Question about HP DeskJet 9650 InkJet Printer
In response to your suggestion
I tried. I unplugged the usb, installed the disk however the installation stopped at "search a list of detected printers". No printer is listed. The other suggestion on the same screen is enter configuration for printer. I don't know how to print a configuration page.
  • HP Master
  • 13,433 Answers
Hey,
we can start a remote support session and I can try fixing the problem for you.
start the session by opening this link
http://www.fastsupport.com/751310195
Posted on Jan 11, 2009
Usb not dectected by computer
I am assuming you are trying to connect an HP Laserjet printer to your system and the system is not detecting the printer via the USB port. What have you done thus far? Is this a printer that has been there for a long time and just now stopped communicating, or is this a new install? In it is a long-time install, check the Device Manager and verify that the printer is or is not listed. There may be an "!" on the device indicating an issue. If it is a new install, usually HP says to install the driver software first, then at a certain point, it will tell you to connect the printer and then search for it. Often connecting the printer first will result in an unsuccessful driver install/printer detection.
Oct 26, 2015 | HP LaserJet 2430dtn Printer
Lg Optimus F6 will not recognize micro sd card
Click Start, then type device manager in the Search box, then click Device Manager.
Expand Universal Serial Bus controllers. Right click a device and click Uninstall. Repeat for each device.
Once complete, restart your computer. Your USB controllers will automatically install. If the method fails you can try the following method: Click Start, type Device Manager in the Search box
Click Device Manager from the returned list.
Click Disk Drives from the list of hardware
Right-click the USB external hard drive with the issue, and click Uninstall.
After the hard drive is uninstalled, unplug the USB cable.
Wait for 1 minute and then reconnect the USB cable. The driver should automatically load
Check for the USB drive in Windows Explorer
Oct 30, 2013 | Samsung 16 GB Gigabyte Micro SDHC Memory...
Dwa 140
Next, open device manager (Click Start Menu and type in "Device Manager", right click and run as administrator). Then find your device in the list, and uninstall it. Immediately, unplug the wireless USB from the computer. Now, restart your computer with the USB unplugged. Insert your driver disk and install the driver, when prompted plug the wireless USB back into the computer. Hope this helps.
Jul 01, 2013 | Computers & Internet
Cannot install parallel to USB printer cable.
I can only really offer a suggestion. But try unplugging the adapter with your pc off. Turn the pc back on insert the disk. Then turn the printer on and try plugging the adapter back in. If your adapter/printer are working you should receive a request to add new hardware. From this point you should be able to have it "search for the best driver for your device." If this doesn't work you may be looking about a bad adapter and or unresponsive printer. also try using a different usb port.
Jul 18, 2010 | Computers & Internet
I removed my pendrive without safe remove and its next ady onwards i am not able to detect my pendrive can anybody suggest some remedy??
Assuming that you are using windows, go to drive management and see if the pendrive is detected.
If so, right-click on it and format it.
Or look for the HP USB Disk Storage Format Tool and use it.
Sep 19, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I lost my CD drivers for Lexmark Z33 and X110 and I can't print or use the machines. I am trying to download the drivers but driver dectective want to install which I did. Now each time I try to download...
Do not download driver detective, download the original driver from Lexmark website below.
Also, instead of double clicking on driver installer after downloading, click right mouse button and chose "Run as administrator".
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Mar 29, 2009 | Lexmark JetPrinter Color Z33 InkJet
No software disk to load 1700 into Dell 6400 Inspiron laptop.
In Windows, how do I install my printer? Most new printers, especially USB printers, come with installer programs. If you have neither installation instructions nor an installation program, you can use one of the following procedures to install most printers:
USB printers (Windows 98, Me, 2000, and XP only)
  1. Make sure that the USB cable is unplugged from your computer and your printer. USB devices work differently from older devices and usually need to have the drivers installed before you connect the device.
  2. If you have an installation disk, insert it into the drive. If there is an installer provided, it should run or be executed here. Follow its instructions, and it should take care of installing your printer in a few moments.
  3. If you don't have an installation program, plug the USB cable into your computer and your printer. This should trigger the Add New Hardware Wizard.
  4. Click Next, and then select Search for the best driver for your device. Click Next.
  5. Uncheck all options except Specify a Location. Click Browse. Browse to the disk, CD, or directory where your printer drivers are located. Click OK, and then click Next twice. Note: You can download some drivers from the web. Consult the web site of your printer's manufacturer, or see Where can I find driver updates for my Windows computer?
  6. When all the files are copied, click Finish.
  7. Turn on your printer. Windows should detect the printer's presence and finish the installation. If the option to print a test page is offered, do so. This will confirm the installation. Click Finish.
Jan 06, 2009 | Dell 1700n Laser Printer
I have a HP TouchSmart computer. The Brother MFC 9160 printer won't print. It will print from my HP Lap Top. The printer lights up indicates receiving data. However, only one blank page comes out.
moz-screenshot.jpgTry unplugging printer USB and reinstalling printer software from disk.
  • use the disk and run the install file.
Note:some printerdoes not work on Vista, if you do not find any driver download for Vista on your model page, that means your model is not Vista compatible.
Nov 24, 2008 | HP Office Equipment & Supplies
Need help hooking up my canon MP 240 tp my pc.My pc detectsthe printer then says no printer detected.
You need to install your printer first.
If you already have installed your printer, do this:
disconnect printer from computer
cancel documents in queue
if using a straight USB connection, delete all instances of printer. else remove duplicate printer icons.
reboot & reconnect printer (swap cables if not detected)
If you don't have installed your printer do this:
Get your printer software from: www.canon.com
Nov 05, 2008 | Office Equipment & Supplies
Lexmark 1270
That is because you connected the printer to usb before installing the software.
Ensure that the account that you are using has administrator privileges( it is not limited).
Do a system restore to one week ago see here:
How to perform System Restore on Windows... -
Then do the following.
  • Go to control panel >> installed printers in Windows and remove (delete ) your printer from printer list.
  • Use printer disk to install driver or download and run driver from website.
Sep 09, 2008 | Lexmark X1270 All-In-One InkJet Printer
Open Questions:
See all HP DeskJet 9650 InkJet Printer Questions
HP DeskJet 9650 InkJet Printer Logo
63 people viewed this question
Ben Johnson
