Question about Epson Stylus Photo 1410 Series
Parts inside your printer are at the end of their service life. See your printer documentation.
Both 2 LED's (the ink and paper jam indicator lights) blinking alternatively and even after following the steps towards resolving the problem still the cartridges cannot move
  • Anonymous Mar 15, 2014
    As soon as I turn the printer on both cartridge lights blink continuously. Replacing both cartridges did not solve the issue.
    Continuous blinking of both cartridge light indicators...replacing the 2 cartridges with new ones did not help
  • Epson Master
  • 419 Answers
This is a common problem with inkjets and is basically that the waste pads have reached a point the printer considers they need replacing.
You haven't specified which printer you have so it's difficult to be more specific as to your options but you can look up more on the problem here:
http://www.octoinkjet.co.uk/waste/
Bear in mind that's a commercial site (mine) but the information available is still useful in determining what options are available.
If your printer is one of the newest models (released in the last 9 - 12 months) then chances are it may have a drop out waste pad holder. Older models tend to have static pads that an external waste kit is an easier solution.
One thing to note... the error itself is based on an arbitrary algorithm in the printer firmware that's based on number of cartridge changes, head cleans and prints with an adjustment for time passed. Resetting it requires software (again the link above will help with what's available) but regardless of whether you deal with the physical waste ink or not the waste counter will not change until you reset it.
That should help at least explain what the problem is... if you want to provide more detail on your specific model I can be more detailed in terms of relevant information.
Posted on Nov 30, 2012
  • Martin Smallridge
    Martin Smallridge Nov 30, 2012
    Whoops, just spotted it's in the Photo 1410 category (curse poor eyesight/attention!). On that basis there are copies of the Service utility available that will reset the counter or you can use the WICReset (with a key purchase). Unfortunately the 1410 is one of three models (1390, 1400 are the others) where some production runs of the printer included faulty firmware. As such the waste counter cannot be reset and a firmware update is required. This is a job for a service centre although I have seen copies of the necessary tool and firmware available on the net, albeit at around $50 or so... Hope that helps...
3 Suggested Answers
  • 1456 Answers
SOURCE: '01 install ink cartridges' displayed on
Hello
first of all,double check all the cartridges have been installed correctly.Press the On button to turn on the Epson Stylus CX, or (if already on) press the Setup button.
Select Maintenance and press OK.
Select Change Ink Cartridge and press OK.
Open the cartridge cover,Press down all the ink cartridges until they click into place to make sure they are properly seated.
Close the ink cartridge cover and press it until it clicks into place.Press OK to begin charging the ink. This takes about 2 minutes.
You see a message on the display screen when ink charging is finished
PLEASE NOTE; With the Epson Stylus CX series printers, when you change one ink cartridge, all of the ink cartridges need to be replaced with new ones.
For whatever reason, Epson has it setup so the printer will only operate with each ink cartridge starting at the same amount.So when one cartridge is replaced, all of the cartridges need to be replaced.
Posted on May 01, 2011
  • 36 Answers
SOURCE: Black won't work! I have had 2 new cartridges
Use the software that was installed when you installed your printer to clean your print heads.
Posted on May 05, 2011
My epson t10 has stopped printing. The orange LED light keep on blinking even if i turn off the printer and turn on.
check for paper jam , cartridges if everything is OK , still the problem persists it is the service error take it to the service centre to the technician
Jul 25, 2011 | Epson Office Equipment & Supplies
Its an R230and it says: Parts inside your printer are at the end of their service life. See your printer documentation.
parts inside your printer indicates that you need to change the ink pad of your printer. for every epson printer they have a cycle of i think around 100,000 revolutions in the gears and then when it reaches its peak it automatically shuts down on the firmware thus indicating parts inside your printer is at the end of its service life... but it can be resetted back to its state by downloading the Ink Pad Reset counter.
you can download the INK PAD RESET COUNTER through this link http://www.ssclg.com/epsone.shtml..... install it then i suggest using the icon which will appear on the lower right hand side.
it represents a small printer. the link will instruct you on how to use it... have fun.
if it does not work then another mechanical issue might have occurred....
Jun 30, 2011 | Epson STYLUS R230 InkJet Photo Printer
My Brother HL-2140 Went out in a storm. All three lights just keep blinking no matter what I do. Held down on the blue light button a number of time, restarted computer, turned off printer, reloaded ink...
You can find the usre's manual here:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hl2140_all&dlid=&flang=English&type2=-1
1) If the LARGE BLUE BUTTON is blinking:
Data remaining in memory
There is remaining print data in the printer memory. If the Ready LED is blinking for
a long time and nothing has printed, press the Go button to print the remaining data
in the memory.
2) If the TONER LED is blinking:
Toner low
Indicates that the toner cartridge is nearly empty. Buy a new toner cartridge and have
it ready for when Toner life end is indicated.
The Toner LED will turn on for 2 seconds and off for 3 seconds.
3) If the DRUM LED is blinking:
Drum life end soon
The drum unit is near the end of its life. We recommend that you get a new drum unit
to replace the current one. See Replacing the drum unit on page 69.
The Drum LED will turn on for 2 seconds and off for 3 seconds.
4) If the RED ERROR LED is blinking:
Front cover is open
Close the front cover of the printer.
Fuser cover is open
Close the fuser cover located behind the back cover of the printer.
Paper jam
Clear the paper jam. See Paper jams and how to clear them on page 85. If the printer
does not start printing, press the Go button.
Memory full
The printer memory is full and the printer cannot print full pages of a document.
Print overrun
A print overrun occurred and the printer cannot print full pages of a document.
Mar 26, 2010 | Brother HL 2140 Laser Printer
My Epson Stylus T10 Printer have a problem...it indicates, (Service Required):"Parts inside your printer are at the end of their service life. See your printer documentation." then the two light (red &...
The waste ink pad needs to be replaced or cleaned AND the service software used to reset the internal counter. You cn download tthis online.
You have to dis-assemble the printer to get at the pad. You can clean the pad with agressive rinsing till it is a very light gray color. (A lot of ink will be flushed out!)
Oct 23, 2009 | Epson Stylus Multifunction Inkjet Printer/...
It's is asking service required,
parts inside your printer are near the end of their service life. This is message is coming, how can i do this problem, please tell me
Sep 06, 2009 | Epson STYLUS R230 InkJet Photo Printer
How to reset waist ink counter
I have resetter for this type. aicazx@yahoo.com
Jun 03, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Reset the waste ink counter!
Assuming you have completed your modification you can reset your printers waste counter using this method (I did this and it worked on the CX6400) can't guarantee it works on all)
1. You will see big button on your printer like power on (this is on the left
2. side), black & white photocopy, color photocopy, and then the stop button (these are on the right side).
3. first turn off your printer
4. push the b/w + color + stop buttons together and hold
5. push the power on button and hold (so you'll now be holding down 4 buttons together)
6. Don't release all the buttons until you see the light indicator is blinking and then a message display on the lcd
7. release all the buttons
8. push the color button (once)
9. turn off the printer
10. turn it on again
After this one may need to reload the printer driver and locate the printer!
May 27, 2009 | Epson STYLUS R230 InkJet Photo Printer
Parts inside your printer are at the end of their service life. See your printer documentation Parts inside your printer are at the end of their service life. See your printer's documentation for details
when i swich on my Printer C43, both the indicator lamp is blinking, and tehn appear the message:
"Parts inside your printer are at the end of their service life"
Feb 26, 2009 | Office Equipment & Supplies
Epson Stylus C88 show an error
I have downloaded the SSC service from the site ie. http://inkjetprinterhelp.us/epsonSSC.html
and done the setting according to the said instruction. And it was cool simple.
Thanks for you help too.
Jan 31, 2009 | Epson Stylus C88 InkJet Photo Printer
EPSON PRINTER R22O
display This massages Parts inside your printer are near the end of their service life.
Nov 08, 2007 | Epson Stylus Photo R320 InkJet Printer
Computers & Internet Logo
312 people viewed this question
Top Epson Computers & Internet Experts
teamtech
teamtech
Are you an Epson Computer and Internet Expert? Answer questions, earn points and help others
