Question about Philips 42PF7320A 42 in. Plasma HDTV
Menu options keeps popping up
Whenever i turn on my tv the menu options just pops up like that and i cant get rid of it. I'll press menu then it'll go away for just a little bit then it will pop up again. Please someone help me get stop it from popping up.
  • Anonymous Nov 28, 2007
    need software upgrade
  • Anonymous Feb 29, 2008
    The menus options keep popping up. I have changed the channel, turned the tv on and off, and even took the batteries out of the remote but the menu options continue to pop up on my screen! It's driving me crazy!!!
The menu kept popping up no matter what I did. I even tried taking the batteries out of the remote and restarting the TV. Looks like my problem was with the obsolete software. The software upgrade provided here worked perfectly. Apparently i hadn't upgraded it for two years, no wonder it went cookoo. The problem's fixed and the software is upgraded i am more than satisfied with this wbsite. Thanks guys.
Posted on Mar 02, 2008
You need a software upgrade. It is free. Go to Philips.com and enter your model. You will find the software upgrade info there. You need a USB memory stick. Easy to follow instructions are at the website. Another issue with these is the cable from the IR rec is dressed too close to some large coils on the X board. The cables need to be rerouted.
Posted on Sep 03, 2007
    New Friend:
  • 129 Answers
The SSB board need to be replaced thi s will fix the problem once and for all. its the fastest way . unless you want to try and call philips support to obtain the memory card with the software upgrade for it.
Posted on Jun 15, 2007
  • 203 Answers
Sounds like the button cluster has an issue...see if the menu button is stuck and if not, repair may be needed to disassemble the TV and have a look at the control section.
Posted on Jun 08, 2007
Samsung smart tv. Menu bar on power right corner occasionally pops up. It doesnt work so I cant get rid of it except to unplugged it. What makes it come on?vwill it huurt anything?
hi don't keep unplugging your tv it will do damage, look in the menu on the tv for osd setting, look for the lowest setting thanks
shaun
Jun 12, 2017 | Samsung Televison & Video
Menu Keeps Popping Up
There is either a short in the menu button on the TV or it is sticking/dirty.
Jan 30, 2014 | Vizio 60" E601I-A3 Full HD LED-LCD TV
How do i get rid of these pop ups which keeps appearing on my samsung tv( series 3) screen on one side and at the bottom
Use the remote to disable the apps the tv is running, they are called 'widgets' and you have them turned on. It will be inthe menu for internet options
Dec 15, 2013 | Televison & Video
My screen indicates hdmi 720p on the top right corner then the video menu pops up. it goes back and forth making watching tv unbarable. also the volume flashes when it is pressed i have a Hesense 32 inch...
The HDMI 720p pop up,because on the tv Menu setup OPTION,U pick YES on the tv Program Title Display option,pick NO should stop the pop up HDMI 720p indicator.The volume bar indicator pop up when it press the button to turn volume up or down it is mornal functions of the tv.
Apr 04, 2011 | Televison & Video
Menu Screen keeps popping up, interrupting cable stream on tv
You have it in the demo mode go into menu and turn it off.
Aug 06, 2009 | Televison & Video
Screen keeps going to menu mode
THE SWITCH BEHIND THE MENU BUTTON ON THE TV IS MOST LIKLY DOING YOU IN
Nov 14, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Google end user
As you did not state whether you are using a Mac or Windows computer I am assuming you are using Windows.
Be sure your pop-up blocker is turned on. this is found in the tools menu. Also check to see if the pop-up blocker settings are allowing this site to run pop-ups. If this does not work I recommend the following.
I'm assuming you're using microsoft's browser. Go to >tools>internet options>browsing history>delete and delete temporary internet files and then delete cookies. You will lose automatic log on passwords and login names so be sure you have recorded them. Reboot your machine and hopefully these pop ups will go away.
Sep 21, 2008 | Toshiba Satellite A135-S4527 Notebook
Guide plus
can you let me know if you got help for this? the gude plus menu is blank and keeps popping up in the middle of a show for no reason. then the picture goes out behind it. the sound works ok though.
Jan 10, 2008 | RCA F32649 32" TV
Cant get rid of captions
look on top and behind of the monitor you will find buttons for your TV then follow this steps: The Setup menu lets you configure the TV to fit its surroundings and your preferences. To access the Setup menu, press MENU, and then select Setup from the Main Menu.closed caption options are: CC Setting Lets you choose the way closed captioning information appears on the screen. Off No captioning information displayed. On Always Captioning information shown always, when available. On When Muted Displays captioning information, when available, whenever the TV?s sound is muted by pressing the MUTE button. The captioning information is not displayed when the sound is not muted. Make sure all of the options for closed caption are off press exit and you are good to go.
Aug 23, 2007 | iLO 3200 32 in. LCD Television
Pop up box appears periodically
try bringing up the menu, and see if there's an option "factory default", and try that. you didn't mention what button on the remote you press to get rid of the popup, or what feature you are turning off to get rid of the popup,
Jun 28, 2006 | Samsung LTM1575W 15 in. LCD Television
Philips 42PF7320A 42 in. Plasma HDTV Logo
346 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
