Question about VIA Epia M860-12e Fanless Mini-itx Embedded Mainboard
How to connect EPIA_M860-12E to a monitor for starting it?
What are the accessories I need to make the connections?After making connections how could I cross-compile?
  • 5,660 Answers
1) Power Supply to Motherboard
2) Motherboard to Monitor
Motherboard has Processor, and Ram Memory on it.
Monitor cable plugs into I/O area on motherboard.
(Input/Output area. Where the Mouse/Keyboard/Audio ports, etc, are)
You can lay the motherboard on a piece of cardboard, then on the table you're working on.
Make SURE you are FOLLOWING Anti-Static Precautions. If you are not aware of what these precautions are, please post back in Comment.
To start the Power Supply, jump the two contact pins in the Front Panel header on the motherboard, with a small flat tipped screwdriver. (Jewelers screwdriver is the best for this)
(The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
Main wires being;
Power On switch, Power On LED light, HarDDrive activity LED light, and Restart switch; IF your computer uses a Restart switch )
http://ep.yimg.com/ca/I/yhst-27518546784426_2237_361300875
http://www.tragant.de/pdf/32992-4f05de2de5d79.pdf
If that doesn't start the Power Supply, then use a jumper wire on the Green, Soft Power On wire, to ANY Black wire. ALL Black wires are Ground wires. (Negative connection)
The contact period is NO more than 2 seconds.
http://www.viaembedded.com/en/products/boards/1510/1/EPIA-M860.html
Bottom -> Users Manual UM_EPIA-M860_113.pdf
After you click on the above, a small window will come up on the right.
Make SURE there is a Green dot in the small circle to the left of -
Open with.
If not, click in the empty circle to the left of Open with.
[Should state Adobe Reader (default) in the box to right of Open with]
The Front Panel header is on Page 31 (Adobe Reader page number box at Top)
Two rows of contact pins.
TOP row is numbered EVEN.
BOTTOM row is numbered ODD.
Top row from Left to Right, is Pins 2, 4, 6, 8, 10, 12, 14, and 16.
Bottom row from Left to Right; is Pins 1, 3, 5, 7, 9, 11, 13, and 15.
Pins 6 and 8 are for the Power On switch.
{ Pins 2 and 4 are for the HarDDrive activity LED light.
Pins 10 and 12 are for a Reset switch, IF a Reset switch is used.
Pins 14 and 16 are N/C. Not Connected.
Pins 1 and 3 are for a Dual color Power On LED light.
Pin 5 is the Ground for the Dual Color Power On LED light.
Use pins 5 and 7 for a two wire Single color Power On LED light.
Pins 9 and 11 are N/C.
Pins 13 and 15 are for an internal speaker. The small speaker/buzzer for hearing BIOS Beep Codes ]
The main power cable is a 20-pin ATX main power cable.
General example of a 20-pin ATX main power cable, and it's respective connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
You want the main power cable plugged into the motherboard, as shown in the photo to the Right.
The Green wire is the Soft Power On wire.
-> ANY Black wire is a Ground wire.
The preferred jumper wire is a straightened out paperclip, bent into a U-shape.
The top of the U is wrapped a few times with black plastic electrical tape. This taped area is for your fingers, and thumb to hold onto.
Turn the U shape over, and it is the 'legs' of the U that you are going to use.
One leg goes down into the socket hole, where the wires go into thew connector; RIGHT NEXT TO the Green wire, and slides down in.
Slides past the green insulation of the wire, and Touches a metal terminal at the End of the wire. MUST touch that metal terminal.
The other leg goes down into a socket hole, with ANY Black wire in it.
The contact period is no more than 2 seconds.
Power Supply comes on you have a bad Power On switch.
Power Supply does NOT come on; you have a bad Power Supply.
The Soft Power On circuit is 5 Volts DC.
In comparison two D cell flashlight batteries produce 3 Volts DC.
However, not stating that there may be a small spark, as you connect the U-shaped jumper wire.
For this reason you may wish to use a glove, on the jumper wire hand.
Cross-compile connections? I am at a loss.
Explain further in a Comment.
Regards,
joecoolvette
Posted on Nov 30, 2012
Computer no turn on
CHECK WITH A OTHER MONITOR.
CHECK THE CABEL SHOULD SIT TIGHT IN BOTH MONITOR
AND VIDEOCARD.
THE VIDEOCARD SHALL SIT TIGHT SCREWED,AND WELL
SEATED TO THE MOTHERBOARD.
THE VIDEOCARD CAN BE BROOKEN.
Feb 27, 2014 | VIA EPIA VB7001G Motherboard
My embedded board of model EPIA-M860-12E is running but it is not showing desktop screen.May I know what's the problem is?What should I do?
In which case change the monitor. I have checked the spec of the board and it has a VGA connector and should output to a normal VGA monitor. But your system is designed for Point of information and industrial automation. Try and find a display made for these purposes.
Dec 06, 2012 | VIA Epia M860-12e Fanless Mini-itx...
Epia m10000 pc case internal speaker not works, all sound drivers are ok all sound jumpers are ok
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
if you dont have a motherboard disc you will have to download the drivers
Aug 25, 2011 | VIA Epia M10000 Motherboard
LAN DRIVER FOR CLE266 0S WIN. XP?
you might have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
If you are trying to connect through a modem/router the driver should have come with a disc provided by your ISP internet service provider or your motherboard disc
you might have to connect the usb lead to your modem to get a connection then
click start control panel administrive tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers if you cant find the driver hopefully one of these will help you
http://alpha.majorgeeks.com/Intel_Network_Adapter_Driver_for_Windows_7_d6273.html
http://majorgeeks.com/SiS191_Gigabit_LAN_&_SiS190_LAN_Driver_d5923.html
http://majorgeeks.com/IntelR_PROWireless_LAN_2100_Network_Connection_d4598.html Latest http://majorgeeks.com/downloadget.php?id=5240&file=15&evp=5fbb1c6e47482358c61a5236fb38a112
Jun 16, 2011 | VIA EPIA-ML8000AG C3 800MHz/ CLE266/ DDR/...
Board is not starting. how to install BIOS
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Jan 01, 2011 | VIA EPIA PX5000EG Motherboard
I pulled the jumpers off the audio pins on the
Go to this page on the via website, towards the bottom you'll find a link UM_EPIA-M_150.pdf
which is the manual for the epia motherboards
Apr 12, 2010 | VIA Epia M10000 Motherboard
Ethernet suddenly not working VIA EPIA-MII10000 Motherboard
I need mother board driver for computer emachines t3882
Dec 27, 2008 | VIA EPIA-MII10000 Motherboard
VIA EPIA MII12000
Here is the link for the VIA EPIA M-Series motherboard. The manual link is on the web site.
http://www.via.com.tw/en/products/mainboards/downloads.jsp?motherboard_id=81
Enjoy!
Mike
Aug 06, 2008 | VIA EPIA MII12000 (EPIAMII12000CCM01)...
VIA Epia M860-12e Fanless Mini-itx Embedded Mainboard Logo
144 people viewed this question
Top VIA Computers & Internet Experts
David
David
Tony
KG John Justin
KG John Justin
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
