Question about Electrolux Washing Machines
Electrolux aqualux 1000i do not reach high spin spin speed changed brushes and replaced motor
SOURCE: electrolux aqualux 1200 ew
I had a similar problem with a different make recently. After cleaning the filter which didn't seem to have anything in it and rinsing the filters on the in and out pipes I took all the clothes out and ran it empty on two different full programmes and somehow the gremlins disappeared and it works fine now.
Posted on Oct 16, 2008
SOURCE: Washer won't spin.
From Howtomendit: key point I missed was that you need to pull the motor apart after you have taken it out of the machine before you can get access to the screws holding the brushes in. (ie: unscrew the four bolts). Not as difficult or scary as it looked!
please read thro first.
first unplug it, pull it out so you have some work space, take off back plate, remove belt undo (should be white rectangle plastic block with wire attached), remove green+yellow wire undo bolts which hold motor to drum, gently ease out motor (please be aware of sharp edges), run screwdriver down 1 side of motor so you put it back together same way you took it apart, unscrew 4 bolts that hold motor together take top bit of dont loose spacer ring, place to 1 side, remove middle comutator the end the brushes are touching will need a proper clean wd40 maybe wipe clean with cloth so its not dull let dry, undo carbon brushes, take plate off also clean then clean what they were attached to when dry replace in reverse order gently (with new brushes) then replace back on machine plug back in and test by running spin program found at bottom of dail if i have my mod/num right let it get to full spin watch motor if it sparks an looks like blackpool illuminations motors no good will need new 1 sorry.
image_icon_name.gifsteven
Posted on Dec 30, 2008
milten1
  • 1304 Answers
SOURCE: maytag neptune will not go into high speed spin
inspect control board behind control panal
look for burning
resister r- 11 is burnt
Posted on Oct 05, 2009
mnwarfield10
  • 452 Answers
SOURCE: electrolux aqualux 1200 water leaking from door
have door gasket changed .....01179512835
Posted on Dec 30, 2009
barkencoa
  • 3463 Answers
SOURCE: HOTPOINT AQUARIES WM63 , NO SPIN SPEED- MOTOR
If the brushes are less than 3 or 4 mm long, then they need replacing.
If still no spin , but washes o/k, then the high speed part of the motor windings could be faulty, which entails replacing the motor.
Please rate my solution.
Thankyou
Posted on Jan 19, 2010
Why won't it start?
Is the power reaching the starter motor so it can spin - did you check that? If no power is reaching motor you have to back trace the wiring - power could be getting to the ignition switch but not reaching the motor. If power is reaching the motor and it does not spin there could be something wrong with the starter - if so check the brushes.
Sometimes the brushes wear and the spring that pushes the brush up against the commutator is not long enough with the shortened brush - replace the brush(es).
Jul 22, 2015 | 1983 Suzuki Tempter GR 650
Model fwt645rhso will agitate but won't drain out, on spin cycle washer spins one way, stops goes back the other way, but water will not drain out. Does not rapidly spin on final cycle. Any...
There's an auxiliary switch in the door lock.switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. The machine will NEVER advance to the spin cycle unless the auxiliary switch is activated as a safety feature to prevent the door from opening during a high-speed spin cycle that may result in physical injury. The drum tumbles back and forth while the machine control checks the auxiliary if activated but since it's not, the control will not command the motor speed control to spin the drum at high speed. These symptoms may indicate a faulty door lock/switch assembly and may need replacement. Click on the links below for the detailed troubleshooting instructions and replacement of the door lock/switch assembly.
Electrolux and Frigidaire Washers Door Lock/Switch Assembly Troubleshooting
Replacing the Door Lock/Switch Assembly on Electrolux and Frigidaire Washers
Jun 18, 2011 | Frigidaire GSTF1670A Front Load Washer
My 1200I washes ok but does not get to spin speed, I suspect its the motor brushes, is this correct?
It seems unlikely as if the motor brushes were worn I would expect problems making the motor turn at all. It would seem that a number of owners have had the same problem and it is due to the load sensor thinking that the load is not even. If it thinks the machine will be subject to excessive vibration it stops the spin progressively. I don't know how the machine checks for uneven load, there must be a vibration sensor, maybe it gets worn and needs replacing, but I suggest you redistribute the load and spin again. Make sure the machine is level and not rocking. Also have a look here http://electrolux.manualsonline.com/washerdryer/ew_1200_i/possible-causes-21.php Please rate my reply thank you.
Jan 05, 2011 | Electrolux EW1200i Front Load Washer /...
At its lowest setting, our mixer spins at ever increasing speeds until it stops and then, will not work at any setting.
Your motor needs to be replaced. The speed setting should be able to be set from the start, and if it will not slow down or change speeds, the motor has been over-heated and will need to be replaced. The only quick fix for this is to bypass the speed setting, and change the brushes on the motor. If you do not know how to do this, ask a serviceman to change the brushes only. Brushes usually run about $30 to repair. Although, you will only have one speed.
Nov 16, 2010 | KitchenAid K45SS Classic Stand Mixer
Washer/dryernot drying-Electrolux - Aqualux 1200 EW
check the drain filter is clear / pumping efficiency good. possible blockage in side chamber on righthand side. fan motor assy on top of chamber may be faulty. a condensing water valve could be faulty its the dual cold valve that the cold hose connects to without it you just get a steam and hot clothes.
Jul 20, 2010 | Electrolux Washing Machines
HOTPOINT AQUARIES WM63 , NO SPIN SPEED- MOTOR WORKS OK ON WASH, BRUSHES LOOK OK.
Thankyou
Jan 19, 2010 | Hotpoint Washing Machines
Electrolux aqualux 1200 water leaking from door
Dec 30, 2009 | Washing Machines
Electrolux aqualux 1200 ew
hi you need to change your big timer you can have one for 40$ uses
bey good lock
Oct 16, 2008 | Electrical Supplies
Oct 16, 2008 | Electrolux EW1000i Front Load Washer
Washing Machines Logo
111 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
