and adjust from there.
Sep 08, 2011 | Samson Mdr 1688
I have the btt350 home theater system connected by a hdmi cable from blu ray player connected to a panasonic 50" plasma 3d tv when playing a disc or listening to the radio from the blu ray player the...
Page 22 in the Manual details the required input to be selected dependent on the connection type.
To enjoy sound from the TV (Page 29)
AUX*1: When using an Audio cable
ARC*1: When using an HDMI cable
(Available when using an ARC
compatible TV)
DIGITAL IN*1: When using an Optical
digital audio cable
And from Page 29
Turn on your TV and select the appropriate audio input mode
[AUX, ARC, D-IN] to suit the connections to this unit. (Page 22)
Page 30 details how to set the audio link.
Setting the audio link with the TV
With the remote control;
Select the actual TV audio connection on the main unit.
1 Press [START] and press [3, 4] to select "Other
Functions" and press [OK].
2 Press [3, 4] to select "Setup" and press [OK].
3 Press [3, 4] to select "TV / Device Connection" and press
[OK].
4 Press [3, 4] to select "TV Audio Input".
5 Press [2, 1] to switch "AUX","ARC" or "DIGITAL IN".
Select "AUX" or "ARC"*1 in "TV Audio Input" when the
DIGITAL AUDIO IN terminal is used for the STB
connection.
Whenever the connection or settings are changed, reconfirm
the points above.
Please leave feedback
Cheers
Andy
Apr 26, 2011 | Panasonic SCBTT350 Theater System
I turn the tv on and there is a loud static noise that will not turn down.
May be one of the high voltage leads popped out of the tube inside. this would cause an arcing static type of sound. May also be a bad wire or worse, a defective flyback transformer. If you have any experience with electronics you can open the back of the set and look for any signs of arcing, but be careful as the high voltage runs about 25000 volts...so I would keep my fingers away. If you do discover an arcing problem, I would have someone qualified come in and repair the set.
Dec 19, 2010 | Hitachi Televison & Video
My rca model f36669 makes a popping sound and cuts off and back on
That's hi voltage arcing. Dangerous condition were a component has broken down and is arcing causing the power supply to 'crowbar' or go into over current protection mode. Call a TV repair pro for an estimate to see if you want to keep the set.
Apr 26, 2010 | RCA F36669 36" TV
I cannot figure out how to change my aux settings to on. Nor the d-aux. any help? I am also unable to change the display color.
try this
Setting the AUX Mode (V-Link)
AUX IN ON / AUX IN OFF (Initial setting)
You can input TV/video sound by connecting an optional Ai-NET/
RCA Interface cable (KCA-121B) or Versatile Link Terminal (KCA-
410C) to this component.
You can change the AUX name display when AUX ON is set. Select
the AUX name by pressing g or f. Then press BAND.
If the KCA-410C is connected, it is possible to select two AUX
names.
• Via KCA-410C, up to 2 external devices with RCA output can be
connected. In this case, press SOURCE/POWER to select AUX
mode and then press BAND to select your desired device.
Jan 28, 2010 | Alpine CDA-9847 CD Player
How do I setup the SoundMAX device for AUX line-out?
The cable from the computer simply needs to be plugged in to the speaker/headphone jack on the computer, then run to the AUX input on the amp. Make sure the volume on the computer is set to about 75% - 90%.
Apr 07, 2017 | NAD C320 2-Channel Amplifier
No sound thru surround sound system in TV Mode
You need to connect your TV to the AUX connection in the back of your HT system. Then set your HT system on AUX 1 and wait about 5 seconds for the TV sound to come through. If it does not work on AUX 1, you may have to try on AUX 2 or AUX 3 settings on your HT system. Make sure the A/V cable you use is good and in working order and is a good quality cable.
Hope that helps, Gary
Jan 30, 2009 | Samsung HTZ-510 Theater System
Adding another external device to the sound system
yes you are right you can pick up an arc aux swich box from radio shack.
will do your job just fine.
thanks
and pleas rate this, if is of help to you.
Jan 13, 2009 | Panasonic SC-PT660 Theater System
Can't play AUX inputs through Panasonic surround sound
Check the TV audio output setting. There may be 3 settings for audio output. Fixed/variable/none. Try all of the settings, and see if you get your audio back. If not, try a different cable between the TV and DVD player. I suspect this is a red/white RCA audio cable.
Dec 12, 2007 | Audio Players & Recorders
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
