How to replace element in bathroom wall-mounted IRD 1000A heater
I have removed reflector but can't see how to remove element.
  • 7 Answers
SOURCE: detaching heater unit from its mounting
Make sure disconect the sercuit braker off before you remove the heater from the wall. Safty is first !
Posted on Jan 24, 2009
  • 659 Answers
SOURCE: Remove the base of a pedestal sink.
There are two bolts on either side of the sink. Remove them and lift the sink off of the base. Sometimes, depending on who installed it, you can slide the base out without removing the sink. Hope this helps.
Posted on Mar 16, 2009
  • 3 Answers
SOURCE: how do i remove it from my wall
simple remove the plate then there are two screws that you need to unscrew then you pull the whole thing out.
Posted on Jul 14, 2009
SOURCE: Remove the base for wall mount
just spoke with a Coby technician. Where the base connects to the TV you can literally just squeeze in those the plastic pieces and they come right off. After that just unscrew the screws underneath. Just did it and it was very easy.
Posted on Dec 18, 2009
  • 176 Answers
SOURCE: need heat element for fasco wall mounted bathroom heater
try to found a local manufacture for heating elements, like http://rezistoterm.xhost.ro/ , give them the old heat element and the power of the bathroom heater (ex: 3000W and 220v, or 2000W and 110V) and they wil macke new oane and much chep like an original one.
Posted on Feb 14, 2010
Goes to 88888 no matter what. How do I fix that?
Are you over 330 pounds? If not, remove the batteries and count to 10 and replace them.
Description Item # 00835165000P Model # 4GNC25302 The GNC WirelessWeight GS-7006 Digital Bathroom Scale accurately measures weight, body fat, water hydration, bone and muscle mass. This item features a removable wireless display that can be conveniently mounted on the wall, so you can see the readout clearly. Built with durability in mind, the scale is made from extra-strong tempered safety glass. The GNC bathroom scale also features an energy-saving auto on/off function and auto zero.
  • Removable wireless wall mount readout display
  • Measures weight, body fat, water hydration, bone and muscle mass
  • Energy-saving auto on/off and auto zero
  • Extra-durable tempered safety glass
  • Weight capacity: up to 330 lbs
  • Requires one 9V and 2 AAA batteries (included)
Apr 28, 2016 | GNC Digital Bathroom Scale
How do i reset my digial bathroom scale
Remove all the batteries. In ones with memory, there are two sets, a 9 volt and 2 x AA.
Jul 16, 2015 | GNC Digital Bathroom Scale
Dimplex Fx20ve 2kw Timer Wall Mounted Bathroom Downflow Fan Heater Pull Cord is stuck
turn of the powere and take the cover off and clean the pull cord and the use a bit of lubricant to keep it free that should loosen it
Sep 24, 2013 | Dimplex Fx20ve 2kw Timer Wall Mounted...
How do i chance the fog light bulb on my ford windstar 2003. I removed the sealed deam from it's location but the bulb is stuck inside. Do the sealed beam could be open???? tks
Are you sure it is a "sealed beam" light. If so, you can't replace the element in a true sealed beam. Thus the name "sealed". Most all recent cars have halogen bulbs that are mounted in a bayonet holder that comes out of the light reflector and lenses assembly. You turn the bulb holder about a 1/4 turn, usually counterclockwise and the holder comes out with the bulb. The bulb can be several different type mounts. Some plug in and some are bayonet mounts also. Get a new bulb and that will help you see how it mounts. When installing one of these halogen bulbs, DO NOT touch the glass bulb with you bear fingers. The oil from your skin will burn on to the glass and reduce the light and shorten the bulb life. Sometimes a little silicone grease on the bulb holder mount tabs will make putting it back together and taking it apart the next time. Just little grease, and only on the mount. Don't get anything inside on the reflector or the bulb and be sure you turn the mount all the way to seal out water. Anything on the reflector will damage the reflector surface. Maybe that is too much about a bulb, but it is important if you don't already know it. Good luck.
Thanks for using FixYa.
Gaker
Jul 29, 2011 | 2003 Ford Windstar
Need heat element for fasco wall mounted bathroom heater, the element is M shaped
Feb 14, 2010 | Fasco Heating & Cooling
The dryer doesnt have any heat.. how do I replace the heating element?
1) Unplug the dryer and pull it far enough away from the wall to remove the vent hose.
2) Remove the screws securing the rear access panel, leaving the top center screw for last. Set the panel aside.
3) Remove the two wires connected to the limit thermostat on the side of the chimney. You need to write down & remember that the wires go to the thermostat and the spade connectors on the ends of the wires will only fit the thermostat. Remove the two wires at the bottom of the chimney connected to the terminals mounted in ceramic insulators. These terminals are part of the heater element.
4) Now go up to the top of the dryer and remove the two screws under the lint filter (pull the filter out first).
5) We need to open the top of the dryer now. Slide a putty knife in between the dryer top and the cabinet to release the clips holding the top down. Push in and pry up about 2.5" in from each corner (see the diagram below).
6) Grab a stub flat blade screwdriver or a short screwdriver (you aren't going to have much room), raise the top (use your head to prop it up) and remove the sheet metal screw securing the mounting ******** top of the heater chimney (it's way to the back and to your left). Before you remove the strap note how it is looped through the slot on top of the chimney.
6A) Some newer elements are now 1/2 of the size of the older style versions, picture help and more picture help and even more picture help.
7) Go back to the rear of the machine and pull the top of the chimney back and out of the drum bulkhead. Note how the chimney sits on two mounting brackets for later reinstallation. Lift the chimney up and off of its mounting brackets.
8) Lay the chimney down with the vent on the top facing you. Remove the sheet metal screw near the bottom. This releases the heater element. Slide the old element out. Confirm that it has failed by locating the break in the coil.
9) Position the chimney above the mounting brackets and carefully lower it into the slots. Push the top of the chimney back into the hole in the drum bulkhead. If the chimney doesn't fit snugly into the hole, check the alignment of the slots at the base of the chimney with those in the mounting brackets.
10) Raise the top again and replace the mounting strap and the screw at the top of the chimney. Lower the top and lock the clips by pushing the top down. Replace the two screws that were under the lint filter. Slide the lint filter back in.
11) Reconnect the two wires to the limit thermostat and the two wires to the heater element terminals. If the heater element terminals are different from those on the ends of the wires that you disconnected, use the connectors supplied with the new element and splice them onto your wires.
12) Replace the rear access panel and its mounting screws. Reconnect the dryer vent hose and plug in the power cord. Check for proper operation.
Nov 15, 2009 | Dryers
I want to install (bathroom) an electric wall insert fan heater on an outside wall. Will the insulation and plastic vapour barrier be an issue???
Depends on the heater/fixture. All devices of this sort list minimum clearances between sides and combustable materials.
As to will insulation be a problem, depends what you call a problem. Will it need to be removed? Most likely yes if for no other reason then to provide cavity/freespace to install the heater. For a exterior wall application a small baseboard electric heater would be a better solution to the problem or a toekick electric heater under a sink vanity.
Oct 14, 2009 | Dimplex DGWH4031 Heater
Need a fuse box diagram to wire in fog lights
Fog lamps are installed on the front bumper. The switch is located to the left of the steering column on the dash panel. The fog lamps are turned off by the circuit relay when the high beam driving lamps are turned on. The circuit relay is located on the right front wheelhouse panel near the blower motor.
Good luck, and remember rated this help.
Removal & InstallationFog Lamp Element
See Figure 1
Fig. 1: Exploded view of a fog lamp assembly
  1. Remove the lamp stone shields, the four bezel attaching screws, and the bezel.
  2. Remove the reflector assembly from the lamp body.
  3. Remove the bulb holder from the assembly. Remove the element from the bulb.
DO NOT handle elements with your bare hands, always handle with a clean cloth. Oil from your hands will cause the element to fail.
  1. Installation is the reverse of removal.
Fog Lamp Switch
The fog lamp switch is removed and installed by simply prying the switch from the instrument panel and unplugging the electrical connector.
FOGLAMP BEAM ADJUSTMENT
  1. Position the vehicle on a level surface, facing a wall approximately 25 feet away. Remove the lamp stone shields and loosen the adjustment nuts.
  2. Turn the fog lamps ON and adjust as follows:
    1. Distance between the light beam centers should be equal to the distance between the lamp assemblies on the bumper.
    2. Height of the light beams on the wall should be 4 inches less than the center of the lamp assemblies when mounted on the bumper.
  3. Install all previously removed items after turning OFF the fog lamps.
1995 Cherokee Chassis Schematic
www.autozone.com
Aug 11, 2009 | 1995 Jeep Cherokee
Freelander Deisel,constant vibration,shudder.
remove drive shaft and all vcu components, take for a short drive ( car will still drive in 2 wheel mode, if vibration gone suspect could be vcu , if still felt at front suspect ird if still felt in rear check diff mounts then diff out put bearings and nose end play.
Jun 15, 2009 | 2004 Land Rover FreeLander
What wall heaters are dangerous and shoul be removed from a house
The ones which have a loose heater coil touching the body of the reflector, need to be replaced. When the wall mounting plug is heating up, replace it with a standard one. It should not be loosely connected to the socket.
Jan 22, 2009 | Heating & Cooling
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
