Question about Atwood Mobile Products Llc Water Heaters Main Burner G6a 4e & Gh6 6e
!990 Bounder By Fleetwood Water Heater is not lighting the propane
I have a Atwood 6 Gallon Gas Water Heater Model #G6A-6E electronic ignite water heater. When I turn the switch to on I hear the mechanism clicking to try to ignite but then the light goes red and all clicking stops. Any advice? I did try turning it off after 5-15 seconds but nothing, no gas is getting to the tank, just the clicking
    Scholar:
  • 155 Answers
Check the gas line orifice for a spider web. Its possible the gas is not able to get past the web.
Posted on Nov 30, 2012
  •  John Burloo
    John Burloo Dec 01, 2012
    That didnt work I guess there wasnt any spider webs...I did take the igniter off and blew through the tube with the compressormaybe theres something wrong with the thing that lets the lp through...I noticed a pin hole and I am reluctant to take that off...
Need to add electric heating element and thermastate to g6a-6e gas water heater
I don't know how you can drill into aluminum tank and install element.
That seems a good way to ruin the heater.
Why not just buy small 'under counter' 1500 watt electric water heater at local box store and install in-line before the water reaches atwood gas heater.
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
Otherwise I do not have a solution.
Don't blow yourself up by messing with gas appliance.
Mar 16, 2013 | Water Heaters
Need to replace G6A-6E Atwood waterheater, what replacement model can I use?
Why not the same model/size? Atwood 6 gal, works on propane with electronic ignition. Or, you can get the 6 gallon with electronic ignition, and electric element as well provided you are willing to run hydro to water heater as well, if not already there. Check any RV parts site for prices and availability. Some places are out of stock currently. I assume your current tank is leaking?
Sep 29, 2012 | RTO Atwood Water Heater - 6 Gal LP
I have a 1997 Fleetwood Bounder with an Atwood G6A-8E water heater. My pressure relief valve was leaking heavily, and I think it shorted something out, because now my electric igniter will not light the...
Have you checked your fuses? there should be a removable cover to pull off there will be a fuse in side that powers the self ignite..can you take a pic of the panel and post it or send it to my email?
Nov 30, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
I just replaced my gas valve thermostat on my 6 gallon Atwood water heater model G6A-7 and the pilot lights fine, but as soon as I turn up the gas, the flame almost engulfs the tank. There is even a flame...
There are a couple of things to check....
I am assuming that the gas is LP or Propane....
make sure that the gas valve is for the right gas and not natural gas...
Also, it is possible that the regulator that cuts the pressure from the tanks is bad and that maybe why the original gas valve failed....
If you have the correct gas valve installed, get a gauge and check the pressure of the gas right before the gas valve...it should be somewhere between 8 and 12 inches water column...
If the regulator is not working properly, check that the vent hole in the regulaor is not plugged by a mud wasp nets or something like that...
heatman101
Jul 16, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
I have an Atwood water heater model G6A-8E. When
If this model has a thremo couple you might want to check it. It sounds like that is the problem.
Jun 07, 2010 | RTO Atwood Water Heater - 6 Gal LP
I have a G6A-7E electronic ignite water heater.
Make sure propane is on and getting to your stove burners ok, first, then try switching it back on. If it fails to ignite, shut switch off and try a couple of times, if still no ignition, get back to me.
May 24, 2010 | RTO Atwood Water Heater - 6 Gal LP
How hot are the 12 volt house lights suppose to get? I'm plugged in to a 20amp. I have a 2000 Fleetwood bounder
They get hot, just like a regular bulb. It will burn your fingers. Ever see a car's brake lights that have melted through the lens? Hope this helps.
Apr 22, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
I have an Atwood Direct Ignition Model G6A-4E 6 Water Heater
I am a RV service tech and that is an old unit. Your control board is bad but with the age of that unit I would strongly suggest replacing the whole water heater, you can shove a pile of money at it and still have an old water heater when for 3 to 500 bucks you can have a new one with a 2 year warranty
Mar 03, 2010 | Water Heaters
Atwood Mobile Products Llc Water Heaters Main Burner G6a 4e & Gh6 6e Logo
295 people viewed this question
Top Atwood Mobile Products Llc Water Heaters Experts
Donni Steen
Gil Shultz
Are you an Atwood Mobile Products Llc Water Heater Expert? Answer questions, earn points and help others
